Modified 348 Front Bumper | FerrariChat
Discussion in '348/355' started by pdebe, Apr 15, 2008.
  1. pdebe
    pdebe Guest
    Apr 15, 2008
    39
  2. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
  3. pdebe
    pdebe Guest
    Apr 15, 2008
    39
    ive havent seen that before as an oem bumper
  4. ernie
    ernie Two Time F1 World Champ Lifetime Rossa Owner
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    I like the mod.
  5. pdebe
    pdebe Guest
    Apr 15, 2008
    39
    I found this picture on the forums. It appears to be a 355 front bumper on a 348. Does anyone know whats required to achieve this?
  6. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    do a search, I'm sure I saw a post about it. I think it bolts right in, but not positive.
  7. Houston348
    Houston348 Formula 3
    Oct 18, 2006
    2,297
    i wouldnt be suprised if it is as easy as just removing the other one and bolting on the 355 bumper at the same connect points as the 348 since i think all body panels on each car are interchangable, correct??
  8. tactical
    tactical Guest
    Jan 23, 2008
    857
    Is nothing on the 355 to be left sacred??;) So now that's the 355s wheels, the lower door, the bonnet air intake, the rear light conversion and now the front bumper. Have i left anything out?
    When will it stop:D When will the 348 boys just buy a 355:D Ok fuse paper lit, i will catch ya later:D
  9. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    I'm waiting for someone to go the opposite direction:) Yep - - make a 355 into a 348 with strakes, front bumper, 348 tail lights and all. Then they could honestly say their Ferrari looks like a 348 but performs like a 355 - "and I've even got an F1 tranny":)
  10. tactical
    tactical Guest
    Jan 23, 2008
    857
    You forget the 348 wheels on the 355;) Ha ha! i wonder if anyones done it?
  11. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    I know a number of 348 owners have done this, but I'm not sure what they did to keep airflow to the R/F AC condenser unit. I suppose it's been posted, but I'm curious. The nose does look great on that car!
  12. pdebe
    pdebe Guest
    Apr 15, 2008
    39
    yes this is that i was wondering! there must be some new ductwork that needs fabricated or something.
  13. TheOnlyest
    TheOnlyest Formula 3
    Sep 25, 2007
    1,686
    Las Vegas Nevada, US
    Steve
    I always wondered that myself... i've seen every post concerning this, nobody has yet explained how they're getting air to the A/C condenser.
    I honestly dont care much, just a curiousity thing. I would never change my front bumper to the 355, I like the 348 bumper WAY better than the 355... no offense to anyone of course, just MY taste.
    I would however entertain the idea of upgrading to the nifty "dual-duct" version of the 348 front bumper cover, altho I have no clue as to where to procure one... I'm totally into symmetry!
  14. Night life
    Night life F1 Veteran Silver Subscribed
    Dec 1, 2007
    7,302
    The city that rhymes with fun in Canada
    Roberto
  15. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Totally agree! I plan to keep my car stock-looking, including the black top and valences. Have purchased Challenge wheels, may upgrade exhaust, and also might install 355 seats to get conventional seat belts, rather than mouse belts.
  16. gandalfthegray.
    gandalfthegray. Formula Junior
    Jul 18, 2006
    692
    Pinewood, MN
    Steve
    So is there someone out there making a twin inlet 348 bumper (as shown on the yellow car above)?
    I do like that look.
  17. Organiser
    Organiser Formula Junior
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    Hi,
    Yes, I do and I can also include a front splitter as well. The problem for you is that I`m in the UK.
    Regards,
    Phil.
  18. gandalfthegray.
    Jul 18, 2006
    692
    Pinewood, MN
    Steve
    Hi Phil, what would be asking for the bumper (unpainted)?
    Have you ever shipped to the US? zip 56676
    Steve
  19. TheOnlyest
    Sep 25, 2007
    1,686
    Steve
    Slick! Nice work! Is that an OEM cover that you modify? or a completely aftermarket piece?
  20. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    All chassis parts interchangable from 348 - 355?
    No not all but nearly. The chassis has some changes on the 355 but is mainly the same as 348. Changes from wich i know
    1. Rearsubframe has different mounting points for the gearbox
    2. Frontfenders have different holes for the door wires
    3. Rearfenders have the small spoiler thing
    4. Fronthood has some different holes under the airinlet cover
    5. Rearhood different ofcorse
    6. Rear sheetmetal part for the taillights is different
    7. Doors have different mountingpoints for the doorscoops
    Mount a 355 frontskirt on the 348
    Mountingpoints all the same
    need to modify the right air inlet wich goes normaly to the brakes to get air to the AC cooler
    need to modify the left air inlet maybe to get clearance to the battery
    need to change the wirings the connectors are all different
    Mount a 355 rearskirt on the 348
    didn't see any differences just 1:1 exchange
    Mount 355 doorscoops on the 348
    Need to modify the mounting points
    1. make a metal cover to close of the hole where the dooropener normaly is on the 355. make a hole in it to screw the scoop to the door on this point
    2. Make 4 metal angles and mount them to the stock mountingpoints of the 348. The mountingpoints have the same position then the 355 mountingpoints
    so they are on the right position :) . The top mounting points need a nut welded to them or you leave them away and use some silicon glue like sikaflex to
    hold the scoop on the top of the door and only screw in the screw on the doorhandle and the two nuts under it.
    Mount 355 taillightcover on the 348
    Cut out a center section of it
    cut out a vertical line of it
    weld it together
    form two round end pieces for each side to cover the hole between the cover and rearfenders
    add mountingpoints to the cover. i used 4 in the middle near the inner taillight hole that you can screw a nut or bolt through the hole in
    weld two studs on each side of the cover and drill a hole into the taillight sheet metal on the chassis.
    Mount 355 taillights on the 348 in the right angle
    Cut out much of the sheet metal part on the chassis to get the taillight far enough in to mount them on the right angle
    weld a 90° angle to the tube frame and on top the the chassis.
    exchange the wirings to fit the new taillights
    Maybe weld the broken circuits inside the inner taillights back in that you have all 4 lights on instead of only two wich i think looks better :)
  21. notbostrom
    notbostrom Formula Junior
    May 8, 2006
    957
    Orlando, FL
    Ben
    the 355 bumber is nice but looks out of place. It does stand out from the rest of the car.. maybe a little to much
  22. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    Yes the rest need to be converted to :)
  23. cscott67
    cscott67 Formula Junior
    May 13, 2007
    418
    Milwaukee
    Scott
    The bumpers do bolt on front and rear. The problem is that they do not match the rest of the body. In the front there will be a gap between the top of the bumper and the front edge of the hood/suppport. In the rear the bumper is wider and has to be narrowed to fit properly. Good luck on the mods, Scott
  24. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    I don't have a gap on the front bumper. There also shouldn't be a gap because the metal chassis parts on the front are equal to the 355. On the rear the rear bumper is a bit wider thats right you can leave it like it is and got a small step from fender to bumper. Or push the fender a bit out.
  25. Organiser
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    Thanks,
    The bumper in the pics is a Euro OEM cover made from PU (Plastic), I can also do them in Fibreglass as well.!!
    Regards,
    Phil.
