Methods to find TDC? | Page 8 | FerrariChat
Discussion in '348/355' started by Dave rocks, Dec 25, 2017.
  1. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Iam afraid to say I did not understand what you posted and I did not want to read it twice to figure it out. Ha ha
    I was talking the ferrari method for timing cams. As Dave stated he allready said their method to find tdc. But even this has not been confirmed by Mitchel, fbb, or any others that use it to the best of my knowledge within this thread.
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    johnk... likes this.
  4. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    I was going to search for that post because I remembered having that compensation, or a similar one, with him a few years back. Nice to see you did it for me. Actually the one I was thinking of was about replacing seals. Brian commented that it was unnecessary to do at every belt change. But same thought.
  5. FSM348
    FSM348 Formula Junior
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    Well, thanks guys for splitting the hair to the point of needing Atomic Force Microscopy to see the result. Seriously, I'm coming up on checking timing on my 348 once I get my butt back out into the garage and this thread has really been interesting to read.
  6. fatbillybob
    Aug 10, 2002
    29,377
    socal
    OMG dave! So you would be willing to spend what 10 hours and drain a bunch of fluids, rebleed the clutch, and rebleed the brakes etc etc to remove the engine and just swap belts? So when a cam seal starts leaking you will happily pull the motor again? Yeah RD said it but do you think he or his customer would be happy if customer spends 2k for belt swap and the cam seal then leaks? Who pays for that motor to come out again? Can you see that fiassco posted on fchat? I'm thinking tar and feathers. Silly dave just silly. Again just another case where reality rolls all over your love of theory.
  7. FlyingHaggisRacing
    FlyingHaggisRacing Formula 3
    Jul 2, 2013
    1,377
    Question.....
    Over say 3 or 5 year interval what might be the typical and worst-case amounts of belt stretch that have been seen, but yet the engine is running reasonably well ?
  8. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    #183 johnk..., Jan 4, 2018
    My God is right. It's not like cam seals go from leaking to OMG the dam just broke over night. Experience as taught me they tend to start weeping a little and typically stay that way for a long time. If a cam seal started leaking like that a month after an engine out you could easily wait until the next schedules engine out to take care of it.
    This is exactly the type of thing that give 355 a bad wrap. People insist in doing corrective maintenance as preventive maintenance because, well, "while we're in there".
    I can answer that question base on 25 year old belts from my 308. On my 308 the 25 year old belts, on the car for 25k miles, deviated from the design length by 0.8mm and 1.0 mm respectively. The tolerance for new belts is +/- 0.75mm from the design length.
    Dave rocks likes this.
  9. fatbillybob
    Aug 10, 2002
    29,377
    socal
    No. What give all Ferrari's a bad rap is not fixing the cars while paying attention to detail with sound plan for repair and maintenance.
    thorn and bcwawright like this.
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    ernie and SoCal1 like this.
  11. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,478
    Atlanta, GA
    Steve D.
    awesome! works on a 348 too?
    sjd
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    If it's the same thread as a 355, it should. I've not had the time to check fitment with other models which would be ideal to make one tool to fit several. In theory, as long as the threads are the same, the tool should work across other models providing it's not too long. I designed it long so it can be installed / removed with the knurl from the top and not dropping down the cam covers.
    M10 x 1.0 thread.
  13. steved033
    Apr 12, 2017
    10,478
    Atlanta, GA
    Steve D.
    looking up spark plug thread sizes, it looks like I'm 12mm threaded.
    sjd
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I believe Ferrari uses M10, M12 and M14. We will design and build others as time permits.
  15. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    Does not work on 348 !
    Will work on some motorcycles.
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Mitch - if you are willing to test an M12 on a 348, we will make a prototype and send it to you. I need to determine what threads are used on each model so we can make univeral tools to cover all models that share the same thread.
  17. yelcab
    Nov 29, 2001
    13,698
    San Carlos, CA
    Mitchell Le
    Send it to me, I will test it.
    M
    phrogs likes this.
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Mitchells hard ontools Dave. Ever seen the bent wrenches he used to get the 355 power steering line off with.
    Hopefully they are T1
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Cases?
    I dont need no stinkin cases!!!
  21. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
  22. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yes. We will be making a video. Or, a few videos:)
  23. fatbillybob
    Aug 10, 2002
    29,377
    socal
    GTUnit likes this.
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Stay tuned. We will prove it is the most accurate way. Although even with proof, I know you won't belive it.
  25. Beetle
    Beetle Formula Junior
    Apr 10, 2013
    776
    8 pg's of how to find TDC.????????????????????? See a mechanic.
    GTUnit likes this.
