Metrojet A321 crash in Sinai | Page 5 | FerrariChat
Discussion in 'Aviation Chat' started by beast, Oct 31, 2015.
  1. TheMayor
    107,637
    Vegas baby
  2. Zack
    Zack Formula 3
    Dec 18, 2003
    2,003
    Nicosia, Cyprus/Cali
    Zacharias
    For the most part, security is just theater. Everywhere.
  3. TheMayor
    107,637
    Vegas baby
    Unfortunately, I think you are correct. However, it gets rid of the amateurs and nut cases and leaves it to the pro's.
  4. tazandjan
    39,396
    Just like a home burglar alarm. Hopefully makes them go somewhere else.
  5. Tcar
    Tcar F1 Rookie
  6. PureEuroM3
    PureEuroM3 F1 Veteran
    9,396
    Toronto, Ontario, Canada
    Thomas
    Sadto hear it was declared a bomb. Again those poor souls rip.
  7. joker57676
    joker57676 Two Time F1 World Champ
    Apr 12, 2005
    23,767
    Sin City
    Deplorie McDeplorableface
    Probably a little of both. Would they really take time photograph the device so carefully? I doubt it. Would they recreate it for pics, though? Sure.
    Mark
  8. TheMayor
    107,637
    Vegas baby
    I really doubt that's the bomb. The reason they posted it is to complete the "terror cycle".
    It looks so easy to do that people worry so they don't fly. When they don't fly, the economies are hurt which is what the terrorists are trying to do, aside from get people to join them.
    It's propaganda. But I believe they will find the actual bomb used just like they did with Lockerbee. That they traced to an exact kind of watch used, the explosive material, and the type of radio it was planted in.
    Most likely, this was in someone's luggage. They will find out who's. All the evidence is sitting in the desert. It just needs to be collected and analyzed.
  9. Aedo
    Aedo F1 Rookie
    Feb 22, 2006
    3,616
    Perth
    Steve
  10. Tcar
    Tcar F1 Rookie
    They are NOT claiming that it was TNT.
    It said the "equivalent" of TNT....
    It is common to use "pounds of TNT" in the measurement of explosive power, even with Nukes (i.e. "8 kilotons" refers to that weight of TNT).
    So the equivalent of 2+ pounds of TNT of plastic explosive, for instance, would fit in a soda can.
  11. boxerman
    boxerman F1 World Champ
    19,994
    FL
    Sean
    From what we read, a small enough bomb, placed in the exact right area, and timed to go off at 30,000 feet where even a small breach is catstrophic is what we are looking at. This also implies a higher degree of sophistication and knowledge base compared to just a big bang as the plane gains altitude as in lockerbie.
    This is not the JV team.
  12. KKSBA
    KKSBA F1 World Champ
    15,303
    SBarbara-La Jolla CA
    KKSBA
    #112 KKSBA, Nov 19, 2015
    Every year that goes by will increase sophistication. We will never cover all the bases.
    It is time (well it was years ago) to just roll back security to a metal detector and pound whoever claims responsibility for these acts when they occur.
    There will always be a risk. Always. When someone wants it bad enough, and is even willing to die for it, you just can't defend against it.
    Also, give cabin crew emergency override access to the cockpit. Hundreds of passengers are going to fight hijackers so we don't need to risk one person in the cockpit going nuts and killing hundreds a la Germanwings.
  13. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,018
    Shoreline,Washington
    Robert Parks
    #113 Bob Parks, Nov 19, 2015
    I don't remember what it is but at 30,000 feet the pressure differential is extreme with the cabin at 4000-5000 feet and the outside way lower at 30,000 feet. The fuselage vessel is a bomb if there is a breach. The breach, however small, is also intensified by the speed. The Comet fuselage failure was over in 6/10ths of a second when the ADF window failed. I imagine that if a small portion of the skin was blown open in the aft lower fuselage of the A320 it would precipitate an instantaneous failure in the structure. Just thinking.
  14. KKSBA
    15,303
    KKSBA
    The early "unofficial" reports are a bomb placed under a rearward/rearmost? window seat. Likely smuggled on by servicing personnel with airport access while the plane sat on the tarmac for several hours between flights.
    The "evidence" is a 1 square meter hole blown through the fuselage with outward peeled skin at that location.
  15. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    It wouldn't take much.
  16. donv
    donv Two Time F1 World Champ
    26,392
    Portland, Oregon
    Don
    Typically the pressure differential at altitude will be around 9 psi.
  17. Aedo
    Aedo F1 Rookie
    Feb 22, 2006
    3,616
    Perth
    Steve
    I know that which is why I said "IF they used TNT". I should have been more specific in my post. Even if they used C4 or similar they would not have crammed that much explosive power into that can (which would only contain about 750g). I'm just trying to point out that the ISIS propaganda is just that... it is unlikely to be the bomb used.
  18. Tcar
    Tcar F1 Rookie
    Thanks for that.
    Pics of the wreckage show the tail section separate from the remainder. Apparently the force was enough that when the breach happened, the damage migrated and the entire tail section separated from the fuselege.
  19. norcal2
    norcal2 F1 Veteran
    And hand operated can sealers are readily available, (install tops) they could have had more then one can/bottle with explosives, or even the cart frame, i dont know if they xray drink tray cans and bottle trays from the catering companies prior to loading on the planes...
  20. tazandjan
    39,396
    C4, RDX, and other explosives also have a TNT equivalence much higher than 1, usually around 1.5. So a small amount of either could have the TNT equivalence of 2 lbs.
  21. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    #121 Bob Parks, Nov 20, 2015
    A hole of 9 square meters is huge and with a pressure differential of 9 PSI and huge volume going through, it would quickly open the hole larger with an explosive force that would fail the fuselage tail structure.
  22. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    Crash: Metrojet A321 over Sinai on Oct 31st 2015, broke up in climb over Sinai, preliminary report states no unlawful interference
    This starting to turn in to 1 huge SNAFU Russia and ISIL says it was a bomb and Egypt say it was not.
  23. KKSBA
    15,303
    KKSBA
