Mind of its own. | FerrariChat
Mind of its own.
Discussion in 'Australia' started by Arvin Grajau, Aug 22, 2006.
  1. Arvin Grajau
    Arvin Grajau Seven Time F1 World Champ
    Jun 7, 2006
    78,325
    Wurundjeri man.
    Arvin Grajau
    Go to start 512 hard to start battery becomes flat.Recharge try again ,turn of with idea of putting in new plugs.And wow bam,starter keeps turning over with key on off postion!Jump out open up engine hatch and wire of starter motor.Belt the **** out of starter and try again still does it.Take starter and relay of,down to auto elect all seems ok,put back on and still does it!What is it ?Have a go and then will give answer as its something all the OHOS could do.
  2. AndrewWA
    AndrewWA Formula Junior
    Oct 14, 2005
    985
    Chiswick, London
    Andrew Stevens
    I had a problem with an Alfa like that, but from memory it was the starter solenoid that basically 'stuck on' and once it was whacked (finely adjusted :)) it unstuck and didn't do it again. You said you had the starter off altogether though, so I wouldn't expect that to be the problem. You haven't got an electrical short somewhere in the main battery lead or anything like that have you?
  3. IanB
    IanB F1 World Champ
    Jun 15, 2006
    16,225
    Change your ignition switch.
    Also recommend fitting a Tildon reduction gear starter (put the original starter on the shelf for concours duty) for less weight (6Kg) faster cranking and easier starting. You find them on ebay, just search "ferrari starter".
  4. Arvin Grajau
    Jun 7, 2006
    78,325
    Wurundjeri man.
    Arvin Grajau
    Yep I was happy lad when it was not the ignition switch ie hot wire and Yes it was the battery and solinoid wires bonded togeither to cause a earth.
  5. IanB
    IanB F1 World Champ
    Jun 15, 2006
    16,225
    Well done, its often the simple things that we overlook.
    Bet you're now regretting the "Belt the **** out of starter" strategy! Can you buff the hammer marks out...!
  6. AndrewWA
    Oct 14, 2005
    985
    Chiswick, London
    Andrew Stevens
    I had an 'interesting' underbonnet fire once in my Alfa when the main battery lead which runs under the crossmember to the starter chafed through after many years of rubbing, sight unseen on a steering tie rod and the first sign of it was the firewall grommet started smoking where the choke cable passed through it. The choke cable had become like a hot wire...Fortunately I was just turning into a carpark and wondered why I could smell burning rubber. Was glad to have an extinguisher in the car and wouldn't be without one now. Was VERY glad that I didn't have any big fuel leaks from the webers either...
  7. waz356
    waz356 F1 Rookie
    Dec 5, 2005
    3,710
    Adelaide
    warren
    i had a similar issue with the Morgan a couple of years ago. The airfilter came off the carbie on the Bay to Birdwood run and when i stopped to fill the car up, i flooded the carb and it caught fire. Nothing major, except i was in a service station. The good thing was the servo had a fire extinguisher, which i didn't. The bad thing was the attendant emptied the whole thing onto the car and called the fire brigade. It could have been fixed with a fire blanket. The moggie never leaves home without an extinguisher these days.
    edit: pleased to hear you got the 512 sorted Rob.
  8. kerrari
    kerrari Two Time F1 World Champ
    Oct 22, 2004
    24,033
    Coolum Beach AUSTRALIA
    Karen H.
    Most bizarre breakdown I've ever had was tool bag in the 500 somehow got dislodged and landed with the shifter that was in the bag neatly across the battery terminals - fortunately just cooked some (most!) wiring and was found before a fire started.
  9. j15
    j15 F1 Rookie
    Jan 5, 2005
    2,624
    Sydney Australia
    Jeh
    my car copped a flat battery today, its stranded in the school car park
  10. goober
    goober F1 World Champ
    Nov 15, 2004
    15,895
    Adelaide & Thredbo
    Buddy Miles
    holler a marshall
  11. Arvin Grajau
    Jun 7, 2006
    78,325
    Wurundjeri man.
    Arvin Grajau
    Hi Ian,it was a light tap.Those torque start motors are great had em on the 2x racing mustangs,also have one on the old Aston sounds like a air starter of a Mack truck,gets more looks then the car.
