Mondial 3.2 Blower/Fan Speed Control Replacement with PWM | FerrariChat
Discussion in 'Mondial' started by aleib, Aug 15, 2023.
  1. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
  2. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    Speed Control 6 pins, left to rigth
    1 - Transistor (a) live and AC Compressor Relay (n) signal (+12v??)
    2 - Full Speed Relay (c) +12v
    3 - In 12v from Car
    4 - Transistor (a) variable V (??)
    5 - Full Speed Relay (c) ??
    6 - Push Button trigger ??
    Still investigating :) If some one can help identify, help!!
  3. Rifledriver
    37,075
    Steve Magnusson in the TR section will be able to answer your questions. TR has the same system and I believe Steve is an EE. He knows the electrical system better than anyone here.
    If indeed you get this done it will help a bunch of Ferrari owners.
  4. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    Can we call him here??
  5. Rifledriver
    37,075
  6. Steve Magnusson
    26,765
    Send me some money ;).
    What version 3.2 Mondial? US or euro or CH or ? (Not sure that it matters for this system, but it's best to be clear).
    You almost don't really need to know what any of the wires connected to the stock speed controller, 61, do as that Amazon motor controller would replace the speed controller 61, the power transistor a, and the full speed relay c. I.e., all you need to do is supply the existing (big) +12V power and ground to the Amazon unit, and then hook the motor up to the Amazon unit. An additional concern would be cooling that Amazon unit. Ferrari tries to address this by mounting the power transistor in the airflow stream from the cabin blower. I don't see an internal cooling fan in that Amazon unit, but, even if it had one, if you just buried it in the center tunnel = probably wouldn't be good. If you can find a place to mount the Amazon unit where you could add a small external fan to cool it, and there was a reasonable airflow path for that added external fan to draw in cool air and then blow out the hot air to somewhere else = then you could proceed. Let me know if you can address this cooling issue, and I'll post a mark-up of how to wire it in (although, once I look at it, there may be other issues as there is other stuff to automatically run the AC occasionally to defrost the inside of the windshield when using the defroster warm and that may impact things).
  7. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    PWM have 80% of efficiency, they don't warmup
    The pins 1 and or 6 go to ac compressor relay probably to turn it off if speed is low?
  8. Steve Magnusson
    26,765
    #8 Steve Magnusson, Aug 15, 2023
    Can't agree with that -- look at all the finned heatsinks inside and the perforated outer metal case. It is disappointing that there's no specification/data sheet in that Amazon ad -- if you have one please post (or a link).
    Don't follow you here -- pin 1 and pin 6 on the speed controller, 61, are the same GV wire. When you actuate a pushbutton (other than STOP) on item 60 = the GV wires on pin 3 of item 60 are connected to pin 1 on item 60 (ground). It does go elsewhere for other uses, but the bottom line is:
    STOP pushbutton pressed = GV wire is nothing
    Any other pushbutton pressed = GV wire is ground
    afterburner and aleib like this.
  9. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    The original controller has 6 pins
    We need to understand what they do to replace it.... It's nota just cut
  10. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    Goooood! Just jump it then.....
  11. Steve Magnusson
    26,765
    OK, you know best -- I'll go away. (I'll repeat: that Amazon motor controller would replace the speed controller 61, the power transistor a, and the full speed relay c -- not just the speed controller, 61).
  12. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    Yes yes, thats the plan, just need to know what to do with the other pins.
    The pwm module could run in the same place as the original transistor (inside the airbox)
  13. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    So...
    1 - Ground/Nothing
    3 - In 12v from Car
    6 - Ground/Nothing
    I I think to replace with a PWM we must
    a) remove Blower Transistor
    b) remove Blower Relay
    c) get Blower Motor plug (+ and -) and connect to PWD output (+ and -)
    d) get Control pin 3 and set as PWD input +
    e) get Control pin 1 and set as PWD input -
    f) get Control pin 2 and remove the wire with point b)
    g) get Control pin 5 and remove the wire with point b)
    h) get Cotnrol pin 4 and remove with wire with point a)
    i) ignore pint 6 and remove wire back to control.
    j) put the new PWD potentiometer in place/addapt if necessary and....
    work done?
  14. Steve Magnusson
    26,765
    Yes, that would be the general strategy, but you can't use control pin 1 (the GV wire) directly as the negative to provide a huge current to the PWD input -, nor the control pin 3 directly as the positive to provide a huge current to the PWD input +. -- their wiring and switch inside item 60 can't support huge current. You need to use the same large wires that presently supply + and - to the blower motor system for the PWD input + and -, and add a relay into one of them such that when the GV wire is ground = it closes the relay and makes the connection, but when the GV wire is nothing the relay is open and the Amazon unit is "off".
  15. Steve Magnusson
    26,765
  16. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    Correcto, so reuse the full speed relay for before the pwm and the ground signal from button... Sounds good, Will update the plan shortly (the pwm Will arrive in 10/14 days)
    moysiuan likes this.
  17. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    Just an update on how it goes
    (inverted numbers, because I use 1 as the high, near the potentiometer, and 6 the low, near the bottom of the car)
    1 GV ---> diode ---> 5 CG + 6 GV
    2 VR ---> diode ---> 4 MN
    and the Full Speed Relay is closed :) so I will install the PWD AFTER the Relay, and all is good :)
    this is a picture of the test
    2cam likes this.
  18. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
  19. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    Done!
  20. Rifledriver
    37,075
    If that is the size of the unit I am not sure in the air ducting is a good idea. It would restrict airflow. Under the console has little airspace. In the foot well or in front of the firewall seem like better choices.
  21. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    the PWM was installed where the original sound system power amplifier was
