Missfiring and skipping, HELP | FerrariChat
Discussion in '308/328' started by jajo1971, Jul 25, 2009.
  1. jajo1971
    jajo1971 Rookie
    Jul 25, 2009
    2
    Hello, i own a 1982 Ferrari Mondial 8. I replaced my spark plugs, spark plug wires, Distributor caps, rotors and the coils. I replaced the fuel pump too. And my car is still missfiring and skipping? When i start my car it doesnt missfire or skip but as soon as it goes on idle it is missfiring and skipping? Anybody got an idea? I would really appreciate some ideas what it could be.....Thank you
  2. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,425
    E ' ' '/ F
    Enzo Gorlomi
    Do you -know- it's electrical? Use an induction timing light to test the spark at each plug wire.
    Have the injectors been replaced in the last 20 years?
    Just thoughts...
  3. FamilyCar
    FamilyCar Formula Junior
    790
    Seattle, Wa
    Peter Goodall
    Was it doing this before you did the work?
    I am in about the same situation, except I didn't replace the coils or fuel pump. The best I've come up with is that the timing is way off, although I don't know what I could have done that would have affected it, unless it was jiggling a wire to a sensor somewhere. I'll be watching this post.
  4. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    And this is tried and proven solid advice....
  5. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    crank sensors
  6. DenisB
    DenisB Formula Junior
    Jul 21, 2007
    511
    Cape Cod Ma.
    Denis B.
    #6 DenisB, Jul 27, 2009
    I had the same situation and i replaced the spark plugs and extenders. Now no more problem ,give it a try. my Mond.8 is now running sooth as silk an' lovin' it. Bought'm at superperformance so far so good. Good luck
    By the way fill out your profile :)
  7. jajo1971
    jajo1971 Rookie
    Jul 25, 2009
    2
    Hello again, i just put new extenders on and my car is still missfiring. I took her out today, she started to missfire about after 5 miles, before she was running fine. I really dont know what to do anymore. I guess next thing I have look into are the fuel injectors. But maybe it is something simple. Any suggestions? Thank you
