Hi, Can anyone help identify what should be plugging this hole under the spare wheel in my '87 328? And if you do, where the heck to find it? Thanks, Image Unavailable, Please Login
I don't drive my 308 in the rain. I put a plug in mine. I believe it is allowing a lot of hot air entering the cab. I also plugged the 2 holes above that. Then I used black silicone and filled the holes where the control cables and brake lines come in. When using a very bright light at night with the light in the spare tire area with the hood closed I could see light under the dash. I also used compressed air to find air leaks into the cab.I put new foam around the battery cover. It did help. I still have to address air coming in around my gas pedal.
