molded breather hose | FerrariChat
Discussion in '308/328' started by 911rcr, Nov 25, 2012.
  1. 911rcr
    911rcr Karting
    Feb 4, 2008
    185
    Northern VA
    Alex
    Hi guys,
    Did a quick search but couldnt find what I was looking for. For my 2v GTBi looking for a cross reference for the molded crank case breather hose that runs from the aft of the rear cam cover down to the block.
    Thanks!
  2. CaptOharry
    CaptOharry Formula Junior
    Jan 4, 2009
    763
    Green Cove Spgs FL
    Harry Welch
    Your talking about #107783 Item #63 in the Parts Manual.
  3. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    #3 PV Dirk, Nov 25, 2012
  4. 911rcr
    911rcr Karting
    Feb 4, 2008
    185
    Northern VA
    Alex
    Thanks PV Dirk.
    Same function but different hose. The fitting on the cam cover is between the dizzy and the air pump pully. Ill post a picture shortly.
  5. 911rcr
    911rcr Karting
    Feb 4, 2008
    185
    Northern VA
    Alex
    Thanks Harry. Ill take a look to verify but was looking for a less expensive cross reference part.
  6. 911rcr
    911rcr Karting
    Feb 4, 2008
    185
    Northern VA
    Alex
    Harry,
    Yep, thats the one.
    Thanks!
  7. SteveG75
    SteveG75 Formula Junior
    Nov 23, 2010
    380
    FL
    Stephen
    Got one a couple of years ago from GT Car Parts. Good price as well.
  8. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Bill and Dave still have them........
  9. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,810
    Cerritos, CA.
    #9 miketuason, Nov 25, 2012
  10. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Mike, is that braided?
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    what is the part number? That hose is 7/8 inch and about 20mm. Napa does not have that size.
  12. miketuason
    Feb 24, 2006
    15,810
    Cerritos, CA.
    yes, it's cloth braided.
  13. 911rcr
    911rcr Karting
    Feb 4, 2008
    185
    Northern VA
    Alex
    #13 911rcr, Nov 26, 2012
    Thanks for the replies guys. As Harry mentioned, its part number 107783, # 63 in the diagram. Just wanting to know if there is a Ford/GM/? molded hose that is comparable in shape and dimension that is less expensive.
  14. SteveG75
    Nov 23, 2010
    380
    FL
    Stephen
    #14 SteveG75, Nov 26, 2012
    The US spec hose is different from the straight hose pictured above. Looks more like a number 7 in shape. Instead of the fitting bolting onto the end of the exhaust cam, it is between the cams (so we can have that great air pump drive).
    Just checked Ricambi (no access to T-Rutland right now). $131 !!!. That is crazy.
    I want to say I got the hose (with the bend) for less than $50 from GT Car Parts (maybe closer to $30 but that was 18 months ago).
  15. mwr4440
    57,968
    Bavaria, The 'Other' Germany
    Mark W.R.
    Try Dave Helms.
    My '81 has the same issue. Very specially shaped hose.
    I am going be a guinea pig and use an idea of his using his "SUPER HOSE" as I could not find a decently priced replacement anywhere.
    $130 and change is CHEAP compared to what i found and most did not have it at all.
    Since I already have Dave's other hoses, it was a no-brainer.
  16. viphoto
    viphoto Formula Junior
    Sep 11, 2010
    264
    Carlsbad, CA
    Mark
    #16 viphoto, Nov 26, 2012
    Could be a long shot but I came across a hose a while ago that may work... My hose on the car is still ok so I don't want to mess with it.. So the hose in below pic is the top radiator hose from a 1275 mg motor found on the later Midgets and Austin Healy sprites. Part # 17-409 for the kevlar version at Victoria British .. Like I said I haven't tried it other than just holding it up to the other one... the id looks to be 13/16ths so if you have yours off the car you can check. The mg hose was $21.
    Cheers
  17. yelcab
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    If it is truly 13/16th ID then it might work with a little heat gun. 3/4 (19mm) is too small. My guess is the factory hose is a 20mm hose. Of course, nobody carries that around the Bay area.
  18. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    SB,CA & Park City UT
    Jeff
    Do you have a part number for that? I'm having a hard time finding 7/8 for blow by system. Thanks Mike
  19. 911rcr
    911rcr Karting
    Feb 4, 2008
    185
    Northern VA
    Alex
    Thanks Mark! Looks plausible. I have my old hose off and will measure the ID and report back.
  20. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    #20 waymar, Nov 27, 2012
  21. viphoto
    Sep 11, 2010
    264
    Carlsbad, CA
    Mark
    Yep Page 52 the 1275 Cross flow system item #2
  22. Nielsk
    Nielsk Karting
    Dec 8, 2012
    179
    Central Florida
    has anyone tried the MG heater hose for this?
  23. mwr4440
    57,968
    Mark W.R.
    Guys,
    I would be very lery of using a coolent hose in an oil application.
    I do not believe that is the smartest of moves.
    My 2-Cents EU
  24. Nielsk
    Nielsk Karting
    Dec 8, 2012
    179
    Central Florida
    Good point, I will contact B C to try and determine what it is rated for, as it is Kevlar reinforced, it may work.
    BTW can anyone confirm what this hose does (107783)? Nothing in the manual, I do not see it in the oil flow diagram, but a very odd spot for a breather...
