mettalic rattle at idle | FerrariChat
Discussion in '348/355' started by lotusk, Oct 16, 2008.
  1. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    gentlemen.................have noticed a loud metallic rattle with my 355 at idle....sort of comes and goes..once revs build up it disappears............maybe a heat shield rattling....if so anyone recommend which one to look at?.......everything is tight on the car...ideas????
  2. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,792
    western hemisphere
    Throw out bearing?
  3. f355spider
    f355spider F1 World Champ
    18,055
    #3 f355spider, Oct 16, 2008
    Exhaust bypass valve. You can remove it and adjust the pre-load or tension to reduce or eliminate the rattle. About two turns out should do it.
  4. tactical
    tactical Guest
    Jan 23, 2008
    857
    One way to check that is to run the engine at idle with the clutch pressed in. If there is no noise then it would well be.
  5. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    how loud is a thrust bearing or bypass valve rattle???
  6. Husker
    Dec 31, 2003
    11,792
    western hemisphere
    Assuming you mean the throw out bearing, the volume is going to be in the range of an 85 lb. German Shepherd barking from 30 feet away, with about a 7 mph downwind.
  7. Dr_ferrari
    Dr_ferrari Formula 3
    Nov 2, 2003
    1,073
    Pocono Sportscar
    Jim McGee
    THREE BIG NOISEMAKERS:
    1 - SHIELD BETWEEN FRONT OF ENGINE AND FUEL TANK
    2 - MUFFLER BANDS
    3 - BYPASS VALVE
    Most likely one of the three.
    Regards, Jim
  8. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    Hamilton, NewZealand
    James
    Could be headers going bad, mine made a sort of rattle/ticking noise at idle. Wasn't very loud though.
  9. tactical
    tactical Guest
    Jan 23, 2008
    857
    Does the sound come from the front or rear of the engine bay by the way.
  10. sandersja
    sandersja Formula Junior
    Jan 16, 2003
    367
    Portland OR
    John Sanders
    For me, it was something that was loose in the otherwise-OK cats. Replacement Hyperflows fixed the rattle.
  11. whyte
    whyte Formula Junior
    Apr 25, 2006
    409
    Merritt Island, FL
    John C
    Parking brake adjustment?
  12. 355dreamer
    355dreamer F1 World Champ
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    I would bet it is the valve. Mine does the same thing.
  13. hezgon
    hezgon Formula Junior
    Dec 13, 2006
    281
    Ft Pierce, FL
    Stan
    +1 this was the issue on my 1995, the rivets work lose. Easy fix. Louder as revs increase, now pure bliss.
    Weekender likes this.
  14. Marco Bussadori
    Marco Bussadori Formula Junior
    Aug 6, 2007
    430
    London
    Marco Bussadori
    Had this 2 months ago too... Rattles at idle (for me when the engine warmed up, not when cold) and through 1500-2000 rpm, then goes away.
    The muffler is segmented into chambers by baffles which have 4 spot welds keeping them in place. These sometimes do crack and the baffle resonates with a rattle sound.
    I had to cut away the edge of the exhaust (listen from which side it comes by listening to the exhaust tips), to then spot weld the baffle and reweld the case. Search for posts with my name for pictures.
    It is now 100% - I did remove a baffle at each side to let it flow a bit better and give more top end sound...
    Marco
  15. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1
  16. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    I actually had a rattle that I thought was the bypass valve, but it turned out to be that one of the bolts holding the Tubi exhaust in place had come loose.
  17. Oengus
    Oengus F1 World Champ
    by pass valve............start there
  18. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    Mine does this too. Can anyone elaborate on the process of checking and fixing the bypass valve?
  19. DMOORE
    DMOORE Formula 3
    Aug 23, 2005
    1,720
    San Diego
    Darrell
    Wire it in the open position. :).
    Darrell.
