minimum Octane | FerrariChat
minimum Octane
Discussion in 'Technical Q&A' started by GiorgioP, Mar 16, 2015.
  1. GiorgioP
    GiorgioP Rookie
    Mar 16, 2015
    2
    Hi,
    I am looking to buy a 458 but here in Ireland I can only find 95 octance fuel, other eu countries like Italy have 98 premium fuel, is this sufficient for the 458 engine and will it damage it on the long run? tks for the advise
    Giorgio
  2. El Wayne
    El Wayne F1 World Champ
    Staff Member Lifetime Rossa Owner
    Aug 1, 2002
    18,069
    San Marino, CA
    L. Wayne Ausbrooks
    #2 El Wayne, Mar 16, 2015
  3. Jumprun
    Jumprun Karting
    Feb 7, 2012
    227
    Southern California
    T. Martinez
    using a lower than recommended octane in a modern ECU controlled car with knock sensors will not damage the engine because the computer will retard the timing to prevent knock or premature detonation. Power and efficiency may/will suffer, but no damage should occur.
    This idea that lower octane can damage an engine is a throwback to pre-knock sensor engine control, in those days a very high compression engine using the cheap stuff would "ping" badly and could do severe damage to the pistons. Even today when rebuilding an old engine you have to be careful with the compression ratio because the panther piss we call gasoline today is doubtful.
  4. GiorgioP
    GiorgioP Rookie
    Mar 16, 2015
    2
    Good stuff and Jumprun tks for the additional explanation I guess I am still stock with old school knowledge where you could work on an engine without a computer....Cheers
    Giorgio
