Mobile OBD Scanner / Logger - iPhone / Android - 360 / 430 | Page 2 | FerrariChat
Discussion in '360/430' started by FerrariDublin, Nov 17, 2014.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    #26 whatheheck, Apr 1, 2015
    Hi Greg. I too scratched my head about the P0030 and P1135 codes so I had to do a search. I learned that P0000 are generic codes and P11XX are car maker specific codes.
    You are right, P1135 is not listed in Ferrari code sheet. My search yielded it points to precat O2 sensor. I will try Facile again and read and compare pulled fault codes as I received an eMail reply from the programmer that engine has to be running in order for Facile to read both ECUs.
    I can return the OM580 from Amazon if the fault codes pulled are not accurate. I will post updates here. Thanks!
  2. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Hi Greg,
    Finally getting a chance to chime in here again and provide update.
    For OBD Facile - Engine must be on in order to pull fault codes.
    OBD Facile pulled the same codes as the OM850. They match. Its P0030 and P1135 which points to O2 Sensor on bank 1.
    I decided to just order all 4 O2 sensors and replace them all at the same time and hope the CEL goes away. If not, I will take it to the dealer.
    It appears OBD Facile is a better OBD reader as once I finally got it working it provided more details than the OM850 code reader I bought from Amazon.
    I will soon return the OM850 back to Amazon as it doesnt work well on Ferrari's.
    Dan
  3. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    Thanks for the follow up. Hopefully the news sensors will cure it.
    As you say, even the mobile apps (versus computer based systems) offer quie a bit more than a basic code reader. Glad you've got one of the working anyway.
  4. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Hi Greg,
    Check Engine Light issue fixed. I replaced both Pre-Cat O2 sensors.
    I created a DIY write up hoping I can help the next guy and make the job easier for them when they encounter the same problem.
    My post here:
    http://www.ferrarichat.com/forum/360-430/483629-diy-how-remove-replace-oxygen-sensors.html
    All the best to you always,
    Dan
  5. margarita
    margarita Formula 3
    Mar 20, 2011
    1,618
    usa
  6. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    You're welcome Antonio.
    Dan
  7. FerrariDublin
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    Nice one Dan. Hopefully that troublesome light stays out as you put some miles on it.
  8. Skipro
    Skipro Karting
    Aug 14, 2006
    57
    Que,Can//Naples,FL
    Richard
    Nice write up Dan. Well done.
    Note: OBD Fusion is not compatible with Bluetooth, and it even states as much in the App description. I (dumb) missed that and purchased a bluetooth scanner and it would not connect. After realising my error amd obtaining a Wifi tool, ODB fusion connected first try and works works great. Thanks to everyone for their input.
  9. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks Greg and Richard!
    Dan
  10. Agent7
    Agent7 Karting
    Jan 30, 2015
    64
    Tokyo, Japan
    Just Bob
    #35 Agent7, Apr 23, 2015
  11. 67bmer
    67bmer F1 Rookie
    3,267
    MD
    car runs but chasing down the slow down light, CATs are NOT glowing red. Since it does run, I assume both engine ECUs are functionng.
    using the ELM and EOBD-Facile app, I now only see 1 ECU. In the past, I have seen two ECUs.
    I am currently seeing ECU 0X014 bank 2 cylinders 5-6 (according to aldousvoice). I am also a little surprised that my CAT ECU would be bad. It appears to have been replaced with one made in June 2014.
    Is there a way to test them?
  12. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Is your immobilizer timed out? I find I can only see one in OBD Facile if the alarm LED is blinking.
  13. Pardal
    Pardal Rookie
    Jan 23, 2022
    37
    Santa Barbara, USA & Europe
    Pardal
    Following-up on this thread that is already a few years old, I tried on my 2002 360 F1 several Bluetooth OBD2 ELM327 scanners from companies like VLink and ODBlink to use on my installed in-dash Android Head Unit specifically to run the RealDash app (really cool logging and data streaming app for those who are not too familiar with it).. see demo bellow.
    Unfortunately to varying degrees none of them work properly and they all seem to interfere with the F1 transmission giving me all sorts of errors and buzzing warning chimes. Are there any known compatibility issues with OBD2 Bluetooth adapters on the 360 F1 or has anyone had positive experience recently with a specific ELM327 scanner that plays nice with the car and without messing up with the F1 system? Thanks for the feedback :)
