355 - Minor cosmetic modifications chrome heat shield | FerrariChat
355 Minor cosmetic modifications chrome heat shield
Discussion in '348/355' started by ruey220, Oct 16, 2019.
  1. ruey220
    ruey220 Formula Junior
    315
    Sf bay area
    RM
    Ga68_ likes this.
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  3. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    Yea I had the same idea for mine a good few years back. However mine is the complete heat shield in Polished aluminium.
    It does look great through the grill doesn't it :)
  4. ruey220
    315
    Sf bay area
    RM
    How were you able to do the whole heat shield complete?
  5. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    Was not to difficult, it was fabricated for me in an engineers workshop.
    As well as looking great through the grill, it looks great from inside the engine bay under the air boxs.
  6. Qavion
    Qavion F1 World Champ
    14,260
    Ian Riddell
    Isn't the point of the standard heat shield to stop the air boxes getting hot? Or did you put some reflective insulation on the bottom of the air boxes?
  7. ruey220
    315
    Sf bay area
    RM
    The shield I got is a heat shield for Truck exhaust stacks, so it serves the same purpose. I also left the original one below, so it is double insulation.
    I also have on order BMC OTA carbon enclosed air filters that I am going to be replacing the airboxes with, to help eliminate heak soak which the airboxes do as well, since the factory ones are metal. It should increase flow and keep intake temps lower. I recall that every 10 deg in temperature is almost 1hp.
    Qavion likes this.
  8. Qavion
    14,260
    Ian Riddell
    Ah, my mistake.. I thought the shiny bit was your muffler and that you'd removed the old heat shield.
  9. ruey220
    315
    Sf bay area
    RM
    Oh no problem. But that was the purpose to look like the exhaust since on this model you can't see it. On the 360 and 430 you can see the exhaust.
    Qavion likes this.
