Michelotto 308 build | Page 2 | FerrariChat
Discussion in '308/328' started by sp1der, Nov 20, 2013.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,787
    Atlanta
    John!
    Fabulous stuff. If I remember right, that steel front clip weighs something like 40lbs. What does a door weigh in its current state?
  2. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    It is glass, will weigh the doors as they were heavier than I thought, the glass and lift motor are the heavy items. I will try and keep a weight roll up of what has been saved.
  3. HotShoe
    HotShoe F1 Veteran
    8,638
    Lake Worth, FL
    Anthony Lauro
    I apologize but is this a vetro car?
  4. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Yes, however the front end is certainly not factory original as there is a split to the dash part of the moulding, so has been replaced at some time, and then glassed back to the dash. One of the arch liners was also a bit of a patchwork of glass and ally. So far it has been fairly easy to tear down, no seized fixings so can hopefully get on re-configuring the front end fairly quickly
  5. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #30 sp1der, Nov 24, 2013
    Brake booster now out and the rest of the bulkhead stripped. The AC unit has also been taken out, which again was fairly heavy. Trial fit of the pedal box, which fits the plate perfectly plus the pedals miss the steering column.
    ARB clamps and suspension is already ready. Next job is to strip the dash and interior out, and then work out a cage design.
  6. Todd308TR
    Todd308TR F1 World Champ
    Nov 25, 2010
    11,074
    LA
    Todd
  7. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    The pedal box, booster is also a surprisingly heavy item, the new pedal box will allow for adjustable brake balance, plus an hydraulic clutch! Will get that welded up now I know it fits!
  8. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
    Oh yes make it look like this.
  9. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    #34 Brian Harper, Nov 24, 2013
  10. Ferraripilot
    May 10, 2006
    17,787
    Atlanta
    John!
    Great progress. Moving along
  11. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Progress may slow a bit now as I now need to start making templates for the coverings on the bulkhead before I lay these up in Kevlar. There is also a bit of working out to be done so I can get the boxer wiper and mech into the car.
  12. jkedino
    jkedino Karting
    Nov 28, 2007
    59
    Finland
  13. greg 19425
    greg 19425 Formula 3
    Jan 6, 2011
    2,471
    Wake Forest, NC
    Greg
    Hate to say this but 712 – 1. Sorry you did not use a steel car for your project. Hope the finished project comes out as you wish.
  14. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    This evenings progress has seen the whole of the front harness now out, the dash out and the front panel now taken off. The only issue on the harness was the windscreen wiper motor connector, large rectangular connector, small round hole - bit of a mystery how they assembled this in the first place
    Also visible is the joint between the old dash pod and the new front end as the joint line is clearly visible inside the car where new glass fibre joins the parts.
    Dash was a bit of pain as it sits under a channel and some bright spark had decided to glue the centre.
    Hopefully I will be able to configure the rear so I can run either the wide Michelotto rear end or the standard narrow clip.
    Another evening and should be able to start on the templates for the front bulkhead covers, which will also give a marginal increase in foot space.
  15. singletrack
    singletrack F1 Veteran
    Mar 16, 2011
    5,794
    Pittsburgh, PA
    Aw man! Exciting to get started...
  16. BigTex
    79,337
    Houston, Texas
    Bubba
    Yep, glass car..
    Can I have all that 'left over' stuff?? :D :D
  17. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    Fantastic build. Where did u source the michelotto type flares? There look pretty close to the originals
    What are the plans for reinforcing the chassis? I've notice the gr4 m-cars double ups some of the buttress members and added extra triangulation to the strengthen standard chassis. i was always curious on how much of the original chassis was retain unaltered.
    I'd be interested in finding out how much weight you removed and how add back on with reinforcements or safety equipment
    Regards.
    Hf
  18. Ferraripilot
    May 10, 2006
    17,787
    Atlanta
    John!
    +1
    I've seen pictures of some of the original Michelotto added cross members here and there, then there's what Mat do which builds a bit on the original Michelotto additions, specifically the mounting areas. Mat have also entered the 308 chassis into a CAD program which points out the higher stressed areas which is what lead to their additions.
  19. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Will be replicating most of the chassis reinforcements, in fairness most of it is just triangulating the suspension mounting points. All fairly basic stuff. There are some mods at the front and rear to mount the radiator and rear body. The whole rear clip is from Garage Donati taken from original cat, the front lid and rear engine cover from Makela in Finland. I guess at the moment there is probably a new save of 50kg, plan is to try and weigh all the bits removed that are not required for the re-assembly.
    Garage Donati - Site officiel du garage Suisse spécialisé en réparation, entretien et modification de tous les modèles Ferrari
  20. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    Yes the standard 308 chassis lacks basic triangulation. Part of the reason is to get accessibility to the drivetrain for service while the front is somewhat inexcusable :). I reckon by adding a few more members stregically would go a long ways.
    Great that they had access to splash a mold from the org cars. I recall mat looking at the mat site they fabricated theirs flares from photos.
  21. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Will post some more pictures up soon, just working on getting the engine out next, forgot what a pain the driveshaft bolts are!
  22. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #48 sp1der, Dec 1, 2013
  23. Robert W
    Robert W Formula 3
    Mar 13, 2005
    1,471
    Oxford, UK
    Robert Westall
    #49 Robert W, Dec 3, 2013
  24. islerodreaming
    islerodreaming Formula 3
    Aug 11, 2007
    1,708
    John - a proud Australian man
    Hi Simon
    I love where you are going with this but aren't you just a wee bit worried that when you get to drive that countach this is just going to get pushed into a corner of the garage??
    Will be watching how this goes as I have had similar thoughts myself..
