Mondial 3.2 decides not to idle | FerrariChat
Discussion in 'Technical Q&A' started by jelliott, Jul 28, 2021.
  1. jelliott
    jelliott Karting
    Mar 8, 2010
    102
    Seattle, USA
    Joe Elliott
    A couple weeks ago, getting off the freeway at the end of a ~50 mi drive home, the engine died when I disengaged the clutch at the first stoplight, but started right back up seemingly normally. Half a mile later, it does the same thing at the next stoplight, and again half a mile after that at the final stop sign before my house. This seemed so much like it HAD to be a an idle switch not closing, that I let confirmation bias get the better of me; hurriedly probing the pins on the idle switch and not seeing continuity, I went ahead and spent $50 on a new idle switch (BMW cross-reference, so not Ferrari pricing, thankfully), installed it, and drove the car again (without testing the old one off the car to realize that I'd botched the first measurement). Got where I was going with no problems. Then, on the way home (20 mi, mostly freeway), it does it again! Dies at the end off the off-ramp, restarts just fine, dies at subsequent stops over the last mile to my house. (Although upon the final re-start to pull into the garage, it was apparent that it wasn't actually idling entirely normally—idle speed definitely a bit low.) So what else can possibly cause this behavior? (Note that the car is very low on fuel at the moment—probably lower than I've ever had it [except the time we drained the tank and refilled it with just a gallon and it died on the steep downhill between my house and the gas station], but I figure this can't possibly be related, because the car obviously had ~40 mi worth of additional fuel in it the first time this happened!) Heat soak seemingly must have something to do with it, but what's being affected that could cause this particular peculiar behavior? Would this be the expected behavior if the K-Jetronic ECU just died entirely (i.e. frequency valve not operating, mixture super lean)? An ignition problem? (Note that I recently replaced the ignition modules, distributor rotors, wires, extenders, and plugs.)
    Thanks in advance,
    Joe
  2. moysiuan
    moysiuan F1 Rookie
    4,255
    Canada
    #2 moysiuan, Jul 31, 2021
    Sounds like the car is running too rich, which stalls things out at idle. Check a spark plug, it is probably fouled black with fuel.
    Since you have dealt with the obvious electrical issues, we can think about the fuel issues.
    Has your fuel distributor been rebuilt or is it original? Could be an internal fuel distributor leak, there are rubber o rings and a diaphragm inside that degrade and cause misfueling.
    What year is your 3.2? Does it have the cat converter and O2 sensor?
    Does the car start well, cold and hot?
  3. jelliott
    jelliott Karting
    Mar 8, 2010
    102
    Seattle, USA
    Joe Elliott
    Maybe you're on to something; the plug I pulled is definitely darker than I anticipated. That said, I'm not sure it's dying-rich-black, and I wouldn't call it fouled, per se:
    http://joeshouse.2y.net:8080/~jelliott/IMG_7524.jpg
    I just went through the records again and I don't see any evidence of the fuel distributor ever having been rebuilt. Is it really plausible that an internal leak in the fuel distributor would only manifest itself when things are really thoroughly heat soaked (i.e. fine after a ~30 min freeway drive, but only problematic at the end of a subsequent ~30 min return trip)?
    The car is a USA-spec '86, so it has a catalytic converter and oxygen sensor. I replaced the oxygen sensor earlier this year, and checked the duty cycle on the frequency valve to satisfy myself that the system was working properly and hadn't been mis-tuned by previous owners ...and now I can't find my notes with those measurements, but they seemed reasonable (for example, there was no indication that the system's authority was saturated in the lean direction as though it was fighting an erroneously rich mixture).
    Car starts instantly, cold or hot. (Note that this was not always the case before I replaced ignition components earlier this year.)
  4. Steve Magnusson
    26,932
    That would be a reasonable thing to do again at warm idle IMO as it would indicate if the WUR warm control pressure has changed to a different value (although measuring both the cold and warm control pressures would be something that you should do first anyway if you were to mess with the mixture adjustment).
  5. moysiuan
    moysiuan F1 Rookie
    4,255
    Canada
    Thinking of what else could cause this problem, and yet still not have hot or cold start issues, I can only think of the fuse box which might have the vertical connector involving the fuel pump heat up after the car has been running a while, and cause some sort of intermittent fuel pump operation that might present when slowing down to a stop. Seems unlikely this would not cause other drivability and hot start problems though. Another random thought is some sort of vacuum leak, go through the air injection system hoses and the those that go to the air injection electrovalve and check valves, and to the spark computer, and make sure these are all not causing a vaccum leak. If they are, the computer might detect a lean condition, and then would add fuel which is undeeded and cause the stall.
    But on a car this age with an original fuel distributor, that is a prime suspect. The rubber items in there were not designed for modern fuels, and any rubber immersed in fuel for 30 + years is going to degrade.
    The fuel distributor consists of a metal plunger that goes up in the fuel distributor body to meter fuel and springs down to return to its idle set position. At idle set position, there would be no fuel flow when the car is off, and the engine vacuum when on at idle is sufficient for the air flap on the plennum to push down ever so slightly and allows the plunger to be slightly acutated and allow the small amount of fuel required to sustain the idle. It is a ridiculously refined system, miniscule movements of the plunger make the difference. It is full of o rings for each port, and a very thin rubber diaprahm that seals all the ports from each other, and these can leak. A bit too much fuel at idle and you get a stall. You can see this doing the following: with the car idling, and the air filter off, push the air intake flap ever so slightly down on the fuel plennum body by hand, and the car will stall as the flap push causes the plunger to lift, and it overfuels. So, it is possible the plunger is sticking and not returning consistently fully to its down position.
    Unfortunately you can only check this plunger action by removing the fuel distributor. This in itself is not that big a job, but once off the temptation to just rebuild it would be pretty high. You can not remove the plunger without key calibration issues being affected, but if that where this goes that requires other threads for advice. It can be done by yourself, but there is a great rebuilder that most would rely upon.
    You could check for an internal fuel leak by doing the following: Remove one of the fuel distributor port pipes (make sure you depressurize the fuel system first, otherwise you will get fuel spraying everywhere, I just start the car, pull the fuel pump fuse and let the car stall after using up the available fuel. With the car off reinstall the fuse). Without the car runnning, jump the fuel pump relay to get the fuel pump to pump (there might be a different procedure to get the fuel pump to run like this, my 1988 Mondial 3.2 car is the Swiss model with somewhat different fuel injection components). There should be no fuel rising up in the port of the pipe you removed. If there is, the plunger is not in its proper rest position and/or there is an internal leak. That would be the excess fuel at idle that would cause a stall. The gold standard for testing these things is various fuel pressure tests, but the procedure noted could catch an obvious at idle internal leak. Fuel pressure checks might not detect an intermittent sticking of the plunger though.
    The fuel system works quite well off idle even when there are things not working as they should be. Most of the complex fuel system controls are to get the car to idle with low emmissions. This is why fueling problems are vexxing in that the car can run well enough at off idle conditions.
    I might have expected some hot start problems given your symptoms described. But the plunger might well be reloosened up by pressing the throttle when starting, and a start up vacuum admits more air and the rich condition is not enough to cause a starting problem.
    My car does not have the frequency valve, or the warm up regulator. These are the other components that regulate fuel, but I would defer to others with those components as to whether they could cause the symptoms you present.
    I don't want to send you down the fuel distributor track without having looked at more obvious things like vacuum leaks. But you seem to know your way around the car, and having dealt with the ignition componentry and ruled those items out, I thought it suitable to add to the ideas of what can cause your issue.
  6. moysiuan
    moysiuan F1 Rookie
    4,255
    Canada
    Just linked to your plug picture. That looks like it is running rich, not ridiculously so, but these cars when set up properly do not run rich at all. Pull another plug and see if the same, that would help rule out eg. a sticky fuel injector leaking at idle but affecting a specific cylinder. I bet if you change the plugs, the car will run well without the stall for a while until the plugs start to foul up again. I see you are using an iridium plug, they generally are more fouling resistant, but once fouled not so good. Might get a batch of the regular plugs as you don't want to keep fouling expensive plugs while trying to diagnose your actual problem.
    I went through a similar symptoms with my car, and went down alot of rabbit holes trying to solve the problem. It was my fuel distributor internally leaking, so I do have a bias to that being the problem.
  7. jelliott
    jelliott Karting
    Mar 8, 2010
    102
    Seattle, USA
    Joe Elliott
    Yeah, I'll definitely repeat that measurement next time I drive the car, but I'm still struggling to imagine what could be different as a result of a few hours parked, such that it does it on the way home, but not on the initial half of the round trip (which was long enough for things to be thoroughly warmed up, such that I'd expect a warm idle problem to manifest itself when I got off the freeway on the first leg of the trip, rather than exclusively on the way home). (And, for what it's worth, I found what I'm pretty sure are my notes from when I performed this measurement in May—47% closed loop, 51% with sensor disconnected, 59% with WOT switch shorted.)
    Funny that you should mention that—my fuse box is, indeed, heat-damaged in that area, such that I was frankly surprised it ran at all—I've since replaced the whole connector (and affected pins) and added a relay for the pump so the fuse panel is no longer carrying all that current. But I would expect any issues there to manifest themselves when the car is at speed—at idle I imagine there's enough fuel in the accumulator to keep the engine running for a few seconds if the fuel pump is intermittently cutting out.
    Thanks for the tip; if I can think of a non-messy way to depressurize the fuel system first, I'll try this both cold and warm. (Do you happen to know the correct torque for reattaching the fuel line to the fuel distributor?)
    Here's a photo of another plug:
    http://joeshouse.2y.net:8080/~jelliott/IMG_7526.jpg
    Did you notice any kind of weird temperature and/or heat soak dependence when your car had similar symptoms? That aspect (i.e. it only does it on the way home, not on the first leg of the trip), plus its willingness to restart every time, is what's really baffling.
    Thanks!
  8. moysiuan
    moysiuan F1 Rookie
    4,255
    Canada
    The 10mm threads on the fuel distributor pipe torque is 10.9 ft pounds. Probably need to use two new copper sealing washers, might be able to reseal with the existing copper ones. Regardless, check for leaks/weeps once you put things back together, and do not strip the threads in the fuel dist body.
    Do the fuel check I described with the engine long left cold, you don't want anything hot around when opening gasoline pipes.
    The second plug looks similar to the first, running rich for sure, suggesting you have overfueling in all the cylinders, which helps rule out some cylinder specific items.
    My problems started out with rich running, but running well enough, some intermittent idle fuel smell, a bit of surge at low thriottgle openings. My plugs looked like yours, maybe a bit more fuel fouling. Then stalling after a long hot run when coming to a stop. Then eventually not starting easily, and eventually not able to hold a consistent idle. So it was a progressive failure, over some time. I had done all the ignition and wiring items, and spent alot of time ruling out many things.
  9. raemin
    raemin Formula 3
    Jan 16, 2007
    2,389
    Lyon (FR)
    R. Emin
    If the pump is drawing excess amps it means there is some crude in the system. Adding a relay makes the system more reliable but could mask a' underlying issue.
    Would replace pump filter, TANK PICKUP FILTER, and clean the mesh-screens (distributor and wur inlets).
    Will probably not solve your issue but should be taken care off while ylu are there
  10. jelliott
    jelliott Karting
    Mar 8, 2010
    102
    Seattle, USA
    Joe Elliott
    Well, after a surprise business trip and a number of other distractions, I've finally gotten back to this, and performed the check of the fuel distributor as recommended—fuel did NOT rise in the open outlet port of the fuel distributor when the pump was running (at least not with everything stone cold). The fuel level was sitting maybe 8 mm below the port. A couple minutes after shutting off the pump, however (i.e. after I walked away from the car to get new copper washers for reassembly), the fuel level had risen to the top of the port—is that normal? How plausible is it that everything works properly when it's cold, but behaves so differently when heat soaked and fully warmed up a second time that it dies rich at idle following decel?
    I hope to drive it Saturday to re-check the frequency valve duty cycle to see if its authority is saturated in the lean direction (or otherwise abnormal) after it's fully warmed up.
  11. moysiuan
    moysiuan F1 Rookie
    4,255
    Canada
    #11 moysiuan, Aug 19, 2021
    So that looks like a slow leak in the distributor. The only way fuel I am aware of that the fuel would rise in that port is the gas in the pressurized system after left a while is finding its way past the internal seals when it should not.
    When cold the car is designed to run rather rich (eg. you actually have a cold start injector to make sure you have very rich mixture to start the car when cold), when warm richness is not helpful to a proper idle, and will cause the stalling.
    Perhaps others can confirm this assessment?
  12. moysiuan
    moysiuan F1 Rookie
    4,255
    Canada
    You might try turning the fuel mixture screw 1/16 of a turn to the left, this will lean things out and might compensate for the hot running issue. See if that makes any difference. Most normally advise not to play with mixture to address other issues, but it can help to diagnose things. Just be meticulous in the very small turn of the screw, and be able to turn it back if things are unchanged or the engine idles more poorly.
  13. jelliott
    jelliott Karting
    Mar 8, 2010
    102
    Seattle, USA
    Joe Elliott
    Well, I drove it Saturday (this time with a full tank of fuel), another case of a ~20 min freeway drive, sitting for a few hours, and then the same drive home. And sure enough, IT DID IT AGAIN, but only at the end of the return trip, just like before. But not as definitively this time–it didn't die at the end of the freeway off ramp, only at the stop sign a block from home (restarted fine), and then again as I was pulling into my driveway. But here's the frustrating part: after restarting again and pulling into the garage, I couldn't get it to misbehave!! I was all ready to go with my timing light to verify ignition functionality on all cylinders and my multimeter patched into pin 15 on the ECU to check the frequency valve duty cycle, but after that second restart, it just kept idling fine! I obviously couldn't simulate load/decel in the garage, but I revved the engine a bunch and closed the throttle abruptly, but it carried on idling just fine, and the frequency valve oscillated right around a perfect 50% duty cycle closed-loop, and was steady at 59% when I shorted the full-throttle switch to force it open-loop. (And, interestingly, the idle was no worse or maybe even a bit stronger when I forced it open-loop, which suggests that I'm dealing with something other than an excessively rich mixture.) What the heck? The ability to instantaneously (but intermittently) cure itself suggests an electrical issue, in my mind, but what?
    Given that my mixture seems nominally perfect (i.e. that the Lambda feedback system runs the frequency valve at exactly 50%), I'm that much more reluctant to play with it. But first I'll have to figure out of the Phillips-head screw jammed in my mixture adjustment is just meant to be an ersatz dust cover, or if turning it will actually turn the adjustment (and, if the latter, I'm afraid I'll never be able to get the adjustment back to where it was, after removing the stupid screw)!
  14. moysiuan
    moysiuan F1 Rookie
    4,255
    Canada
    #14 moysiuan, Aug 23, 2021
    Reaching for some ideas...Maybe some burnt or loose connections at the fuse box, the infamous fuel pump connector? After a good run the fuel pump heats up the fuse box contacts and maybe you get some random intermittent fuel pump interruption? No reason this would present only when coming to a stop though.
    Maybe a leaking vacuum hose to the spark ecu, that only presents under load when vacuum pull is higher but rpms of the engine are lowering, as would occur on deceleration?
    Maybe the air injection check valves and the vacuum hose to the electrovalve that actuates the air injection needs inspection? Maybe getting some sort of lean condition on deceleration, and the computer senses and add richness when it shouldn't?
    Head gasket leaking, and some coolant being sucked into the engine under load conditions? Any white smoke coming out of the exhaust on a warmed up engine? Would need to do compression test to see if there are any anomolies in a specific cylinder. Seems a stretch, as one would expect this would present running symptoms under more conditions than just your examples.
    Just some guesses based on my understanding of the systems.
    My Swiss car has a unique spring loaded attachment to allow for mixture adjustment to be done very easily. I think in your case, that philips screw was from a technician replacing a factory "plug" designed to avoid tampering for the US emissions. The actual mixture screw is an allen headed screw under that plug within the plennum body.
    The mixture screw itself acts as the stop for a lever mechanism, on the other end of the lever it pushes on the plunger in the fuel distributor body, that is how the screw position alters the mixture, and the lever with its fulcrum point makes very small screw position changes have an outsized movement on the other end of the lever.
    When I do the adjustment, I use a T handled allen key, and that helps with the visual of how much of a small turn one makes, and one can return it to a start position. It should not cause you problems to carefully play with it.
    But it makes sense to further rule out electrical matters, I had presumed that at the start of the thread, but of course one can miss intermittent issues despite a thorough check and some parts replacements.
    Your plugs showing rich remains among the clues that points to fueling, spark issues would generally affect one cylinder, or one bank of cylinders, not all of them. And the suspicious rise of fuel in your fuel distributor also points to fueling issues inside the distributor. I can't explain these clues without reverting to the
  15. jelliott
    jelliott Karting
    Mar 8, 2010
    102
    Seattle, USA
    Joe Elliott
    Yeah, any kind of fuel delivery problem would manifest itself more obviously at high engine load as opposed to decel or idle.
    I'll definitely take a look at this, but if the vacuum of decel opens up a leak in that hose, the timing would be retarded to the full-throttle advance curve, which I wouldn't expect to kill the engine or affect the idle too much—on older distributor ignitions we set the static timing at idle with the vacuum advance disconnected, after all, and I don't recall the idle changing noticeably when doing so.
    Oh gosh—unintended EGR from a busted air injection check valve—is that a known failure mode?? I might expect that to be more apparent under load (pressure in the exhaust manifold higher), but maybe not, given the intense vacuum that's present in the intake manifold on decel. I should probably take a look at this too, but this is one system I'm not terribly familiar with—is it really as simple as it sounds—electrovalve opens, and the exhaust scavenging effect is so strong from Ferrari's flat-plane V8 that the little transient suction pulses in each exhaust manifold branch are strong enough to overcome the intake vacuum and draw little gasps of air into the exhaust?
    Yeah, certainly no white smoke or unusual smells. And I spent enough time standing behind the car, idling in the garage Saturday afternoon, staring at "50%" on the multimeter and cursing myself that the problem went away just as I got home, that I'm pretty sure I would have noticed!
    Yeah, nothing worse than an intermittent problem! I'm curious if my symptoms are consistent with the ECU just dropping dead (and the engine thus going super lean due to lack of frequency valve actuation). Things did get quite hot back there when I had my single-bank ignition failure back in March, and I'm pretty sure it was only after that, that I found and repaired the peeled-back bit of insulation in the ECU compartment, so I was actually a little surprised that my ECU wasn't totally fried then! So I can't help but wonder if it did suffer some damage that only becomes apparent after heat soaking. (Or maybe the culprit is that dang Porsche-branded relay that powers it—the fact that restarting the car [i.e. turning it off and on again] seems to briefly cure it seems entirely consistent with a failing relay, and I know that the identical relay that powers the ABS in my Porsche is one of only two things that's failed multiple times in the 16 years I've owned that car.)
    Looks like that last sentence got cut off—the suspense is killing me—were you about to tell me what's actually wrong with my car? o_O
  16. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    793
    Treasure Coast Florida
    MATT
    Sorry I have not read this thread at all and maybe this was mentioned but check your fuel pressure regulators.... if it is leaking internally it will dump raw fuel and cause it to stall out... very easy to check.
  17. POLO35
    Feb 21, 2005
    793
    MATT
  18. moysiuan
    moysiuan F1 Rookie
    4,255
    Canada
    Ha, yes I fumbled my message at the end, indeed I know what is wrong with your car but decided to keep it secret, it will be revealed on my new reality show, Mondial Island.
    The air injection system has two check valves at the exhaust manifold injector connection that rot out or fail from inside, and you can get both air leaks or exhaust gas backing up into the system. Easy to check, the rear one is quite accessible, take off the hose and see if there is carbonization signs of back flow, or you can take off the valve (if it is not seized on) and inspect it more carefully. Replacements are very expensive for what they unless you buy these ones which are not - Standard Auto Parts Brand pn AV7. Get them before they are no longer available, you will need them eventually.
    There is also a plastic check valve that the eletrovalve vacuum line hooks to, but I don't think fails often. Since it is plastic it might be brittle so removing the hoses to check may not be worth the bother. Beyond that just check that all the hoses are good.
    The protection relay can cause problems, but I don't recall other Fchat threads noting symptoms like yours.
    Maybe the fuel ecu connectors are not well seated? Perhaps just taking off and cleaning with Deoxit and replacing will be a worthy procedure?
    My last truncated note was stating that we can't ignore the clues provide by an appearance of rich running on at least two plugs (suggesting they all are showing the same rich mixture), or the fuel distributor internal leak check which does suggest an internal leak.
    Like you, I was resistant to dealing with my fuel distributor, and presumed it must be something else, focussed on spark. In the end the fuel distributor was very easy to remove, just need to be careful not to strip any fittings when replacing the lines. My inside rubber parts showed no blatant signs of failure, but when reconditoned with new seals inside and installed, I can say my car runs like a new car. The problem was no doubt creeping in over some time before the more dramatic stall I was getting like you. As a handyman owner I am hesitant to be definitive on sending you down the fuel distributor track, but the clues I am seeing on fueling seem compelling.
  19. jelliott
    jelliott Karting
    Mar 8, 2010
    102
    Seattle, USA
    Joe Elliott
    Ah yes, the classic Bosch "damper that looks like a regulator" trick. But what's less clear to me is whether you're still saying there's a failure mode associated with it that I need to rule out. Related question: I was pleasantly surprised to discover that there are still a number of purpose-built K-Jet fuel pressure test kits available via Amazon, etc.—is there a particular product that people recommend?
    Thanks for the cross-reference! I'll buy a couple of those right away, if only to keep on the shelf!
    What would the symptoms of a failing protection relay look like?
    Already did that!
    The fact that the symptoms go away (and don't necessarily recur, based on last weekend's experience) when I turn the car off and on again is hard to reconcile with internal leakage—is there anything that could be binding up in the fuel distributor that would be effectively 'reset' when the fuel pump is turned off and on again (bearing in mind that the system is designed to retain pressure with the pump off, so it would almost have to be something flow-dependent).
    Where did you send your distributor for overhaul? Or did you do it yourself?
  20. jelliott
    jelliott Karting
    Mar 8, 2010
    102
    Seattle, USA
    Joe Elliott
    UPDATE:
    I drove the car again today, this time with a multimeter in the car, wired to pin 15 of the K-Jetronic ECU to monitor the frequency valve signal. And sure enough, the system seems to saturate in the rich direction (3% on my meter, which I presume is actually 97%, since full-throttle open-loop operation shows 40% rather than 60% on this meter), suggesting that it's reacting to excess unburned oxygen in the exhaust. (So this explains the slightly rich-looking plugs, if it's reacting to something other than an actual lean-running condition.) But I could not get it to stay running long enough in this state to get it into the garage, and upon restarting the car it's fine!
    So, upon realizing that the inductive pick-up lead on my timing light is just barely long enough to reach from the engine compartment to the passenger compartment, we set out again, this time with the timing light (attached to the aft coil wire) and my girlfriend in the back seat. After a few minutes of driving around, we got the issue to reoccur, but with no change to the timing light signal. So we moved the timing light's pick-up to the forward coil wire and, bingo, erratic timing light flashing corresponded to the 97% frequency valve duty cycle! What's interesting is that she said it never stopped flashing entirely (until the car dies at idle, obviously), but rather flashed erratically when the issue was occurring, as though it's not a complete failure of the ignition on the forward bank, but rather something causing a weak spark or loss of spark on less than four cylinders.
    Of course now I'm regretting not replacing the distributor caps when I replaced nearly everything else in the ignition system six months ago, but my next step is going to be to switch the coil assemblies between banks and see if the problem follows the coil. (Note that the coils themselves are the other thing that wasn't replaced.)
  21. jelliott
    jelliott Karting
    Mar 8, 2010
    102
    Seattle, USA
    Joe Elliott
    Well that didn't work. It seems like the erratic timing light behavior on the forward bank correlating the 97% frequency valve duty cycle was a fluke. When we got back on the road with the coils swapped, at first it seemed like the problem followed the coil, but then the timing light seemed to flash erratically in a way that didn't correlate to anything when we swapped it to the other coil wire. The lead is only long enough to reach cylinder #4 individually (with the timing light in the passenger compartment and the hood closed), but when it was hooked up thusly there was no interruption of the light when the car started acting up.
    And then we realized that the way it was coming and going, jumping from 50% duty to 97% and back to 50%, we would have noticed an instantaneous kick of acceleration or deceleration every time it happened at steady state cruise on the freeway, but we didn't. That—and the rich-looking plugs on both cylinder banks—make me think that it almost has to be something in the fuel ECU, i.e. the change in duty cycle isn't a response to unburned air in the exhaust, but rather erroneous behavior of the fuel injection system itself. (And not the protection relay, either, because—if I can trust my meter—that would produce a 0% duty cycle, not 97%. I also confirmed that when it's acting up on the freeway, flooring the throttle makes the duty cycle jump to 60%, as it should, and reverting to part throttle went back to 97%, in this case.)
    So now I think my next step should be to wire up a switch to short the full-throttle microswitch, and next time it happens, if I can keep it idling while it's misbehaving (which I was able to do a couple times today, by tickling the throttle), I'll flip the switch: if it continues to try to die, we'll know that there's something else wrong and that the rich duty cycle was just a response to unburned air in the exhaust; if the idle recovers, we'll know that the rich duty cycle is the actual reason it wants to die. In the latter scenario, does that necessarily mean I have a bad ECU, or would a fault in the oxygen sensor wiring produce this behavior? (I know it's supposed to detect a disconnected sensor and revert to an open-loop mode of operation in that case, but I seem to recall that if you short the oxygen sensor wire directly to ground, that will produce like a 95%+ duty cycle and make it too rich to idle...hmm.)
  22. jelliott
    jelliott Karting
    Mar 8, 2010
    102
    Seattle, USA
    Joe Elliott
    Success! Shorting the full-throttle allowed me to prevent the car from dying at idle, i.e. the super-rich mixture is the problem, not a system response to another problem. So I could just drive it around like that indefinitely, but if I'm going to go that route, I should really try the other open-loop mode, i.e. disconnect the oxygen sensor, because that should make it run open loop at nominal mixture, whereas what I've done is making it run open loop in the richer-than-nominal mode intended for full throttle mixture enrichment and super cold starts.
    But, of course, the question remains as to what's broken—as much as I'd like to think that Amazon sold me a defective oxygen sensor earlier this year, I'm increasingly fearful that it's the K-Jet ECU, since turning it off and on again temporarily resolves the problem. My cursory research suggests that my ECU is not the same as an earlier 3.0 car (even though all it has to do is modulate the same frequency valve in response to the same oxygen sensor input), limiting my opportunities for troubleshooting or inexpensive repair. Does anyone know if the car will run properly with a 3.0 QV 0 280 800 063 ECU? Anyone in the Seattle area want to loan me a correct 3.2 ECU for troubleshooting?
  23. moysiuan
    moysiuan F1 Rookie
    4,255
    Canada
    I have a NOS spare ECU but it is for a Swiss market car, the Bosch number is 0 280 800 261. I would send it down for your test purposes, but as the Swiss car has the KE3 injection I am pretty sure this will not work on your car.
    I think failed ECU's are pretty rare. Are you sure the connectors are clean and affixing tightly?
  24. jelliott
    jelliott Karting
    Mar 8, 2010
    102
    Seattle, USA
    Joe Elliott
    I actually haven't confirmed the Bosch part number for my ECU (Ferrari part number 127479, pretty sure that should be Bosch 280 800 068), but the ECU from a Swiss car, especially a later Swiss car with KE3, would certainly be very different.
    Connector has been inspected/cleaned/reseated. I've never heard of an analog Bosch ECU failing either, but I experienced an ignition failure on one bank earlier this year, which ended up with the exhaust system glowing red hot... and only subsequently did I discover and repair a bit of displaced insulation in my ECU compartment. So it's safe to say that those 35-yr-old circuit boards were exposed to some pretty excessive temperatures four months ago. :(
  25. moysiuan
    moysiuan F1 Rookie
    4,255
    Canada
    I still go back to the suspicious fuel distributor test when you identified a bit of leakage past the plunger if I recall. Your shorting out the throttle microswitch leaned things out, and compensated for what might be a leak inside.
    The reason I have a spare ECU is I went down the track you are on. :)
    But each car is different, and my quirky Swiss setup is not quite comparable to yours. But I feel we are ignoring the results of the fuel distributor test procedure you did, which did suggest something was leaky inside.
