Modifying the Testarossa exhaust. | Page 2 | FerrariChat
Discussion in 'Boxers/TR/M' started by jcorallo, Aug 31, 2011.
  1. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,421
    Alabama (was Mich.)
    Jeff
    Testarossa Lover: Go ahead and install pipes in place of the convertors, it will help. I've heard that the most restrictive parts of the TR's exhaust system is the Precats...unless they have been hollowed out. The precats have a sort of chain-mail inside them that helps get the exhaust up to temp quicker for reduced emissions. This chain-mail crap really impedes flow.
    You should have O2 Sensors on your cat replacement pipes, so the fuel system can adjust as needed. I'd say go for it!
  2. Testarossa Lover
    Testarossa Lover F1 Rookie
    Dec 31, 2006
    3,622
    Newport Beach, CA
    Haig Barsamian
    Good, I get her to rumble now. :)
  3. Sunracer
    Sunracer Formula Junior
    May 18, 2005
    661
    Makati City
    Pierre Beniston
    If the exhaust system has such low restriction it could lean out the engine to the point that the fuel injection system can't compensate enough. There are limits to the original design parameters. Running too lean will over heat the exhaust and burn the pistons.
    My TR had hollowed out precats and Stebro converter replacement tubes. Great sounds and in picked up some power.
  4. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    #29 Philwozza, Sep 4, 2011
    Strange that it looses so much, it something like 20% :(
    Was a measurement taken before the removal of the parts so they had an like for like test?
    I believe that Ferrari often over estimate the power of its cars so the first time you test the car on a dyno it has already "lost" horsepower it never had:D
    Do you think Lambo could have done the same?
    Gorgeous car by the way, I love the purple colour, if I could afford another car it would be that one.
    P
  5. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,421
    Alabama (was Mich.)
    Jeff
    SUNRACER...yes that can happen, the TR's fuel system can only compensate so much. As I said in a previous post, that the fuel system must have it's base-line parameters reset for drastic exhaust system changes.
  6. Testa-rossa
    Testa-rossa Karting
    Aug 21, 2010
    61
    The Netherlands
    Martijn
    #31 Testa-rossa, Sep 5, 2011
  7. Ferrari Mackintosh
    Ferrari Mackintosh Formula Junior
    Sep 21, 2004
    716
    N/A
    Ferrari Enthiusiast
    #33 Ferrari Mackintosh, Sep 5, 2011
    I LIKE TO THINK THAT I'M AN EXPERT ON SUPERCAR EXHAUST SOUNDS (AS BIG HEADED AS IT SEEMS), AND I RECKON THAT IS POSSIBLY THE MOST PHENOMENAL NOISE I'VE EVER HEARD YET. YOUR EXHAUST APPEARS TO REMAIN TUNEFUL AND SWEET SOUNDING NO MATTER HOW HARD YOU REV IT OR FLOOR IT. NOT LIKE THESE OTHER HARSH SOUNDING SPORTS EXHAUSTS LIKE X-OST (AN ABSOLUTE RACKET/PAINFUL ON THE EARS). THE BIG QUESTION WITH YOUR EXHAUST IS - LOSS OF HORSEPOWER OR GAIN?
  8. Testa-rossa
    Testa-rossa Karting
    Aug 21, 2010
    61
    The Netherlands
    Martijn
    Thank you Dan ;) Can't get enough of it too!
    I raced it a week ago on Zandvoort racingtrack (ex GP track) and this weekend at the Assen moto GP track in Holland and I had enough power to keep up with every new type Ferrari there, no problem .. It runs and it runs and as you can hear in the last video, no flat spot at any rpm... My only problem is the brakes... I never had a car with brakes that bad. After one lap the steering wheel started shaking so that I had to slow down a lot earlier and lose my position just before the corners. This winter I install some 8 pot MovÍT calipers with aluminum bell mouted discs.
  9. Ferrari Mackintosh
    Sep 21, 2004
    716
    N/A
    Ferrari Enthiusiast
    FUNNILY ENOUGH, WILLIAM H THOUGHT THE SAME WITH HIS TR SO HE FITTED FERRARI F50 BRAKES AND NOW IT STOPS ON A DIME.
  10. Ferrari Mackintosh
    Sep 21, 2004
    716
    N/A
    Ferrari Enthiusiast
  11. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Great video.. You could have winded her out a bit more.. Take her to the edge my man.. They love it..
    R
  12. jcorallo
    jcorallo Karting
    Feb 25, 2008
    84
    After reading these posts it definitely makes sense that too much flow loses mid-range. I have always known that. Seems like the best option is to keep the stock set-up and just ditch the cats.
    By the way - the hyperflow cats that I have are gutted out and perfect. Would anybody be interested in buying them?
  13. Testa-rossa
    Testa-rossa Karting
    Aug 21, 2010
    61
    The Netherlands
    Martijn
    Just to enjoy:
    [ame]http://www.youtube.com/watch?v=jVYxjKyqHFA&feature=related[/ame]
  14. Testarossa Lover
    Dec 31, 2006
    3,622
    Newport Beach, CA
    Haig Barsamian
  15. Testa-rossa
    Testa-rossa Karting
    Aug 21, 2010
    61
    The Netherlands
    Martijn
    Yessss!!
  16. EMILIO
    EMILIO F1 Veteran
    Feb 23, 2006
    6,854
    Italia
    this is rwhp not flywheel!
    the number is more or less correct for a jota car
  17. Maniak
    Maniak Rookie
    Jan 2, 2009
    47
    Amsterdam
    Marc
    This replaces most of the original system, right? Yeah, where should you install the O2 sensors? I think Ferrari installed them on the location they did for a reason. For sure there is concern not to overheat these parts and I know they are rated for 500 Deg/C in temperature. My point is, should you place them closer by the header, the gas flow "upstream" has yet to lose its energy and they sustain conditions that are much harsher. A second thing is, they are mounted sideways for example, and never placed at the underside of a pipe. That's because of moisture, their second mortal enemy.
    Running the engine without the sensors is possible. To tell the computer the mixture is right, hence you replace the signal that was discarded, is all that is required in theory. It can be done with printed circuit boards that find use in conjunction with nitro boosted engines etc. Please note. These sensors (=narrow band) at idle, they cycle the mixture sort of speak. At full throttle, they do nothing! Hope this helps.
  18. Ferrari Mackintosh
    Sep 21, 2004
    716
    N/A
    Ferrari Enthiusiast
    IT CAN'T BE, BECAUSE WHEN ROYTOY CHANGED THE EXHAUST OVER BACK TO THE OEM/STOCK EXHAUST THE POWER FIGURES INCREASED.
  19. Red Head Seeker
    Red Head Seeker Formula 3
    2,443
    San Francisco Area
    Mark
    Hello Dan; Can you PLEASE!!! turn the "caps" off when you type.......Mark
  20. Ferrari Mackintosh
    Sep 21, 2004
    716
    N/A
    Ferrari Enthiusiast
    Ha ha! OK just a bad habit that stayed with me. How's this? LOL
  21. Red Head Seeker
    2,443
    San Francisco Area
    Mark
    #47 Red Head Seeker, Sep 8, 2011
    Thanks Dan....a "bad habit" is not driving your Testarossa enough....as far as customizing/altering the Testarossa exhaust.....I made my own custom exhaust, eliminated both the cats and pre-cats by welding a appropriate sized pipe and length to replace the cats and pre-cats, then for the muffler utilized a "Flow Master" muffler, welded the bungs for the O2 sensors, and for about $200.00 in parts and my labor, I have an exhaust system and more importantly to myself, a sound (F1) that rivals any exhaust out there. I have been to many Ferrari gatherings and have recieved nothing but compliments and many astounded listeners. I don't believe thousands of dollars needs to be spent to achieve a "F1" sound, just some time a few lengths of pipe & a Flowmaster muffler. I will try to post my exhaust sound, I'm Great at mods....like a 3rd grader with a computer....Here's a video from a Ferrari gathering. My car is the white Testarossa....you can hear the car leaving the dealership at 2:12 of the video...and also doing a drive by at 2:25....notice the front end lift from the torque of the motor as I accelerate.....Mark
    [ame]http://www.youtube.com/watch?v=_UQkr_x-Y9k&feature=related[/ame]
  22. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,938
    Red Head Seeker,
    Sounds great! Can you provide any details on how you fitted the Flow Masters and which ones you used? I eliminated my cats and gutted the pre-cats but the sound did not change much from before, probably because I used the stock muffler, so I am thinking about going your route.
  23. Red Head Seeker
    2,443
    San Francisco Area
    Mark
    #49 Red Head Seeker, Sep 8, 2011
    Here's the link. The Flow Master muffler was almost the exact size as the stock Testarossa exhaust as were the inlet & outlet locations. I was able to get a stock Testarossa muffler at a GREAT price from a fellow F-Chatter. I then cut the muffler apart and "carefully" removed (lot's of grinding) the inlets and outlets, and then welded them to the "Flow Master" muffler. Some brackets were made and welded to the new muffler (simple)....and AMAZINGLY!!, since the inlet and outlet locations were very close, the dual exhaust tips located themselves "Perfectly" in the factory location. It was almost if the Flow Master muffler was an "Exact" replacement factory muffler. I also have removed the stock Ferrari air cleaner and inlet, and replaced with "Dual cylinder shaped over-sized K&L air filters, utilizing flexable metal tubing that is located down in the engine compartment next to the wheels. One flexable tubing per throttle body. I also built a stainless steel "Heat Shield" that mounts between the muffler & motor to seperate the muffler heat from the area where the cold air intakes are mounted. I NEVER liked the stock Ferrari air filter location....If "Heat" travels up.....Why mount the air filter on top of the motor/exhaust heat?.....that is why I relocated the "New" dual air filters as far "Down" as possible. With the combination of the custom exhaust & dual cold air intakes the difference in performance, gains in horsepower, sound, instant throttle response, is "AMAZING"!!!....Like I stated.....watch the "Front-End Lift" during acceleration in the video....that's "Horsepower"!!!.....car revs to 7,200+++ in the "Blink of the Eye". I almost forgot to mention VinceP, that when I cut apart trhe stock Ferrari muffler...you would be surprised & disapointed at how restrictive & baffled the stock muffler is, that is why you are hearing no Sound change....you have opened up your exhaust system by gutting the cats and pre-cats....THEN!!! the stock muffler restricts the "improvements".....Mark
    http://www.flowmastermufflers.com/searchfmm/inoutlet.php?inlet_pos=Dual&outlet_pos=Dual&inlet_dia1=2.5&outlet_dia1=2.5&search=1&inlet_dia=2.5&outlet_dia=2.5
  24. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,421
    Alabama (was Mich.)
    Jeff
    Hey Mark - do you have any sound clips of your exhaust system from behind the car? It sounds great coming at you....how about going off into the distance.....?
