Mixing 89 octane with 100 question | FerrariChat
Discussion in 'Technical Q&A' started by Alden, Nov 10, 2015.
  1. Alden
    Alden F1 Rookie
    3,717
    Central Florida
    I would like to use non-ethanol gas in my 3.2 Mondial, but the only types I can get locally are 89 octane lead free and 100 octane Sunoco "race fuel."
    Neither are cheap, but the race fuel is about $8 a gallon right now, so going 100% with that is costly and probably not necessary for my car.
    How much 100 octane could I mix with 10 gallons of 89 to get close to the 93 octane 10% ethanol I am running right now?
    I was thinking of something like 8 gallons of 89 to 2 gallons of 100 but don't have the knowledge to arrive at the proper ratio.
    Thanks for the help in advance!
    Alden
  2. JCR
    JCR F1 World Champ
    11,029
    H-Town, Tejas
  3. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    A 50/50 mix would give you 94.5 octane.
    10 gallons of 89 plus 5 gallons of 100 would give you a little more than 93 octane.
  4. Alden
    Alden F1 Rookie
    3,717
    Central Florida
  5. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    I think if you did 60% 89 RON and 40% 100 RON you're pretty close. At 2:1 you'd be slightly less and that is probably fine.
  6. Steve Magnusson
    26,932
    #6 Steve Magnusson, Nov 10, 2015
    Why are you using such a high octane-rated fuel? Have you raised the compression ratio or have a pressurized intake system?
    The Ferrari octane spec is usually given in RON units while the markings on the US fuel station pumps are in AKI units -- a 93 AKI US fuel is about a 98 RON euro fuel. On a stock US 3.2, I believe 89 AKI fuel would be fine (it's just barely under the 95 RON spec and unless you are flogging it on a hot summer day I doubt you'd have any trouble), and 91 AKI would be a little over spec.
  7. Alden
    Alden F1 Rookie
    3,717
    Central Florida
    Thanks for the response, but, "I believe it would be fine" is not an answer I am comfortable with for my Ferrari.
    I do live in Florida and "flog" on very hot summer days sometimes, lol!
    I am using 93 octane because it is usually recommended to run "premium unleaded" in our cars. Why would I want to risk any chance of detonation in my 28 year old F car?
    Alden
  8. Steve Magnusson
    26,932
    It's a free country, but not sure why you'd not consider the direct F specification as adequate - happy motoring...
  9. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    38,157
    houston/geneva
    Ross
    its linear so blending is easy.
    just make sure your car can adapt to the higher octane.
  10. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,458
    Dumpster Fire #31
    SMG
    the math is simple btw,
    ((n gallons x octane 1) + (y gallons x octane 2)) / (n+y)
    i.e.
    5 gallons of 89 + 10 gallons of 103
    (5x89)+(10x103) / (15)
    1475/15 = 98.33 octane
  11. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,458
    Dumpster Fire #31
    SMG
    In case anyone is wondering, the static CR is 9.2, dynamic CR which is what is applicable here is 8.15:1 , yeah that low. Cranking PSI is ~160. Which is one reason why these engines respond well to forced induction. Also the cylinder heads flow numbers are poor, very poor. The VE (volumetric efficiency) does not hit 100% so DCR will not match CR at any point in the RPM range. The target DCR for best power and efficiency is 8.1:1 on regular pump gas, and look at that! it's what Ferrari did. I'll skip effective CR or what the engine really runs at, but figure it's ~90% of the DCR.
  12. Alden
    Alden F1 Rookie
    3,717
    Central Florida
    Runs great on 93 now, that is where I want to end up with no ethanol.
    Perfect, exactly what I needed to know. I will run the figures to arrive at 93 using 89+100.
    Thanks!
    Alden
  13. jimpo1
    jimpo1 Two Time F1 World Champ
    Jul 30, 2001
    25,020
    Dallas, TX
    Jim E
    I think somebody already did that for you?
  14. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    #14 finnerty, Nov 11, 2015
    I would caution the OP to read the label(s) carefully on the pumps / fuel sources for whichever he decides to use. The "RON" method for octane calculation is most commonly given, at least as an alternative, on US pumps / specs. In most states, it is the primary method used.
  15. joshtownsend
    joshtownsend Formula Junior
    Jul 12, 2007
    422
    H-town...TEXAS
    Its pretty clear you don't know why your running it, you only know that someone "told" you to..When asking a question you don't know anything about, you should take the advise when give, not just the advise you are looking for.. i run 87 in mine.... why?? because i understand why and when its needed for higher octane..as does the other guy.. oh well, burn them dollars..ill save mine!!!
  16. Steve Magnusson
    26,932
    Can't agree with you here. AFAIK, it's a legal requirement to have the AKI rating shown on the pump in the US. Maybe the RON equivalent is allowed to also be shown, but it's not in the legal requirement.
  17. Alden
    Alden F1 Rookie
    3,717
    Central Florida
    #17 Alden, Nov 11, 2015
    It's pretty clear you don't know how to read.
    I asked how to mix gas to get 93 octane, not what octane gas to run in MY CAR.
    Start your own thread about what octane to run in YOUR CAR, otherwise, stop berating me and derailing my thread by inserting your opinion about a question that was never asked.
    Alden
  18. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    #18 Jeff328, Nov 12, 2015
    In the US I've never seen anything but the AKI shown on the pump. RON = Research Octane Number, which is one way of measuring gasoline octane content and is what is used around most of the world. MON = Motor Octane Number and is another way of measuring octane content. RON is typically a higher number than MON.
    AKI = (RON + MON)/2 That's why you see (R+M)/2 on the octane label on every pump in the US.
  19. JCR
    JCR F1 World Champ
    11,029
    H-Town, Tejas
    The yellow sticker and AKI calculation was by FTC regulation in the later 1970s. In the early 1970s and prior US gasoline octane was measured by RON.
  20. finnerty
    May 18, 2004
    10,406
    Ahhh.... That was the source of my confusion on the issue. Thanks for clarifying, guys..... I stand corrected.
  21. joshtownsend
    Jul 12, 2007
    422
    H-town...TEXAS
    Typical response form your kind.. never wrong , always right, never knowing anything and only accepting statement in which support your views..
  22. kevfla
    kevfla Formula 3
    Nov 20, 2003
    2,086
    gone 4 good
    #22 kevfla, Nov 12, 2015
    Alden:
    Harris Oil in Mt Dora on US HWY 441, just south of SR 46, has 93 octane non-ethanol priced at $3.219 per gallon. Open until 5 p.m. weekdays, Saturday until noon. Other option is to buy the 89 octane non-ethanol at some WaWa gas stations and then add an octane booster that you would find at most auto parts stores. Either option works out to just about the same money spent for 16 gallons.
    Now the fun time:
    Alden, you did say in your first post that the gas is for your Mondial. Most of the people responding were addressing the octane needs of a Mondial.
    Josh: ADVISE is a verb. ADVICE is a noun. They are pronounced differently: "I advise you to heed the advice Tom gave you." If English is a second language to you, I would give you a pass. However, that is likely not the case.
    Secondly, what exactly did you mean by "form [sic] your kind" in your last response to Alden? People that own a Ferrari? People with an Anglo-Saxon first name? Please elaborate, so others here can determine just what kind of a person you are.
  23. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Holy cow!
    We're usually more civil to each other in even motor oil and timing belt discussions!
    It's like an FChat P&R takeover in here!
    All this in response to a trivial problem, easily googled and understood by most persons that would have the technical basis for being anal about the precise octane number they're running in their car.......
  24. norcal2
    norcal2 F1 Veteran
    You guys are way smarter then I am! i hate to think the damage I did running Avgas through my vehicles over the years in my younger days...great data...
  25. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    "Octane booster" from the auto parts store at best raises your AKI rating by one point. Meaning 0.1 octane. It says so right on the can. Multiple cans max out at about 0.3 AKI number increase. Hot Rod magazine tested this out a few years ago. Don't waste your money. Unless you want to pay race gas prices for 89.3 AKI gas.
