Modena F1 Transmission Issue | FerrariChat
Discussion in 'Technical Q&A' started by hrbrendan, Apr 18, 2006.
  1. hrbrendan
    hrbrendan Rookie
    Apr 18, 2006
    11
    NY
    Brendan
    I have a 2000 Modena 360 F1. When I come to a stop, occasionally the F1 transmission light (not sure what its called) starts blinking and the car will not shift gears. This goes away if I shut the car off and turn it back on. The light is not on steady, and there are no warning sounds etc. Anyone got any input on how to go about resolving this?
    -Brendan
  2. jeffdavison
    jeffdavison F1 Rookie
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    The same thing happened to Brian Willis's 360 at T.Rutlands picnic this weekend. He thought maybe the pump, but there was no leaks and the engine would start, just couldn't shift.
    He got it going again (after we pushed him out of the path of traffic). There just happened to be a tech guy at the event and it was tentitivly diagnosed as dirty micro switches on the shiffter padels and that cleaning them up would help prevent the problem from arising again. A quick fix was to rapidly play with the paddles (with the engine off).
    Haven't talk to Brian since Saturday, the day of the picnic, but after the event I followed him home just to make sure he wouldn't be stranded.
    JD
  3. Rifledriver
    37,288
    The cars warning light is trying to inform you there is a problem and it can only be resolved by bringing it to someone that is equipped to diagnose and repair it.
    Quit driving it before it stops in the middle of the road somewhere dangerous and bring it to someone to have it fixed. Turning something on and off or wiggling a wire won't do it.
  4. hrbrendan
    hrbrendan Rookie
    Apr 18, 2006
    11
    NY
    Brendan
    I figured i'd ask since the closest dealer is like 100 miles away. Not exactly a hop skip n' a jump :(
    -Brendan
  5. Rifledriver
    37,288
    It can be a real PITA but you really need to go.
  6. Dr Tommy Cosgrove
    36,596
    Birmingham, AL
    Tommy
    If not for this reason, at least do it so you won't have to push it. I helped push the one at Rutland's last Sat. There is no cool place to touch one of those things on the back right after they shut off.
  7. ferrarilou
    ferrarilou Formula Junior
    Apr 13, 2004
    513
    US
    Lou Menditto
    Check the F1 fluid level. I was getting an intermittent F1 fault till I topped it off. If that isn't the issue, then I agree with all the experts that you should bring it in. Even worse than the 'too hot to push' issue, if it gets stuck in gear there was a post quite some time ago indicating that the car can't be moved onto a flatbed without a special (dealer only) tool to force the gearbox to neutral. Scarey thought having to wait many hours just for the properly equiped tow truck. Luckily I've not had this experience directly :)
    Lou
  8. Dr Tommy Cosgrove
    36,596
    Birmingham, AL
    Tommy
    All this sounds like a good arguement to pick the 6 speed manual.
  9. ferrarilou
    Apr 13, 2004
    513
    US
    Lou Menditto
    Well, 6 speeds haven't been trouble-free either.
    Remember the sticking throughout bearings in the
    first year?
    Personally I really like the F1 in the 360. The only
    real frustration has been that the dealers keep
    wanting to reset the PIS value whenever the clutch
    gets inspected. If this was more visible without
    having to visit the closest SD-2, I think I would be
    much happier.
    Lou
  10. Rifledriver
    37,288
    Ferrari makes a good argument to drive a Toyota, except we like to drive Ferrari's.
