430 - Mode Set Trim piece Removal | FerrariChat
430 Mode Set Trim piece Removal
Discussion in '360/430' started by [email protected], Feb 26, 2022.
  1. rbh2002@rbhlaw.com
    Sep 27, 2015
    3
    Does anybody know how to remove the “Mode-Set” plastic trim piece to lower left of steering wheel?
    Same for the glove box push button. Last two piecesI have to go in to Sticky No More. Any help much appreciated. Thanks .
  2. Minibm
    Minibm Rookie
    Dec 1, 2016
    18
    Warren, NJ
    You have to pry on the right side of trim closest to steering wheel. It should pop out and then slide out from the opening.
    Not sure about the glove box push button.
    mathewr likes this.
  3. 66ss427
    66ss427 Formula Junior
    439
    N. Myrtle Beach, SC
    Dominic
    Here’s some pictures. Correct on the plate. My picture shows what you’re prying behind the right side of that plate. It’s plastic, so go gently, and don’t use sharp tools !!!
    The switches have flat springs on two sides. They are somewhat delicate, so go gently. Top and bottom on the glove box switch. Using small dull tools, you can get to them to depress them and slide the switch out.
    Good Luck !!!
    Qavion likes this.
  4. rbh2002@rbhlaw.com
    Sep 27, 2015
    3
    Thanks guys hugely helpful appreciate the pictures and will give it a go—as soon as I work up the courage! Thanks much
