Miura Fire | FerrariChat
Miura Fire
Discussion in 'LamborghiniChat.com' started by Napolis, Apr 23, 2012.
  1. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #1 Napolis, Apr 23, 2012
    Several things to think about. Fire Suppression system are very important in all cars. Miura's have a design issue that owners should be aware of. The Carbs are positioned in a way that the gaskets tend to dry out when the car is not used regulary. If they leak they leak right on to the exhaust headers and fires aren't surprising. Many classic cars that are not used regulary suffer from carbs leaking. You really have to check this out often and pre flight a classic car before setting off after a period of non use.
    Joe was this one once owned by Gary? If so I drove it and a friend almost bought it for 20K
    in the 70ies.
  2. Peter K.
    Peter K. F1 Rookie
    4,448
    Connecticut
    Peter K.
    I've always been curious, is there a fix? Different gaskets or something sheilding the exhaust? Or just replace as regular maintinance and drive often?
  3. silver1331
    silver1331 Formula Junior
    521
    shame...beautiful looking miura. that color is fantastic!
  4. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    I'm not sure. With a bit of re engineering you could but that's a slippery slope original wise.
    That said the trick is to check it and use it regularly.
    Webbers that aren't used aren't happy especially side drafts.
  5. garybobileff
    garybobileff Formula 3
    Sponsor
    Feb 5, 2004
    1,180
    San Diego CA
    Gary
    The carbs do not drip on the headers, but drip on the spark plugs and wire connections that sit just below the carbs. I have modified dozens of Miura's, over the years, to prevent fires, and have been totally successful ( to my knowledge) and installed the Halon suppression systems as well, just in case. A very necessary item, on all Miura's, in my opinion.
    Gary Bobileff
  6. staatsof
    95,949
    Fuggetaboutitland
    Bob
    What an awful photo ... :(
    And if you don't carry a decent sized halon extinguisher you'll be very, very sorry one day.
    I carry a 5lb one and had to use it once. Fortunately it wasn't a gasoline fire.
  7. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Jim, carburetors mounted directly above spark plug ports is the stuff of genius :)
    What were they thinking? Gasoline + spark = fire!!
    Anyway, in all my time behind the wheel of 5 different Miuras I owned I never had a fire, BUT, I did check the carbs before driving. Regular exercise is indeed the other key.
  8. TheMayor
    106,110
    Vegas baby
    This is terribly sad.
    But, I can't tell you how many people think that classic cars are just like modern cars only "older".
    Clearly, they are not.
    I'm sure this car will be repaired and I agree with Napolis that fire extinguisher suppression systems should be installed on classics like this.
  9. xs10shl
    xs10shl Formula 3
    Dec 17, 2003
    2,037
    San Francisco
    Carburetors are mounted in precarious positions in most cars, Wasn't it more an issue with the particular carburetor, and not the design?
    Correct me if I'm wrong, but I think its fixable by switching to a different carburetor (and adding a pressure regulator under all circumstances). Some aspiring Porsche aftermarket providers have also created an EFI triple-barrel, which I've been tempted to experiment with.
  10. garybobileff
    Sponsor
    Feb 5, 2004
    1,180
    San Diego CA
    Gary
    The Carbs are fine, it's a system design problem. There are a number of system modifications done to remove the problem areas. Fuel injection is a cure to this problem, but injection has trouble maintaining the value of the car when installed!
    Gary Bobileff
  11. ralfabco
    ralfabco Two Time F1 World Champ
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    It is a good idea, to install a fire suppression system.
  12. ClassicFerrari
    ClassicFerrari F1 World Champ
    Jan 7, 2004
    16,798
    Toronto
    Vasco
    Anyone know what happened to the car?
    So sad to see...
  13. xs10shl
    xs10shl Formula 3
    Dec 17, 2003
    2,037
    San Francisco
    Good to know- I keep bringing up the EFI once every few years in the hope of convincing someone else to give it a try, LOL. Perhaps I'll have to bite the bullet and try it myself.
  14. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    Gary B didn't you have one that someone had installed injectors on and reverted it back to carb?
  15. Night life
    Night life F1 Veteran
    7,287
    The city that rhymes with fun in Canada
    Roberto
    That made me sick to my stomach :(
  16. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    That photo is painful to watch.
    If such things can be prevented from happening by mounting FI, I'd say it's a lot better to take a little punnishment on the resale value, rather than not having a car to sell at all.
  17. Albert-LP
    Albert-LP F1 Veteran
    8,169
    around Modena, Italy
    Alberto Mantovani
    terrible picture: what a disaster.
  18. staatsof
    95,949
    Fuggetaboutitland
    Bob
    Japan?
  19. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    You could easily do it in a way that could be changed back if anyone wanted to without damage.
  20. Albert-LP
    8,169
    Alberto Mantovani
    Jim's words are full of wisdom, but i think is enough to check carbs and fuel lines every week before and after you start the engine, even if Miura was not a flawnless car at all.
  21. Jota 5084
    Jota 5084 Formula 3
    May 18, 2006
    1,922
    Sweden
    Eric Andersson
    Yes, it's the 3rd or 4th time this pic popped up here.
