Michelin front/ Pirelli rear, to match diameter. Ok? | FerrariChat
Discussion in 'FF/Lusso' started by RossFF, Apr 18, 2019.
  1. RossFF
    RossFF Rookie
    Mar 26, 2019
    10
    christopher
    I am running a 21/22" wheel setup.
    The rear I am pretty much stuck with one option. A pirelli 335/25/22. Calculating the outer diameter difference from front to rear I come up with a 4.85% difference on an OEM setup. This can vary a bit lets says 4.5-4.9%.
    My current setup is at 6.3% difference. I wont want to risk blowing the PTU or gearbox.
    I can get my setup into the OEM range, with a Michelin 265/30/21, but would have a P Zero rear. I know a silly setup, but thoughts on this?
    27.3-27.4" is my goal for front tire in 21"
    (Also I compiled a list of the sizes, OEM, and so on if it is helpful to anyone else)
  2. lamborarri
    lamborarri Formula Junior
    Nov 15, 2015
    452
    I went thru this with my F12, 812 and Lusso.
    If you 21/22 is the set up, front you can run Pzero PZ4 265/30/21. Don't mix different brands cuz the ratings are different even tho it shows the same.
  3. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    Having different wheel size difference than stock will not put extra strain on the PTU, as by design it engages only when needed, and its clutches are always slipping anyway (due to the difference in gearing between the PTU and the gears in the rear gearbox). However, this might throw a code as the car will try to understand why there is a constant slippage between the front and rear. This might also affect the ABS as it could believe the slower spinning wheels are on the verge of blocking.
    Going with different brand/model tires, especially on a sport car, is a bad idea in my opinion, and can lead to erratic behaviour of the car, especially under the rain.
  4. RossFF
    RossFF Rookie
    Mar 26, 2019
    10
    christopher
    Thanks guys for the input guys.
    I actually found out this is my only option for keeping an all Pirelli setup. They PZ$ in a 265 matches well with the 335 rear Pirelli. The one thing I dont like, is the tread width on this tire. It doesnt make sense to me, with such a wide section width, but the tread is narrower than a stock 20 tire. Concerns on front handling?
    Im going to make a spreadsheet, with OEM FF, GTC4Lusso, options, and so on, with the percentages of F/R difference. If for anything then reading entertainment, but maybe it will help someone...
  5. lamborarri
    Nov 15, 2015
    452
    PZ4's are very good actually, not those old Pzero's. I would like they are not far off from PS4, and definitely better than PSS.
    My Lusso is currently on PZ4 265/30/21 and 315/25/22, they ride just like stock 20's. Much better than I expected.
    rmfamily likes this.
  6. RossFF
    RossFF Rookie
    Mar 26, 2019
    10
    christopher
    Do you think a 275/30r21 will go okay on front? This looks to be a better match from OD, load, and tread width in the Pzero. I will have to check how close the tire is now with a 255 to the shock/control arm, and so on.
    Otherwise I guess I will go with a PZ4 in 265.
  7. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,426
    Bournemouth, UK
    I would say that the Pirellis are superior to the Michelins
  8. richard_wallace
    richard_wallace Formula 3
    Feb 6, 2004
    1,957
    Cincinnati, Ohio
    Richard Wallace
    As stated, the size is not your problem - the different tread pattern front to rear will make the car feel unstable in certain conditions (anything but dry/hot). I would not do different tread patterns from the same manufacturer or different...
    Also - Michelins IMO are far superior to Pirellis (minus their snow tires).. As opposed to the last poster, for a different POV.
    350MH83 likes this.
  9. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,426
    Bournemouth, UK
  10. richard_wallace
    Feb 6, 2004
    1,957
    Cincinnati, Ohio
    Richard Wallace
    A few things to consider... Quite and comfort Michelin are a bit better (even in this test) - important on a GT car (f12, 812, FF, GTC4) , as well you will get around 5K more miles out of a PS4 than a PZ.... (at least in my 20 years of exotics having bounced between both tires over the years.) Don't get me wrong, I switch back and forth and try each generation of both brands (and used to even try Goodyear on occasion and Toyo a few times). Today, I have not found better overall: speed, handling, comfort, quietness, and wear characteristics better than the PS4 - as of now. Could change tomorrow, but as of now - no better.
  11. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,426
    Bournemouth, UK
    The most important thing is comfort? Really? By the way the 812 is NOT a GT car.
    I test my tyres on the track. I have not found a better tyre than the Pirellis. About 1 second per lap quicker than the Michelins in my hands.
  12. richard_wallace
    Feb 6, 2004
    1,957
    Cincinnati, Ohio
    Richard Wallace
    Didn't say most important - read the post again
    812 is a GT car... Really it is.. So is the F12 which it replaced (and I have one of those) :)
    I will give the new PZ's a go on one of my cars during the next change.. as mentioned, always up to switching each generation between P and M's, as the advancements do change.. Speed is not my biggest factor as mentioned, as the amount of time on a track with my F or P cars is much less than street.. And again, longevity, comfort, quietness, etc. are all factors I look at.
  13. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,426
    Bournemouth, UK
    Ferrari themselves beg to differ, classifying it as a sports car, whilst the GTC4 and Portofino are classified as GTs. Even journalists criticise the 812 for not being GT enough (comfortable, long distance cruiser), driving more like a true supercar; more sporty than the rear-mid engined Aventador for that matter.
  14. richard_wallace
    Feb 6, 2004
    1,957
    Cincinnati, Ohio
    Richard Wallace
    I guess we are way off topic.. So will end with this..
    Darn it, I have been calling the F12 and 812 GT cars which is evidently wrong then.... ;-)
    "The Ferrari 812 Superfast (Type F152M) is a front mid-engine, two seat, rear-wheel-drive grand tourer"
    Don't get me wrong, I believe they are as much as a sports car/supercar than any, just talking more specific classification.
  15. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,426
    Bournemouth, UK
    #15 REALZEUS, Apr 21, 2019
    Yes, indeed. I too will stop here, just posting one last pic. ;)
    The confusion stems from the legacy term "GT" that Ferrari used for all its road cars, but in recent years they started to differentiate between pure GTs and super-sports cars.
  16. dcmetro
    dcmetro F1 Veteran
    Nov 27, 2007
    9,048
    Paris , France
    Olivier
    R J likes this.
  17. RossFF
    RossFF Rookie
    Mar 26, 2019
    10
    christopher
    Im doing P zero all around. 335/25R22. 275/30R21. The O.D. are within spec to OEM differences. I expect some slight rubbing on the fabric liner on turns in the front.
  18. montpellier
    montpellier Formula Junior
    Aug 27, 2009
    704
    Europe
    Paul
    Do not ever ever mix tyre brands between axles. Always try to retain the homologated tyres all round, but if you must change, keep the same brand and hopefully compound front to rear. The characteristics of the compounds used can vary greatly, even within one brand of tyre and can totally destroy the balance and handling due to different characteristics.
