Methods to find TDC? | Page 4 | FerrariChat
Discussion in '348/355' started by Dave rocks, Dec 25, 2017.
  1. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    This makes sense, I didn't consider that. Seems like more gear adjustment is not necessary.
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Some things are hard to explain. When you do this and do it slowly you get a feel and sense for it. But, John is right in saying that you still are interpreting the measurement a bit and to do this with more accuracy would really require a degree wheel with finer resolution and same with an indicator although .0001" resolution is pretty darn fine for an indicator. And I do have confidence in my ability to split 1 degree by eye on the degree into 4.
    Based on last nights experiments, I very certain the max measurement uncertainly would be 1/4 of a degree and if we can all agree on that, we can agree that each method will yield the same results. And truly, without question, the dead stop removes a level of operator error and is the better way to go. I'm fairly certain I will get accused by some for making this statement because I want to sell tools :rolleyes:
    taz355 likes this.
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    #78 johnk..., Dec 27, 2017
    James, I have download the spread sheet you referenced. It's basically the same as mine but I figure you wouldn't believe mine. ;) I have made two changes. First, I changed the increment for the crank angle to 0.01 degrees rather than 1 degree. Second, I reformatted the Piston Position cells to scientific format. Now, look at the piston position. even 0.01 degrees from TDC the piston is displace, and the position is changing. Next look at the Piston velocity. Obviously, even at 0.01 degrees it is not zero. How can the piston be stopped in the dwell if has velocity. The thing about this spread sheet is that it doesn't account for clearances (neither does mine) so it represents the purely geometric behavior in the limit of zero clearance. And, as shown, there is no dwell. The is no angular region around TDC where the piston stops and remains at rest as the crank continues to rotate. Clearances, and only clearances are responsible for the dwell. If there were no clearances the only dwell you would measure would be because of the limitation of the instruments used to measure the small displacements around TDC.
    By the way, as wrist pin off set is introduced the piston stop method will becomes less accurate as the offset increase due to a lack of symmetry in piston motion about TDC. I will have to modify my spread sheet to account for this. I don't think the one you linked to accounts for in the way I expect.
  4. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Didn't I tell you wrist pins are offset? :D I don't recall the amount but I'll have my buddy at GM check for me ;)
  5. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    John I agree that if we bring it out another tenth dwell no longer exists! That's why I have mentioned "as measured with the tools here". As I understand it piston dwell is considered to be degrees of crankshaft rotation within .001 piston movement.
    In texting with Dave last night I mentioned that all this makes perfect sense if there is no 1deg of dwell but, that is what is viewed with the tools and methods we are using even if that ceases to exist if measured with more precision.
    Still, if you adjust rod/stroke ratio you can see differences in piston position vs crank angle change which is more than just a result of bearing/wrist pin clearance and would change "degrees of dwell" within .001 piston movement.
    Good point about the offset wrist pin. Maybe we should use a bridge type piston stop with the head off that has a larger surface area that would square the piston in the bore rather than a small point the piston can rock on.
  6. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    taz355 and Dave rocks like this.
  7. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    One more comparison of piston stop vs dial indicator method. Just further shows there can be some variance in interpretation/result if using an indicator. Not so much going to happen with a piston stop.
    https://www.ferrarichat.com/forum/posts/144460171/
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Many people are going to criticize this thread but I'll tell you what - this is a great thread and great discussion. It pains me to keep saying John is right but as stubborn as I am, I'm happy to bow down when I'm wrong. Lot's learned here and I'm grateful for it. ;)
  9. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    I don't know how many holes in the 355 cam and sprocket but in the 550 it is possible it achieve an accuracy of .06 of a degree in setting the cam in relation to the crank.
    This is because moving the sprocket in relation to the belt with the cam locked in place changes the starting angle of the sprocket/cam hole relationship so for every belt tooth the sprocket is moved a new and different vernier equation is established between the sprocket and the cam.
  10. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    If so, 0.001 is just something some one made up. Arbitrary. Why 0.001? why not 0.005 or 0.0005, or 0.1? It has noting to do with TDC. If you define the dwell as where the piston move less the 0.00X from the TDC position dwell what would that tell you about TDC? I'm ok with calling that dwell, but it would then be unrelated to what we are discussing.
    No argument that stroke and rod length effect things. It's geometry.
  11. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Yes, but they are all offset. Search and read up on it. It's mainly used for reasons as I mentioned last night, to reduce piston chatter in the cylinder, or noise. Also used to more align the thrust axis on the power stroke. Whether or not 355 pistons are offset I have no idea. But your TDC results suggest that either it isn't or it isn't very much.
  12. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    Arbitrary yes. Why not .005 or .0005 or others? I don't know, maybe not repeatable at that level. Dave what value did you use to determine 1deg dwell? We never discussed a standard for this.
    Did we find tdc by the last .0005? Why not .0005? Why are we visually splitting 1/4 degrees on a wheel with a pointer instead of using a rotary angle encoder?
    Probably because the values that are commonly used are as accurate as they practically need to be.
    If the above is true how is it unrelated to what we are discussing?
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I know they all are. I will have an example amout later today.
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    The 1 degree dwell was measured with the .01mm (.00039") resolution indicator. I think I was getting a bit more with the .0001" resolution indicator. I will do it again and will see if I can rig something to hold the phone while I video it. To rotate the crank slow and smooth, 2 hands are needed. I'm not done with this - I want to do these experiments again and try to reduce measurement uncertainty more. It's good to walk away and come back after a few days of thought and discussion. I might even try to add more divisions to the degree wheel.
    No matter what how this is done, we will be dealing with some level of measurement accuracy. But, using the dead stop, we take one whole variable out of the equation and that is the indicator - we are only left with the divisions on the degree wheel.
  15. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    Agreed! :)
    I wonder when the Ferrari method was developed. Maybe at a time before 4/5 valve heads where the spark plug (and therefore piston stop placement) was not centered on the piston? I guess taking up the slack against a stop is taking up the slack no matter where it lands but you would think it would be better centered above the wrist pin/connecting rod than offset to the side of connecting rod centerline.
    Maybe it was an insurance policy so tech's didn't mistakenly turn the engine over by the starter or too hard with a stop in place and damage things.
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Also remember, to use a piston stop, (in a way), you need the cylinder head on. The block lead down tool I designed as the same thread as the spark plug (for the test port) - that is not a coincidence ;)
  17. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    Well you just need something to hold the stop right? (which is why you can use your leak down tool as well?)
  18. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yep :)
    INTMD8 likes this.
  19. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    Neat model. Did you gain the overlap by advancing the intake cam, retarding the exhaust cam or both? Just wondering if the results are influenced by IVC as well as overlap.
  20. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Dave, Put a laser pointer 90 degrees to the crank and a tape measure 10 ft away then measure the distance the laser dot moves. About 1 inch per 1/2 degree. (0.477465)
    Or put the tape 9.5493" away and the laser dot will move 2 inches for every one degree of rotation.
    :):D:eek::rolleyes:
    Dave rocks likes this.
  21. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    I did this today for the fun of it. It is a comparison of how the piston moves in the limit of zero bearing clearance (dark blue curve) with how it moves with clearance (pink). It assumes rotation is continuous from 10 degrees before TDC (-10) to 10 after. I used 0.01 mm clearance. The blue curve (no clearance)is symmetric about TDC and there is no dwell, or region where the piston remains at a constant position as the angle varies. The ink curve, with clearance, shows a different behavior. First, on the approach to TDC (piston moving up) the piston position is lower at any given angle. This is because the closing the clearance gap is like having a slightly shorted con rid. Once TDC is reached, the piston remains at a constant position because the crank has to rotate to a position where the clearance is now opened at the top of the con rod and closed at the bottom (see my post #18). This defines the dwell in terms of the piston not moving over some crank angle. In this case about 1.75 degrees. Once the crank rotates past the dwell the piston start to move down. But notice it is at a higher position that the piston with no clearance. Again, this is because the con rod looks a little longer. If L is the length of the con rod between bearing centers (crank and wrist pin) and c is the bearing clearance, the on the way up the con rod look L -c on the up stroke and L + c on the down stroke.
    Also note that if you define the dwell as the angle between which the piston moves no more than some small amount the dwell is symmetric for zero clearance but not symmetric when clearance is considered. For example. with zero clearance the zero clearance case cross the 175.5 position at -2 and 2 degrees. But with clearance it crosses 175.5 at about -1.7 degrees on the up stroke and 2.2 degrees on the down stroke.
  22. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    If they are, then in the 355 it can not be very much because if it was the piston stop method would give a different result than the dial gage method for finding TDC. The 355 is what matters.
  23. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    John, it's been over 20 years since I first encounter this at GM via Mahle pistons. Yes, from my memory, it's very small - .002" comes to mind. My buddy is pulling a print for me when he has time and will let me know what the value is (for one particular motor).
  24. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    GM pistons aren't Ferrari pistons. :rolleyes:
    :D
  25. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    That is neat. How are we reaching higher dwell numbers calculated with clearance than what Dave actually measured? Actual clearance/movement with oil smaller than .0004in?
    This is with zero main bearing and wrist pin clearance as well?
