Hi, i'm french (so i m sorry for my poor english). The A/C of My 85 3.2 mondial runs very well sometimes, and sometimes no. I checked all relays and the R12 level, no problem. The A/C compressor is good and turns. Any ideas ? Somebody here knows the same failure ? Thanks.
FWIW, in humid conditions, you can get ice built up in the system, which blocks the airflow, after it's been running a while. When the ice melts, the system works again. To find an intermittent problem, you have to figure out what the "non working" times have in common.
DGS is correct. A/c systems can ice up and have no airflow. Can you please explain a little better if airflow is your issue Mr Mondial? =
Hi, i find my A/C problem...It was the passenger's compartment temperature sensor...Now it's great...
