Mistral door hinge | FerrariChat
Mistral door hinge
Discussion in 'Maserati' started by Ursa Major, May 23, 2014.
  1. Ursa Major
    Ursa Major Karting
    Feb 25, 2011
    162
    Norway
    Hi all,
    We are experiencing problems with deattaching the doors on my Mistral. It seems the hinges have been both attached with screws and then welded. The door pins are a pain in the a$$, as there is no room to beat them out.
    Any ideas?
    Sent from my HTC One using Tapatalk
  2. eogorman
    eogorman Formula Junior
    May 10, 2005
    337
    Buhl, ID
    Eugene O'Gorman
    Eastwood make some special tools for door hinge pin removal. One looks like a c clamp with a bolt in one end and a hole in the other to push the pin thru. THe other is an offset punch that allows you to use a hammer to break it loose. Heat always helps as they are usually seized by rust
  3. Ursa Major
    Ursa Major Karting
    Feb 25, 2011
    162
    Norway
    Thanks Gene!
    Tried to heat them up, and they were glowing red, but still no luck.
    Somehow they will come off!
  4. GLB
    GLB Formula Junior
    Oct 27, 2010
    311
    Dallas, TX
    George Lawrence Brantingham
    A veteran machinist taught us a trick - heat up the joint, then remove heat and apply a stick of paraffin wax to the junction of the parts. The wax wicks into the joint. It has worked quite a few times for us on parts that had absolutely refused to budge using other methods.
