Modern Alignment | Page 2 | FerrariChat
Modern Alignment
Discussion in '348/355' started by Ob917, Mar 18, 2025.
  1. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,956
    Richmond
    Pete
    Spring collar adjustments.
  2. Ob917
    Ob917 Formula Junior
    448
    Cardiff CA
    OB
    #27 Ob917, Mar 21, 2025
    That adjusts ride height, but preloads your sway bar. To actually corner balance you need to be able to adjust your endlinks. That fixes the preload that different spring positions can cause.
    Im suprised nobody markets a set, not that I've found anyway.
    Did the Challenge cars come with adjustable endlinks?
  3. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,956
    Richmond
    Pete
    It can still adjust corner weights, but to your point maybe not 'properly'. I believe the front swaybar on all 355's is adjustable, challenge evo cars got rear adjustable links.
    edit: Interestingly, manual steering cars did not get an adjustable front sway bar. See here:
    https://www.ricambiamerica.com/car-diagrams/ferrari/v6-v8/355-group/f355-m2-7-1995/front-suspension-wishbones.html
  4. Ob917
    448
    Cardiff CA
    OB
    Agree with you on “properly”. Still some benefit available.
    Id love to get my hands on a full set of adjustable challenge anti roll bars with links.
  5. fatbillybob
    Aug 10, 2002
    29,463
    socal
    You can make them. You only need one side to be adjustable if you are lazy. That will allow you to delete the preload and scale the car. Remember to put your weight in the drivers side, 50% fuel load and hot tire pressures.
  6. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,774
    Yes, exactly !
    Drivers weight in seat
    1/2 a tank of gasoline
    Tires at hot pressures (~40 PSI for street tires on road race tracks)
    Disconnect sway bar links while setting ride height and corner weighting.
    Set sway bar links for zero biased loading.
  7. Ob917
    448
    Cardiff CA
    OB
    Where are you guys sourcing your links from?
  8. Mitch Alsup
    Nov 4, 2003
    9,774
    Buy rod ends from aircraft supplier, and use my lathe and mill for fitment.
  9. ShineKen
    ShineKen Two Time F1 World Champ
    20,202
    Southern California
    Nostradamus
    Here’s another comparison done in 2003 on Tsukuba, which a 1 min-ish track where handling characteristics tend to shine. All were using the same Pirelli P-Zero Corsa street tires (probably all fitted at the same time for the test.)
    *They used a standard 2.7 F355 Berlinetta with lighter after-market wheels with a challenge wing. Stock brakes. Stock carbon seats.
    Comparing the 355 times to the 348 Challenge times, it tells me it is trickier to consistently clock a good time in the 348. Perhaps the 355 is indeed a lil “easier to drive.”
  10. Ob917
    448
    Cardiff CA
    OB
    bobzdar, 308 GTB and Qavion like this.
  11. Ob917
    448
    Cardiff CA
    OB
  12. ShineKen
    20,202
    Southern California
    Nostradamus
  13. Ob917
    448
    Cardiff CA
    OB
  14. Ob917
    448
    Cardiff CA
    OB
  15. ShineKen
    20,202
    Southern California
    Nostradamus
    Doesn’t say for what car. Could be a challenge car.
  16. mr.windupbird
    mr.windupbird Rookie
    27
    San Diego, CA
    Where did you get your alignment done?
  17. Ob917
    448
    Cardiff CA
    OB
    355 challenge, guess that's why it
    HG in san marcos. They did the setup on my 911, so good. Make sure its Chayse, guy is bad ass with chassis setup,damper settings and just making sure the car is as perfectly set up as possible. Cant recommend him more.
  18. Skippr1999
    Skippr1999 F1 Rookie
    4,586
    What would be the most reasonably aggressive suspension settings for a stock 355 Berlinetta.
    Do you need all the challenge or Fiano parts to use those settings listed above?
  19. mr.windupbird
    27
    San Diego, CA
    Awesome. Thanks for the recommendation.
  20. Ob917
    448
    Cardiff CA
    OB
    Its been hard for me to get accurate info on alignment settings! Lots of different info and even factory documents that are just wrong. Anyway I ended up using those settings that i shared that are 348 challenge settings, or one of the later 348 challenge car variations. But i am super happy with how the car feels, finally.
    ShineKen likes this.
  21. Ob917
    448
    Cardiff CA
    OB
    You cant get the ride height as low, but a good technician who has enough shims and skill but no other parts can get your settings there. The settings i chose throw tire wear out the window, that isnt an issue Im worried about. Also my car has nose lift. That ride height wont work on the street without nose lift.
  22. Mitch Alsup
    Nov 4, 2003
    9,774
    Good, but I wonder about the difference in caster side-to side.
  23. Ob917
    448
    Cardiff CA
    OB
    True. I need to look at those shims
  24. fatbillybob
    Aug 10, 2002
    29,463
    socal
    caster is more on right side to account for road crown. If you were racing on a road course you want those equal.
    308 GTB likes this.
  25. Ob917
    448
    Cardiff CA
    OB
    i never knew that there was a specific adjustment for road crown. Good point
