Mexico brake lights | FerrariChat
Mexico brake lights
Discussion in 'Maserati' started by remi, Jan 8, 2024.
  1. remi
    remi Karting
    Sep 18, 2008
    112
    Melbourne, Australia
    Hi all,
    Happy New Year. Just prior to Christmas a driver pulled up to me at the traffic lights to let me know that my brake lights weren’t working (nice of him). Both lights are out, regular lights work fine front and back/ indicators etc all good.
    Bulbs look fine, as do the fuses with a quick check. My mechanic is closed for a few weeks for the summer holidays here in Australia, anyone got any troubleshooting tips to get me up and running for some summer driving?
    Remi
  2. JulianMerak
    JulianMerak Formula 3
    Hi Remi,
    I had problems with my Ghibli brake lights, it turned out to be an issue with the brake pressure switch which once replaced solved my problem, is there a similar system on the Mexico?
    Julian
    https://maseratinet.com/maserati/ghibli/3061-brake-light-switch-gt
  3. remi
    remi Karting
    Sep 18, 2008
    112
    Thanks Julian- maybe I should have a look at the contacts of same to see if they could you a clean up?
  4. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,031
    Remi: It should be a very common old Volkswagen brake light switch. You can easily check the thread pitch.
  5. JulianMerak
    No harm in trying but I think the inner workings stop working. Mine were on all the time then stopped working altogether
  6. JulianMerak
  7. thecarnut
    thecarnut F1 Rookie
    3,203
    Atlanta
    The Car Nut
    Most likely the brake light switch has gone bad. Locate the switch and bridge the two contacts. If the brake lights come on the switch is bad. This is a common switch used on many period British cars.
    Ivan
  8. remi
    remi Karting
    Sep 18, 2008
    112
    Thanks- will see how i go!
  9. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    The after market brake light switches are not too reliable, On one of my cars I fitted a micro switch to the brake pedal and extended the wires to this.
    It works reliably and the lights come on instantly when the brake pedal is touched rather than requiring a certain amount of pressure.
