MIG or TIG. What type of welding process to use on 360 front end? | FerrariChat
Discussion in 'Technical Q&A' started by AEman69A, Mar 23, 2011.
  1. AEman69A
    AEman69A Karting
    Jan 13, 2011
    147
    Central NJ
    Eddie
    Hello Gentlemen,
    I was wondering what type of welding process is used on the front end parts of the 360? Such as the radiator cage, fender, fender extension, etc.
    The parts are an aluminum alloy which under normal circumstances would use a TIG welder. But I've heard contradicting information claiming that because of the thinness of the aluminum alloy and its particular composition, MIG welding with 100% argon gas and a spool gun is just as effective.
    Your thoughts are greatly appreciated.
  2. jav
    jav Formula Junior
    Apr 9, 2007
    508
    Massachusetts
    #2 jav, Mar 23, 2011
    tig is the preferred method. Depending on thickness, a high end mig "may" work but if you want the best weld possible, tig for sure. If your talking thin sections, the control that tig gives you is unbeatable.
  3. 355tsr
    355tsr Formula Junior
    Mar 9, 2010
    322
    Spool gun will pig tail and really makes a nasty looking weld, tig is really the only way for
    Great job , however there is a welder called a cobra that can make a mig look almost like tig
  4. fatbillybob
    Aug 10, 2002
    29,261
    socal
    I use both regularly as a self-taught welder. I would use tig no question. But if you have to ask the question you probably do not have the ability to do the job. So farm that out to a pro and do yourself a favor.
  5. AEman69A
    AEman69A Karting
    Jan 13, 2011
    147
    Central NJ
    Eddie
    Thanks for the replies Gentlemen.
    As some of you have pointed out, the particular gause of the aluminum plays an important role. because the pars in question are quite thin, I was told a MIG will work just as well but I geuss TIG is the way to go.
    I had heard the factory uses robotic MIGs but does anyone know for sure?
  6. AEman69A
    AEman69A Karting
    Jan 13, 2011
    147
    Central NJ
    Eddie
    I don't intend to do the welding myself, but tthe few shops I have spoken to have given me varying responses.
    Anyone know a decent welder in the Central NJ or surrounding area?
    Thanks for the input
  7. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    Do you want to know what process was originally used or what process to use to repair it?
    You can mig aluminum with a spool gun and it should be sufficient but it will never be as good as tig.
    If you are just trying to find out what was originally used post a picture of one of the original welds. I would guess some type of robotic mig.
  8. AEman69A
    AEman69A Karting
    Jan 13, 2011
    147
    Central NJ
    Eddie
    I'm looking for the process to repair it but was curious as to what the original welding technique was as well.
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    +1
    What are you attempting to do, a repair?
    What is broken?
  10. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,441
    B.C., Canada
    The factory would use MIG as it is the most expedient process... And there's nothing wrong with using MIG as a repair too. If the machine is set correctly and you have a good operator working the gun, you can get an aluminum MIG weld to look as smooth as silk.
  11. fatbillybob
    Aug 10, 2002
    29,261
    socal
    An OEM's robot controled MIG welder is a taotally differnent animal than a freehand welder doing mig. That's why 99% of the time aluminum is done with tig in the field
  12. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    +1 with that..Cant beat the almost semless welds that Tig produces.
  13. AEman69A
    AEman69A Karting
    Jan 13, 2011
    147
    Central NJ
    Eddie
    Thanks for the info, I appreciate it.
    I guess TIG is the way to go.
  14. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    They used MIG and a combination of TIG and Gas Torch for final finish work at the body seams. I remember watching one of the body builders gas weld the top of an A pillar.
    Somewhere I have photo's I took of the bodys being welded as well as a completely paintless coupe on a chassis cart we were given for training at the factory.
  15. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Ever try a TIP-TIG? Wonder working for just about every type of welding job....
  16. AEman69A
    AEman69A Karting
    Jan 13, 2011
    147
    Central NJ
    Eddie
    Can you elaborate on the process?
  17. AEman69A
    AEman69A Karting
    Jan 13, 2011
    147
    Central NJ
    Eddie
    Very interesting, I appreciate the information.
  18. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,441
    B.C., Canada
    #19 Peter, Mar 24, 2011
    At the truck tank and trailer company I work for, we use spool guns for all of the welding on the tank shells and attachments and use TIG for the piping. At one of our competitors, they use automated MIG welding on the long seams only, the rest all by hand (spool guns and push-pulls)...
    An example of a repair job we did (trailer rolled over onto it's side. The wrinkled material had been cut away before I took these photos)...
  19. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,441
    B.C., Canada
  20. AEman69A
    AEman69A Karting
    Jan 13, 2011
    147
    Central NJ
    Eddie
    Peter, thanks for the pictures. I never knew that the inside of tankers were sectioned off as such but it makes much more sense now. And for the information regarding CK. Both CK and TIP-TIG are very interesting and advanced forms of welding. It's always great to learn knew things.
    I'm looking to source out a proficient TIG welder now in my area that can take on the job.
    Thanks for the advice thus far.
