Missing fuse near ABS | FerrariChat
Discussion in '308/328' started by nikojo, May 5, 2013.
  1. nikojo
    nikojo Karting
    Apr 18, 2008
    58
    Midwest
    #1 nikojo, May 5, 2013
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,326
    That's correct if I recall.
  3. nikojo
    nikojo Karting
    Apr 18, 2008
    58
    Midwest
    Correct to NOT have fuse?
  4. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,326
    Yep.
  5. Carbuilder
    Carbuilder Formula Junior
    Aug 18, 2012
    550
    Bolton, ON
    Rick
    Apparently you put a fuse in there to complete the circuit to read trouble codes, otherwise it shouldn't have a fuse.
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,605
    San Carlos, CA
    Mitchell Le
    That is right. You put a fuse in that location and your ABS stops working on the drive.
  7. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Wow. These cars never cease to amaze.
  8. nikojo
    nikojo Karting
    Apr 18, 2008
    58
    Midwest
    Is that the purpose?? To turn the ABS off?
  9. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    No, its to enable diagnostic mode. Any stored fault code is displayed by flashing the ABS warning light in a sequence which makes up 4 digits.
    The codes can be found in service manuals for the Teves MKII ABS such as here:
    http://www.vwclub.bg/uploaded/manual/ABS/ABS_MKII.pdf
  10. Erik Johnson
    Erik Johnson Karting
    Sep 12, 2012
    66
    Boulder, CO
    Erik Johnson
    A fuse that disables the ABS, I wish every car came with this feature.
    Erik
  11. ethan hunt
    ethan hunt Rookie
    Dec 7, 2014
    10
    Good morning,
    i'm from Italy and i have a problem with the brakes of my GTS turbo intercooler ABS.
    I have to bring the car in a official Ferrari center, but is' very far from my home.
    The ABS and brake lights are ALWAYS on and the brake pedal it'very heavy and (almost) without motion..it's seems stuck. I read the thread and i have a question.
    Can I insert a fuse to solve temporarily the problem ? In this way i can bring the car to the Ferrari center for the repair..or not ?
    Thank for your help.
    Luigi
  12. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,228
    Gold Coast, Aust.
    Patrick
    Stick one in and see if anything changes
  13. Motob
    Motob Formula 3
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
    Inserting the fuse just puts the ABS ECU into diagnostic mode, it does not fix issues with the system. If your brake pedal is hard with no assist, it sounds like the accumulator is not charging. You have a problem with the braking system that needs further diagnosis.
  14. ethan hunt
    ethan hunt Rookie
    Dec 7, 2014
    10
    I have the problem to move the car to the Ferrari garage..
  15. Motob
    Motob Formula 3
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
    It is called a tow truck or a trailer.
