Mixed Size Tires
Discussion in 'Technical Q&A' started by sjmst, Apr 2, 2004.
  1. sjmst
    sjmst F1 Veteran
    Jul 31, 2003
    9,853
    Long Island, NY
    Sam
    I am buying new 16" wheels for my 82 Mondial. It now has the same size all around, but the new Mondial wheels are 8jx16 rear and 7jx16 front.
    The specs for the Mondials with 16" wheels is 205/55vr 16 front and
    225/55vr16 rear. That comes out as almost the same exact overall diameter for the rear as my current metric wheels and tires. For the front though, it seems very small. I am concerned it won't fill the wheel well.
    Questions:
    Can the same tire as rear be put on front (smaller) wheel?
    Would it look akward?
    Sam
  3. Ed P.
    Ed P. Formula 3
    Dec 28, 2002
    2,177
    Long Island
    No Longer
    Sam, The sizes you mentioned are the same as are on my car, which you have seen....
  4. sjmst
    sjmst F1 Veteran
    Jul 31, 2003
    9,853
    Long Island, NY
    Sam
    OK. Didn't even notice that they had mixed, just that it looks good.
  5. Dom
    Dom F1 Veteran
    8,347
    Southern California
    Dom V.
    Hi Sam,
    Yes, the wheels are 7" in the front and 8" in the rear. The stock sizes are 205/55-16 front and 225/50-16 rear.
    It's odd, because the stock wheel size on my GT4 was 7.5" all around. Why did they go to a slimmer front wheel in the later models?
    If you order tires from tirerack, the website lets you choose your tires based on model. Since I upgraded to 328 wheels (should be similar for the mondial), I picked 1986 328, and it came up with tire sets for me in the correct stock size.
    Dom
  6. BigTex
    76,224
    Houston, Texas
    Bubba
    It's the same with 308s as well.
    Standard was 7.5'W all around, but when wider rears were introduced they went to 7" front 8" rears.
  8. Ed P.
    Ed P. Formula 3
    Dec 28, 2002
    2,177
    Long Island
    No Longer
    Sam, With the sizes you mention, it would make the front tire diameter 24.8" and the rear 25.8". Keep in mind that my car has ABS so it is a little different. But I guess you worked out the spacer issue already....
  9. pogibm
    pogibm Karting
    Nov 2, 2003
    103
    Washington
    Randy Madamba
    Sam if your car came with metric tires like mine did (the 240 metric) for your rears 222/55 or 245/50 are the same diameter as the metric 240's
    fronts i'll go with 215/55 same diameter as the rear but narrower 205/55 on early mondials are to small your wheel gap will be 6-7 inches from the fender.
  10. Dom
    Dom F1 Veteran
    8,347
    Southern California
    Dom V.
  11. sjmst
    sjmst F1 Veteran
    Jul 31, 2003
    9,853
    Long Island, NY
    Sam
    That gap issue is what I was concerend about. I checked with Tire Rack. They said 225/55 16's would fit on all the wheels. I think that might work for my car; 225's all around, which keeps in character for that year Mondial.
    Ed, I had heard that the 16's were straight bolt on. Hope that's true.
