minimum ceiling height for engine removal 308 | FerrariChat
Discussion in 'Technical Q&A' started by Martin308GTB, Nov 18, 2007.
  1. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,252
    Black Forest Germany
    Martin N.
    Hello from Germany,
    I'm planning some alterations of my garage. Is it possible to remove a 308 engine with a chain hoist on a girder instead of an engine crane ? I have a lot of floor space, so moving the car wouldn't be too tricky. But I only have a ceiling height of 8.8 ft.
    What is the minimum required ceiling height for removal of the 308 engine ?
    I would be happy, if those of you who have already removed an engine could tell me some details about this.
    Best Regards and thank you in advance
    Martin
  2. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    It has been a few years since I removed mine, but I had to wheel the car out side to get the motor out. The boom height was too high for me. I had to hoist the motor all of the way up, sit on the back bumper of the car and push it forward. However, I could have had too much slack in the hoist straps I was using.
  3. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Martin,
    A chain hoist can be used, but you'll have to do the following calculations to see if you can do it in 8.8'. My suspicion is it's going to be very tight.
    Measure the engine compartment from the back edge of the drip groove behind the rear window to the front edge of the luggage compartment bulkhead. That's very close to the length of the engine from highest point to bottom when rotated into lifting position.
    Add the above measurement to the height of the top of the luggage compartment above the floor,
    + about 3" for the suspension to rise when the engine's weight is removed
    + about 2.5 feet for straps, engine tilter, etc.
    + height of hoist & it's mounting.
    Has to be less than 8.8 feet. I'd like to see about 1' to spare.
  4. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    I took some measurements and I seriously doubt you can pull the engine with a chain hoist and only 8.8' clearance. I have 8'3" ceilings. Using a moveable engine hoist, engine leveler, and removing the rear wheels to lower the car to where the rotors are almost on the ground, I have just enough clearance to get the engine over the trunk and out of the car. In your case, at the very least, you will need to remove the rear wheels and lower the car down onto a dolly so that you can move the car and still have the necessary clearances.
  5. fatbillybob
    Aug 10, 2002
    28,609
    socal
    In america if you don't have one you can just rent a cherry picker aka engine hoist. The advantage to this over chain hoist is you can move it around easy and 8ft ceiling is fine. Scrap the load lever just wrap climbing rope around the front head and pull/tilt it out.
  6. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Alternatively, If you use a pair of ratchet type nylon straps (get the wide yellow ones that Home Depot sells), you can use the ratchet to rotate the engine.
  7. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Paul (pad) and I have pulled the engine on his '83 QV a couple of times and we did my '78 308 in his garage last winter. With the portable engine hoist, it's a piece of cake, and you've got 5" more clearance than we did at Paul's place. IMHO, you are better off with an engine hoist than a chain hoist in fixed position. With the chain hoist, you are going to need to move the car out of the way to lower the engine, and you'll have to shift the car around some putting the engine back in. It's easier to move the hoist around than the car. Just a thought.
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,592
    The twilight zone
    The Butcher
    In my basement I’ve got 9’, but it's 8' the AC ducts so I knew right where that is and the engine crane didn't get that high the last time I did mine, close though. I choked up on the chain on the puller and I didn’t use a load leveler (mostly because I don’t have one). I kind of knew what angle the engine had to roll to come out so I just set the chains the crane was hooked to that way.
  9. Martin308GTB
    Jan 22, 2003
    4,252
    Martin N.
    thanks a lot for your valuable hints. You guys are REALLY of great help. I think I will eventually purchase a movable engine hoist, because I have more cars which will require engine removal sooner or later.
    One additional question about the dimensions of the hoist. Because the mid engine layout of the 308; how much is the required length of the crane arm ? I have seen cranes with enough load capacity, but an arm too short.
    Most manufacturers specify the over all arm length, but not the more interesting dimension from the vertical cylinder to the middle of the hook.
    There are also foldable 1 ton cranes with a capacity of 700 kgs with the arm fully extended. What do you think of these ? Those would save me a lot of floor space.
    Best Regards from Germany
    Martin
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,592
    The twilight zone
    The Butcher
    #10 mk e, Nov 19, 2007
    That's what I have and it just makes it....even with the v12 I'm trying to stuff in :)
  11. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    #11 pad, Nov 19, 2007
    I have a folding crane and it works fine. You need about 47" from the ram connection on the arm to the hook. Also note to lift the engine out of the car, the engine will need to be angled front head up. Then, to clear the trunk as you move the engine crane backwards, you will need to level the engine since you only have about 8' ceiling clearance. The engine leveler makes this much easier.
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    BTW, notice that PAD's engine leveler is about 3' long. A 18"-20" leveler (the common sizes) won't tilt the engine enough(been there!).
    There's a different type leveler that cranks a length of chain thru a hub. I think it may be the best type I've ever used. That's what we used to lift Chris's engine. Will try to get the brand name & model.
  13. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,399
    San Carlos, CA
    Mitchell Le
    I pushed my car outside and used a crane to lift the engine in and out, with a 20 inch leveler. My crane arm was a tad short and the bumper had to come off the GT4 to push the crane in a little bit more.
  14. Martin308GTB
    Jan 22, 2003
    4,252
    Martin N.
    Hello again,
    this is a great thread for me. Thanks a lot so far.
    pad; I have found a crane which seems to fit my needs. But one question I still have. What is the minimum required height of the hook ? Or how high is the hook on that picture ? I understand, that you had to lower the car with the wheels off. When the brake rotors almost touch the floor. Is there still enough room for the crane to move below the car ?
    How high are the 'legs' ? Those of that crane I'm supposed to buy are 80 mm ( 3.15" ) high.
    Verell; I cannot find a leveler over here with that required length of 3'.
    Martin
  15. eurogt4
    eurogt4 Karting
    Apr 15, 2006
    243
    Sacramento, CA
    I think Moss Motors sells a leveler that uses a cable or chain that is cranked around a drum - might work
