Methods to find TDC? | Page 5 | FerrariChat
Discussion in '348/355' started by Dave rocks, Dec 25, 2017.
  1. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I was questioning that too. I need to check dwell again woth the .0001" indicator. I'll try to give it ago again this week. John is also just esimating the clearance.
    INTMD8 likes this.
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    #102 johnk..., Dec 27, 2017
    It's just all clearances lumped into one. I just put in a value to provide a example of the behavior. But I do agree that while the clearance will close up and squeeze out oil, there will always be a residual film of oil. Surface tension, molecular attraction, surface roughness will all contribute to holding some film.
    Edit: To get about 1 degree of dwell would mean closing the clearance up by about 0.005 mm.
    INTMD8 likes this.
  3. fatbillybob
    Aug 10, 2002
    29,430
    socal
    This is why the Ferrari way exists.
  4. Motob
    Motob Formula 3
    Nov 11, 2003
    2,391
    Frederick, Maryland
    Brian Brown
    Umm, for all of this crazy trying to be super accurate, are you checking TDC and cam timing on each individual cylinder? I can tell you that cranks and most cams are not ground to such precision that you need to be concerned with more than 1 degree of accuracy. We had a car in the shop with a Lampredi motor that had reproduction cylinder heads with rocker stands that were so bad that we had to have cams ground with different timing for each cylinder.
    Pangea likes this.
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Brian - if you follow my posts you will see I brought up this exact situation many times. John and I both believe none of this needs to be that precise. The point of this thread was to study each method of TDC regardless of wether or not we feel the precision is needed. In fact, this thread proves that finding TDC with an indicator can lead to errors in that alone which is the baseline for doing the work.
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Apparently you didn't bother to pay any attention to the findings in this thread.
  7. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Nice large degree wheel. DTI through spark plug hole. 0.200" before zero, read degree, turn until 0.200" after zero, read degree wheel, split the difference ai absolute TDC
    johnk... likes this.
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Brian, that's not the so called Ferrari method. That would be similar to a dead stop method. I will do this and compare the result.
  9. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    #109 johnk..., Dec 28, 2017
    5
    No, it would not be similar o the dead stop method. With the dead stop method the piston is coming up the bore form both sides. That is, the clearance issue is the same and the con rod in in compression for both measurements, thus symmetry. If you approach TDC for one side with the piston coming up (con rod in compression, minimum clearance case) and mark the angle at some position X, then continue to rotate past TDC with the piston coming down (con rod in tension, maximum clearance case) you will have to rotate a slightly greater angle to reach the same value of X. See my post https://www.ferrarichat.com/forum/posts/145740159/ The Pink line represents this case. Notice that when clearances is considered the 175.5mm position is less that 2 degrees coming up and more than 2 degrees going down. But as the position in the bore, X, gets further from TDC the error would become less.
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I was waiting for your reply, John. I said "similar", not the same. I realize that keeps the lash so to speak all the same direction. Just like tuning a guitar, you always tune to sharpen, never flatten ;)
    Brian's method is actually a more accurate why of finding when the piston first comes to the top - right?
  11. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    I would not call it similar but.... But Brian's method would be like finding the start of the dwell and the end of the dwell and saying TDC is 1/2 between.
    How would it tell you where the piston first cones to a stop?
    Brian's method will give you TDC somewhere in the dwell. The bigger X (he said 0.2") the closer to TDC, but never exact. If you like, I can modes the error assuming a 1 degree dwell. (Something to do today, for 15 minutes.)
  12. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    Just did a quick check. If you use 0.2" (well I checked 5 mm) Brian's method would be pretty accurate. As good as the piston stop method. The biggest advantage of the piston stop would be that it removes any possible error in setting the piston position by reading a dial gage. Both are ultimately limited by the accuracy in reading the degree wheel. The advantage of both is that you get away from trying to read angles where the piston position is insensitive to angular displacement, like the with Ferrari method.
    {edit} Hum, 14 minutes.
    David Copeland likes this.
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Right. I think Brian's method removes the indicator error reading as you can certainly stop when you reach .200", especially with a .0001" resolution indicator. Then, by going over center, same direction, I see this as an accurate way to arrive at first place piston reaches the highest point. No?
  14. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    You still have to read it though. But here is a really simple extension to what he said.
    1) bring the piston up the bore anywhere near TDC. Doesn't have to be particularly close.
    2)Set the degree wheel to zero.
    3) Set the dial indicator to zero at that position.
    4) rotate the engine backward to where the dial gage reads 0.2"
    5) read the degree wheel. It would be X degrees before the zero reading, say 15 before the zero point for example.
    6) rotate the engine forward, past the zero degree point and continue until the dial gage reads 0.2 again.
    7) read the degree wheel again. It may be Y degrees after the zero point, say for example 23.
    8) subtract, 23-15 = 8.
    9) divide by 2, 8/2 = 4
    TDC is 4 degrees past the zero on the degree wheel.
    Confused? Need a picture? :)
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Nah, I get it. Still would be mid point of dwell.
  16. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    No, starting point is completely irrelevant.
  17. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    #117 johnk..., Dec 28, 2017
    Actually no need to set the degree wheel to zero. That just makes changes the math. . Just measure the two angle where the piston is at the same position and TDC is 1/2 way in between to within measurement accuracy plus a little error due to clearance changes. Brian's suggestion is the simplest. I was just over thinking it.
    About clearances. If the clearance variation is like 0.005mm, and the stroke is 77mm then the amount the crank has to rotate to take up the clearance is
    2 x clearance/stroke = cos(a1) - cos (a2). If a1 is TDC, 0 degrees, a2 = 0.923 degrees. But if a1 = 20 degrees a2 = 20.02 degrees. So the effect of the clearance becomes insignificant on crank angle when you move away form TDC. Again, making Brian's suggestion and the dead stop method basically equivalent, and IMO, this just makes the "Ferrari" method stupid!
  18. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    :eek::rolleyes::D:p
  19. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    Well, you see Dave, it's thinking out loud. Bouncing things off one another. That how progress is made. It's necessary to defocus form time to time. I knew the clearance issue was less important as you move away from TDC, but I hadn't taken a look at how insignificant it became. :cool:
  20. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I know, John - that's how I typically get myself in trouble ;)
  21. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    That's be cause what you do out loud isn't thinking. :confused:o_O:rolleyes::p:D
    Ouch! :D
    AIA
  22. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    OK - get a load of this: The wrist pin offset on a GM 4.3L motor is 0.5mm" - That is much more than I ever remember. Obviously this may vary from manufacture and even make.
  23. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    So when are you pulling a piston out of the 95? I know you want to. It's killing you not to know. :)
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I guess you know me pretty well, John :D ;)
    I'm awaiting for your analysis of how this value could effect what we've been discussing :)
  25. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    Depends on how deep the piston is, whether it's a stop of Brian's approach, when you measure the angles. But it looks like the GM offset applied to the 355 would make it about 1/4 degree difference.
