Mixed Thoughts About Resuming Training in a C172... | FerrariChat
Discussion in 'Aviation Chat' started by ghost, Aug 21, 2006.
  1. ghost
    ghost F1 World Champ
    Dec 10, 2003
    10,046
    Singapore
    What's up Gents.
    Excited about resuming private pilot training in New Jersey, but have somewhat mixed feelings about doing so in a C172. Started my private pilot lessons out of 06C in Schaumburg, IL. FBO was Northwest Flyers ("NWF"), which is a great operation. Started my training there with Piper Warrior II's. Chose the Warriors because (i) NWF had more of them vis-a-vis the Cessna's, and (ii) preferred a low-wing to a high-wing. Had a whale of a time during the Summer of 2003, accumulating about 40 hours before I head to head out to New York. Kept promising myself I would continue flying once I relocated but work and other obligations took up most of the time. Add to that the logistical hassles of getting out of New York to the nearest FBO, and it's been over three years since I last flew recreationally. (As a side note Teterboro - which was the closest airport to NYC - no longer allows private pilot training due to the increased private jet traffic).
    Am planning on resuming my training at Essex County Airport with Air Fleet Training, Inc ("AFT"). AFT seems like a quality shop. The only fly in the proverbial ointment is AFT has 12 Cessna's and 2 Warriors. Have taken a couple of quasi-training flights to check the Cessna's out. Initial impressions of the Cessna's are that they seem easier to fly, but also more twitchy. Hate the fact that I can't see my 3's and 9's when make turns, but love the fact that I can continue to orient myself with the centerline when touching down. Bottom line is that feelings are somewhat mixed. All things being equal, at this point I'm still biased towards the low-wing Warriors.
    More Cessna's at the flight school means more availability for training. Additionally, I begrudgingly acknowledge that Cessna's are much more prevalent around the US than Warrior's, so if I switch I will likely always have a plane to rent...but what can I say: there remains a nostalgia for the Warriors.
    What are your views? Anybody have views about training on low-wing versus high-wing? Cessna's versus Warriors?
    Will likely switch for the reasons mentioned above, but keen to hear your thoughts.
    Best.
  2. SWITCHESOFF
    SWITCHESOFF Formula Junior
    Nov 9, 2005
    582
    Ghost, I'm not an expert on training psychology but if you can get training at a reasonable price and location, do it. There are pluses and minuses in high wing and low wing airplanes. The important thing is that you recognize it and modify your awareness while flying either one. I was lucky enough to fly both high and low wing when I was learning and I realize that the traffic situation is different than it was 60 years ago but not so different that one has to be less or more vigilant. Get your training and learn to adjust.
    Good luck.
    Switches
  3. ghost
    Dec 10, 2003
    10,046
    Singapore
    Good advice Bob. Thanks.
  4. planeflyr
    planeflyr Karting
    May 27, 2006
    174
    Ghost,
    Congratulations on resuming your flight training.
    As far as whether a 172 or a Warrior is the better training aircraft, the short answer is both are just as good as training and rental aircraft. Certainly for the early stages and for east coast flying. It really all boils down to preference and cost.
    I'll add my perspective of some of the points each has to offer and some of my thoughts on the deficiencies of these airplanes.
    The most visable characteristic is the visability and this is where i think the 172 has the advantage. The issue of blanking downward visability in a turn vs. the added downward visability in a turn of the Warrior is simply a matter of preference and not of training. I pick the 172 in this regard because of the larger windscreen in both the vertical as well as the horizontal directions along with the rear window for an occasional peek over the shoulder.
    I have found that the Warrior (along with it's sibling the Archer) being a low wing airplane and having less wing area than the 172 (and it's stablemate the 182) tends to be more of a stable aircraft in flight due to its higher wing loading. The result of this is a less fatiguing flight particularly in turbulence. It also makes for firmer landing and ground stability as the wing unloads more quickly. Float is about the same where the piper has a more pronounced ground effect due to the wing's proximity to the ground but the larger wing area of the cessna will cause the same effect with the wing higher off the ground.
    I mentioned stability. Since the 172 has a longer arm from it's CG to the runner, it tends to yaw more than the shorter coupled Warrior. This makes it more fatiguing as I mentioned and may be a bit more uncomfortable to the rear seat passengers who are further behind the CG than in the piper. The advantage is that it teaches good rudder technique so as not to undercontrol or overcontrol. The Warrior requires far less rudder to center the ball and a student may not develop good rudder technique as a result.
    On landing, Cessnas usually have a pronounced nosewheel shimmy as a consequence of their design which is annoying and tends to wear the nosewheel tire. Also because it's CG is higher vertically it will rock back and forth after landing. The Warrior usually has no nosewheel shimmy (unless something is really wrong with the nosewheel rigging) and because of the lower vertical CG is very solid on the ground.
    In pitch, it is interesting to note that 172's sue a horizontak stabilizer and an elevator vs. the Warrior's all flying stabilator. The stabilator approach is way more efficient.... think Grumman F-14 and Lockheed F-16!
    Fuel management is a little more involved in the Warrior as you have to manage tank selection for balance and fuel consumption and you have to learn how to use the boost pump when taking off, landing, and switching tanks. These are good skills for the student to acquire. The 172's gravity feed system makes fuel management unnecessary other than tracking overall consumption. Both aircraft have essentially the same engine so consumption should be equal. For some reason due to the design of the induction system, the 172 tends to acquire carb ice moreso than the Warrior. it is an observation I've made from my time in both aircraft. (note: I learned how to fly back on the east coast at Repulsive Airport on Long Island in the mid '70's in both a 172 and a Cherokee 140.
    Now for the mundane stuff. It is easier to sump the 172 tanks standing up vs. crawling under the wing of the Warrior... in the snow! :eek:) But it is easier to check the fuel in the piper and fuel it up at the end of your flight. No ladders or awkward strut climbing necessary. Also, unless you're a short ****, like me, sooner or later you will acquire the diamond shaped indentations in your forehead from walking into the trailing edge of the wing by forgetting to duck. (I don't seem to have that problem)
    Speed-wise I think the Warrior has the edge, but only by a couple of knots. Please correct me if I'm wrong here.
    That's it in a couple of nutshells. Have a great time training and keep all of us updated on your progress.
    Planeflyr.
  5. ghost
    Dec 10, 2003
    10,046
    Singapore
    Corey, thanks for your very detailed reply. I appreciate it immensely. You've clearly had the benefit of flight time in both planes and provide a very relevant perspective.
    My Dispatcher at the FBO (who was previously a flight instructor with thousands of hours under her belt) noted the same: for student pilots, both the Warriors and the Cessnas are satisfactory trainers. However, at the margin, the Cessna makes you a better pilot given that it is a little more skittish to land (requiring more pilot focus), requires a little more rudder control, and is a bit more involved to fly.
    I think I'm going to take the plunge into the world of Cessna's...even though I will always have a fondness for the Warriors.
    Wish me luck! - :D
  6. Dr C
    Dr C Formula Junior
    Dec 1, 2002
    480
    Kansas City
    Ed
    Vik:
    I did my primary training in a highwing Cessna 152, transitioned to a rental Piper Warrior and now own a Piper Archer (with IFR avionics). I think both planes have their good points. The one point I would make is pick either the Cessna or the Piper and stick with it. No need to switch back and forth.
  7. ylshih
    ylshih Shogun Assassin
    Honorary Owner
    Mar 21, 2004
    20,274
    Northern CA
    Yin
    Vik -
    I had a similar situation when I was going through my training phase. The flight school had a bunch of C152/C172's versus just 2 Pipers. I also preferred the Piper look/configuration and ended up sticking with that rather than the Cessna's. In my particular case, the availability of the Pipers was not a big factor as the flight school allowed booking of the planes several weeks in advance and the planes were well-maintained with very little downtime. It's even arguable that most people went with the Cessnas so there was proportionately better availability of the Pipers. I'd ask the flight school to take a look at the booking log just to get a feel for availability and that might sway you one way or the other.
    Beyond the availability, I don't know if I would put a lot of weight on the one versus the other as long as you can stick with one to complete your training. You're not buying the plane so you won't be stuck with your choice after you get your PPL. You could even make the case that spending some time with the other configuration from what you would likely stay with long-term or buy would give you more experience. After training on Pipers, I spent some time getting checked out on a C182 & C210 to get my high-performance rating. That also gave me a period of continuous time in the Cessnas, enough that I felt that I could make some choices between a high and low wing when I got around to buying a plane. As it turned out, that was useful experience as when I went to get my instrument rating, my plane (a Mooney) had some engine downtime just before my check flight and I ended up doing my check flight in a C172 and it felt very comfortable.
  8. ghost
    Dec 10, 2003
    10,046
    Singapore
    Thanks for everybody's thoughts. Can't go for training for the next week or two until I get TSA approval given how strict they have become as it relates to background checks, etc. However, once that is squared away, I do plan to take another ride in the Warriors and then make a final determination.
    Yin, I agree with you that theoretically the Warriors may be more available given the relative popularity of the Cessna's. However, two things concern me about continuing with the Warriors:
    (i) my ability to schedule training sessions are often determined only days in advance, not weeks, given the demands of my job, and
    (ii) my fiance and I want to train in parallel in the same type aircraft so that we can both fly together after we receive our respective licenses. Therefore, we will need both Warriors the flight school has to be in service everytime we would seek to fly, which is a lower probability event, given that the Warriors are frequently used for half- to full-day rentals and also b/c of unscheduled maintenance.
    Case in point: we wanted to fly the Warriors the last time we went up. Were slotted in, but then when we arrived were told that it was out for unscheduled maintenance, whilst the second one was taken out for a cross-country. Resultantly, had to hop into a 172. I'm just concerned of more incidents like this happening.
    Again, not ruling out continuing to train in the Warriors. Just concerned that if I continue (and my fiance starts) on one, that we have the appropriate availability given our uncertain schedules and the limited supply of Warriors (only 2) at this flight school.
    Whatever the decision, will make it and stick with it, as I agree switching back and forth makes no sense during your training.
    Will let you guys know how everything pans out.
    Thanks again for your thoughts.
    Best.
