Milky oil. Ugh! | FerrariChat
Milky oil. Ugh!
Discussion in 'Boxers/TR/M' started by Veedub00, May 23, 2020.
  1. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,900
    Troy, Michigan
    James
  2. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,900
    Troy, Michigan
    James
    Never saw white smoke. No oil in the water. Oil reservoir was a overfilled. I have been adding coolant recently.
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,931
    romano schwabel
    good sign, so I think no headgasket
    also good sign, so again no headgasket because the oilpressure is higher than the water pressure
    bad sign, water is going into the oil
    also bad sign that water is going away into the oil because of overfilled oil reservoir
    I would say leaking water pump - or somewhere a crack in the block or in the heads:(
  4. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,900
    Troy, Michigan
    James
    Qavion likes this.
  5. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,900
    Troy, Michigan
    James
  6. turbo-joe
    Apr 6, 2008
    8,931
    romano schwabel
    good to see this damaged seal. so you may be sure 99 % that the water was coming from this seal into the oil. so no worry about more
    1 or 2 piece seal? I would take what you have and will match
  7. clinton
    clinton Rookie
    Feb 16, 2013
    39
    Houston
    It looks like you have a bad water pump problem.
    Did you check the bearing behind the oil seal? Looking at the oil seal, water has been seeping into places it's not supposed to be. I would assume the bearing behind the oil seal is bad.
    Unless the water pump is assembled correctly, water will seep into the wrong areas, destroying the oil seal, bearing and into the crankcase.
    Sent from my SM-G950U using Tapatalk
  8. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,900
    Troy, Michigan
    James
    how do I check the bearing?
  9. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    A leaking water pump seal dumps fluid onto the ground by way of the weep hole.
    The ONLY way anti-freeze can be forced towards the oil seal is IF the weep hole is plugged off. Check your weep hole. If it is not plugged off, the coolant is entering the oil at a different location.
    ‘IF’ the water pump seal is leaking, and ‘IF’ the weep hole is seriously plugged, and ‘IF’ the oil seal is bad, THEN the anti-freeze may get into the oil system.
    A three ‘IF’ sequence is pretty unlikely.
  10. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,900
    Troy, Michigan
    James
  11. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,900
    Troy, Michigan
    James
    can i remove that bearing through the front?
  12. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Is the weep hole plugged up with debris?
  13. clinton
    clinton Rookie
    Feb 16, 2013
    39
    Houston
    It's very difficult, is it bad?
  14. clinton
    clinton Rookie
    Feb 16, 2013
    39
    Houston
    What happened to the shaft? What does the sleeve look like?
  15. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,900
    Troy, Michigan
    James
    yeah it looked like it was. I poked a pipe cleaner through it and it took a few thrusts to get it through the top.
    turbo-joe and vincenzo like this.
  16. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,900
    Troy, Michigan
    James
    It doesn't look bad, but if I have to split the powerpack then I think I'll just leave it there.
    I think I'll try replacing the seals and pressure test the system. I pressure tested the system when I pulled the pack and it didn't hold pressure very well. Pumped to 10 psi and it didn't hold much. How much psi is the system regularly?
  17. clinton
    clinton Rookie
    Feb 16, 2013
    39
    Houston
    I think the system will go up to 16 psi or 1.1 bar.
    If the balls in the bearing are anything but shiny sliver or if you see any rust, I would change it. You still have not found the problem. What about the sleeve?
    turbo-joe likes this.
  18. MOSS
    MOSS Formula 3
    Apr 28, 2004
    1,619
    Wow, this is as bad as it gets.
  19. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,155
    Canada
    Newman
    If you split the engine from the box you can replace the inner bearing as well, probably the chain tensioner and chain because they stretch. Its not hard to take the engine off the box. Ive also seen those front engine covers leak where they meet the block.
  20. timemachine
    timemachine Karting
    Dec 8, 2009
    185
    Hartland Michigan
    John Meaney
    Hey James,
    I've got a water pump seal kit you can use if the engine number is before 20820.
    JM
  21. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,900
    Troy, Michigan
    James
    Thanks! I got one coming in the mail today. unfortunately. But who knows if the seal is the right one. Let me get back to you.
  22. Clyde Romero
    Clyde Romero Formula Junior
    Sep 6, 2019
    691
    Atlanta Georgia
    Clarence Romero
    water pump seal
    for sure
    its a TR !
