360 - Modena's fuel pump replacement gymnastics! | FerrariChat
360 Modena's fuel pump replacement gymnastics!
Discussion in '360/430' started by 24000rpm, Feb 13, 2019.
  1. 24000rpm
    24000rpm F1 Rookie
    What pose(s)/position(s) did you take to replace your fuel pumps?
    Naturally, I'd lean over the fender and look down, then its obviously not enough so I climb over to the top of the engine and put my full weight on the 2x intake boxes and the red intake manifold. sometimes I squat on the white aluminium frame that support the gearbox.
    I noticed that its easy to damage something in the 2nd and 3rd position I took.
    What's the correct position of doing it?
  2. vrsurgeon
    vrsurgeon F1 World Champ
    16,543
    Charleston, SC
    Curt
    I used the "upward leopard" position by leaning of the rear bumper and rearmost quarter panel when I replaced the passenger pump.
    I might hang from the ceiling in spider pose when I do the drivers side in the future.
  3. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  4. Ricambi America
    Sponsor Owner
    Like this?
    forty1, Mel Spillman and 24000rpm like this.
  5. vrsurgeon
    16,543
    Charleston, SC
    Curt
    Exactly!
    I re-use my harness that I used for hacking the Def-con and NOC list systems. :)
  6. F-Serge
    F-Serge Formula 3
    Aug 3, 2004
    1,945
    UAE
    Serge
  7. 24000rpm
    24000rpm F1 Rookie
    i replaced my RH fuel pump and almost broke my neck, i got dizziness when walking upright and nauseated when in bed.
    i should have paid somebody to do that !!!
    that's the most unwanted job i want to do on my 360!!
    RANDY6005 likes this.
  8. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    I did my r/h pump over the rear fender. Wasn't that bad, but I'm tall and bendy. Valve cover gaskets don't look as easy.
  9. 348TN
    348TN Karting
    Oct 14, 2020
    93
    Chattanooga TN
    Full Name
    Anyone know if you can assemble the pump to the mounting plate OUTSIDE of the car before putting it back in? Asking because the obviously pita part of aligning the rubber seal whilst pushing down in an awkward position would be avoided
  10. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    I did my left side pump about 3 months ago. I still have nightmares.
    I did it all from the left side of the rear quarter panel. Mostly blind and by feel. I used zip ties to tie up the spring tension a bit. I have no idea why there needs to be so much spring tension on the pump as it sits in the retaining ring at the bottom of the tank. This to me was the biggest problem; trying to hold the pump in place and securing the ring at the top of the pump to the tank with relentless spring pressure push back.
  11. 348TN
    348TN Karting
    Oct 14, 2020
    93
    Chattanooga TN
    Full Name
    did you try installing it / securing it to the mounting plate outside the car before putting it in? Just not sure the angle / room is there. Assume not otherwise folks wouldn’t be struggling so much.
  12. 348TN
    348TN Karting
    Oct 14, 2020
    93
    Chattanooga TN
    Full Name
    I just took my old one loose and put it back in because the smell from the open tank consumed my garage. Struggled at first but then I seated the gasket first into the car and it slid right into place with no problems. I’m sure I got lucky as hell and the new one when it arrives won’t go like that.
  13. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    The struggle is real and it is exhausting. I went through it for 4 days (and several Jim Beams on the rocks) -- having to just walk away and recuperate from the ordeal. IIRC it is not possible to assemble the pump first as the angle needed (in a coupe) is simply too severe to get it into position with the sending unit float and all. One time I actually succeeded getting the pump in only to find that the sender arm (left side pump) had come off. So I had to remove the pump again fish out the float arm and start over again. Of course a Spider is supposed to be easier access. The coupe... it's a crazy ordeal. The patience of Jobe is required.
    collegeboy likes this.
  14. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    Fingers crossed for you brother. Some here have said it went just fine with little or very little struggle.
  15. collegeboy
    collegeboy Formula 3
    1,372
    Texas and Kaua’i
    Mikey
    I just hover over the car. It's actually quite easy then.
  16. 348TN
    348TN Karting
    Oct 14, 2020
    93
    Chattanooga TN
    Full Name
    Hahaha heard.
    Any tips on positioning the sender arm?
  17. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    The sending arm has to be in the correct position so you have to kind of twist and feed it just right. I wish I could give more specifics but as I said it's pretty much a blind install and all "feel".
    I know some here may scoff at the idea I had that I mentioned. I used a couple of zip ties to pull a couple of the spring coils together so as not to have to be the Hulk just to get the damn pump into the round receiver at the bottom of the tank and then push it down to try and get the mounting screws in. I soaked the zip ties in premium fuel for several days and it had no effect on the zip ties so I was confident that my solution was a no risk deal. Fuel gauge works fine, reads like it should, and I don't see any problems for over 7 months now.
  18. 348TN
    348TN Karting
    Oct 14, 2020
    93
    Chattanooga TN
    Full Name
    Ohhh I didn’t quite follow the zip tie thing at first. But you’re saying you tied it and left them inside the tank?
  19. Kendall
    Kendall Rookie
    24
    Kendall Torrejos
    I placed a piece of carpet and a yoga mat on top of the engine and laid on it with my wife handing me tools from the side.
    I also considered removing the exhaust and getting in there to get closer.
    348TN likes this.
  20. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    Yup
  21. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    Careful laying on those aluminum quarter panels.
  22. 348TN
    348TN Karting
    Oct 14, 2020
    93
    Chattanooga TN
    Full Name
    Can’t imagine that’s an issue, the wires are zip tied as well on my new pump
  23. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    Exactly.
    Not only does it take tension off of the pump it also makes the pump a little shorter to allow for installing it at the severe angle that it enters the tank on a coupe.
  24. 348TN
    348TN Karting
    Oct 14, 2020
    93
    Chattanooga TN
    Full Name
    This^^
    All my parts arrived and I tackled this last night. Most I did laying on the engine. Some had to be done fender side. I didn’t tie the springs up. Reused my lock ring because the new one wouldn’t grab the thread. Not a fun job. Anyone considering I would highly suggest you consider a shop unless bloody knuckles and the smell of gas for hours as you blindly remove and replace 8mm bolts from the depths of hell is your sort of thing.
