Michelotto 308 build | Page 7 | FerrariChat
Discussion in '308/328' started by sp1der, Nov 20, 2013.
  1. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #151 sp1der, Sep 8, 2014
    Images of the plates used for mounting the cage, both 3mm and will be boxed in, the rear to the main chassis rails and the fronts to the chassis rail and the door post area. These should both provide good strong locations with adequate area and tie in to the strong areas of the chassis.
    Also images of the new galvanised inner sills, and a few shots of the before and after from the soda blasting team at Soda Blasting Ltd (UK).
  2. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #152 sp1der, Sep 15, 2014
    Well the car has gone off to be welded up and so started on a few of the mechanical jobs. The drive-shafts have all been stripped (a messy but fairly easy job) and the heads, and water pump are now off the engine.
    Fortunately the heads came off fairly easily a few good thumps with a mallet and block of wood and they were both free. no steps in the liners and all seems ok, but has been running very rich!
    The cams are michelotto as fitted to the car a number of years ago and have about 9mm lift.
  3. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #153 sp1der, Sep 19, 2014
    Collected the new alloy radiator today complete with revised 4 pin fixings and also twin spal puller fans - a really well made product made by Radtec.
    Also picked up a really nice piece for the garage on ebay a 1 metre tall Prancing Horse in Fibreglass, it has sustained some slight damage on one of the rear legs in transit (probably reflecting this years more than slightly hobbled F1 effort!)
    Welding is well underway but forgot to take some pictures as was busy making sure the box of bits got welded on in the right place (quite a worry when the box of bits was spread on the workshop floor, quite a few more parts than it seemed when making them all).
    The front end is now complete with all of the other miscellaneous michleotto style parts going back onto the chassis. Last job will be the cage welding and new inner and outer sills.
  4. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #154 sp1der, Sep 20, 2014
  5. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,790
    Atlanta
    John!
    Great update! thanks as always
  6. George Vosburgh
    George Vosburgh F1 Rookie
    What a great project, looks like you're making some nice progress Simon!
  7. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Thanks guys turned the corner now stuff going back together and so far no surprises in the engine department so should be a straight forward rebuild with hc pistons and racy cams plus shim under valvetrain. Headwork is already done plus the transmission was rebuilt not so many miles ago so should just be a clean and inspection job.
  8. bigodino
    bigodino F1 World Champ
    13,089
    The Netherlands
    Peter den Biggelaar
    That looks pretty serious! Safety first though.
    I don't know if you've mentioned this before, but have you decided yet about exterior colours/livery when it's done?
  9. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    For sure the cage will not be going anywhere with the 3mm plates all boxed in - the other chassis triangulation parts will also make a difference - the tubes are probably a little larger diameter (and wall thickness) than the original cars plus I made a change to one of the front tubes for a more efficient structure - should all make a big difference to the chassis stiffness.
    The shop doing the work are being very diligent and we have manged to get the car all straight again with the new front chassis leg, we have approx 0.5mm front to rear difference side/side so better than new!
    As for final colours will be the VS Olio scheme (White, Yellow, Blue).
  10. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #161 sp1der, Sep 30, 2014
    Cage now in and most of the new parts on, just a few bosses and bits and bobs to add now. The cage was a little tricky here and there to get access to weld.
    Engine and box also pretty much stripped down, no signs of major wear anywhere in the engine so hopefully just hone and drop new 81mm HC pistons in.
  11. NickH07
    NickH07 Karting
    Jan 19, 2014
    96
    Greensboro NC
    Nick Hawks
    Awesome work so far, simply amazing. Subscribed...
  12. Ferraripilot
    May 10, 2006
    17,790
    Atlanta
    John!
    Great frame work at the front and rear sections!
  13. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Thanks guys, just spent today winding out all of the studs in the engine and gearbox what a pain! All done now so another box of parts ready for the platers.
  14. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,307
    Netherlands
    Steven
    good progress Simon!! love to see more and more
  15. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #166 sp1der, Oct 3, 2014
    Sills now back on and all the mounting brackets for things like the ARB's, dry sump tank and also the radiator mounts. Shop has a few bits of tidying to do and then can collect next week ready for prep for paint.
    The chassis is now quite a bit heavier, I would estimate about 40kg of parts have gone back on including the cage but the chassis is now a whole hep more rigid and has some roll-over protection, the original roof structure is scarily flimsy.
  16. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #167 sp1der, Oct 10, 2014
    Finished stripping the gearbox which was quite a bit simpler than I thought, the main shaft jiggled out complete and the layshaft just needed the synchro ring breaking from it's splines - a few good taps got it loose and then slipped the shaft out.
    Plan is to have all the alloy parts soda blast cleaned and then I can wind all of the freshly plated/new studs back in and start putting the gearbox and engine back together. This week-ends job is to try and get all the bulkheads back on the chassis and get all these holes drilled prior to final prime and paint. The front sills will also be closed up to stop water running down the sills and therefore stopping a potential corrosion path.
    For the new sills we have removed the flanged and just tacked straight to the chassis rails and this gives a much cleaner look and prevents any potential snagging on anything.
  17. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #168 sp1der, Oct 17, 2014
    At last things going back on now - trial fitting of all the bulkhead panels and side panels + the most exciting bit is the new rear lower 3/4 panels. New closure panels made for closing the gap around the suspension and new wheel arch panels and the new rear struts have all been cut back now these are all welded up.
  18. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,541
    Avvocato
    Spider, great thread..... This might sound like a silly question.
    If you were going down to the tubes, couldn't you have done this with a steel car, as opposed to a glass car ?
  19. greg 19425
    greg 19425 Formula 3
    Jan 6, 2011
    2,471
    Wake Forest, NC
    Greg
    BIG RED, see my post #38. Wish it was steel also, but each toooo his own. :)
  20. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    It will just be a lighter faster glass car when done. Taking a steel dry sump car in terms of conversion would probably be even more expensive due to having to purchase a complete set of panels as it is I can re use the roof, doors, front clip.
  21. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    Interesting project, but I still don't get the sacrifice of a RHD glass car for this. Totally agree, however, with you being able to do as you wish. I supported the Germoglio GT4 groovy beach ride build for the same reasons. Your work is very nice...
    Keep the pics flowing!
  22. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,222
    Robb
    Late to the party.
    Subscribed.
    Robb
  23. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #174 sp1der, Oct 25, 2014
    Rear body parts now going on, fit seems pretty good (there is a little fettling to do on the RHS with the flange to the roof but just requires a small cut and shut job)
    The engine cover will need some small brackets making as per the MAT cars to splay the lower edges of the engine cover, I guess when they are made they spring in a little, its about 10mm a side so now major issue as there is this amount of flex in the lid.
    Inner arches have been bonded in and the front quarter pieces cut prior to final fitting plus the mounting holes drilled, the car is certainly a bit wider now!
    Also finally managed to obtain a grp shallow spoiler from a fellow UK FOC member this week so can hopefully start on the front end fitting soon.
  24. Andy 308GTB
    Andy 308GTB F1 Rookie
    Jun 2, 2004
    2,660
    Essex, UK
    Andy M
    Taking shape - I love those fat wheel arches.
    I suspect somewhere in the thread you've already answered this question but what colour scheme are you going for?
    It looks like you are doing the bulk of the work yourself - is that the case? If so, you're extremely multi-talented!
