Mondial 3.2 exhaust noise | FerrariChat
Discussion in 'Mondial' started by buck74, Jan 2, 2017.
  1. buck74
    buck74 Rookie
    Dec 14, 2016
    30
    Eau Claire, WI
    Frank Buckles
    I recently purchased a 1988 Mondial 3.2. Only 21 k miles. It runs great but the exhaust seems a bit to loud. Also when I start it up there seems to be more exhaust coming from the drivers side pipes than the passenger side. Any ideas would be appreciated.
  2. mseals
    mseals Two Time F1 World Champ Lifetime Rossa Owner
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
  3. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,083
    FRANCE
    All 3,2 exhausts (notably 328s) discharge more gases at idle from the driver's side pipes, this is due to the internal disposition of tubes in the exhaust box, notably the "Euro" variant (no catalysator; or is it catalycist?).
    Rgds
  4. ronfrohock
    ronfrohock F1 Rookie Owner Rossa Subscribed
    Aug 16, 2004
    4,154
    MA
    Ron Frohock
    This picture is worth a thousand words. Thanks for posting it.
  5. moysiuan
    moysiuan F1 Rookie Silver Subscribed
    Nov 1, 2005
    4,185
    Canada
    Hard to believe the muffler is a problem with the low mileage. I would first take a look under there and see any signs of perished "doughnut" gaskets at the various cat and tube junctions, make sure the O2 sensor and slow down light thermistor on the muffler are tight (assuming its a US model with the single entry pipe and cat, not the euro catless model pictured in this thread), etc. i.e. check for system leaks. Also make sure the exhaust "spring" hangers and brackets are all in good order and tight, could be the muffler or tips are hitting the grill or something while vibrating with the engine on.
    I also note that looking in from the engine bay there is a check valve (# 3in pic) on each bank which is part of the air injection system, these can rot away and fail /leak and sound like an exhaust leak. Wiggle them around as they may look ok at a glance, they corrode from the inside out. Other items relating to the air injection (#4) or test pipes that are on each exhaust manifold (#30 and 52 in second pic) might also have corroded, usually where they join the manifold. Should be able to tell with a visual inspection, or might use a stethescope to pinpoint a noise source for greater certainty while the engine is running.
    More remote issues could be a cracked exhaust manifold, and leak at the manifold gasket, but this is so uncommon I would think not likely but anything's possible with a car this age. My bet is the check valves or test port corrosion.
    Beyond that, most people complain the Mondial is not loud enough in stock cat/muffler form!
  6. jgoodman
    jgoodman F1 Rookie Silver Subscribed
    Aug 29, 2009
    3,267
    Central PA
    Jay Goodman
    I bet one of the exhaust gas sensor sampling ports is broken/rusted off the manifold. Part 22 or 30 on the diagram. Design weak spot.
  7. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    Mine started getting noisy, doughnut joint leaking, lots of popping when going down hill in 3Rd gear and off the throttle is a good indication. Also a huge loss in power with these engines when the exhaust leaks.
    I fixed it and power was restored. Good luck, Bell
  8. moysiuan
    Nov 1, 2005
    4,185
    Canada
    Does anyone actually use the exhaust gas analyzer ports to diagnose anything? Seems like a good idea to have but in practical terms who has actually used or benefited from this type of refined testing? Anyone removed/replaced them without busting things? Mine are fine but do look rusty where they attach at the manifold, and I always wondered whether these things would be a future problem and would be best to proactively replace?
  9. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    Those pipes are a convenient test point for misfiring cylinders. Run the engine from cold for a few minutes, then try to hold your finger on the test pipes. If you can, then that cylinder is not firing.
    If your pipes are rusty, you could soak them in Metal Rescue, then paint with VHT.
  10. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    Per Andy's comment above. I had a check valve fail on mine. At that point it is an exhaust leak and quite loud.
  11. Bell Bloke
    Dec 6, 2012
    1,839
    Assuming that the engine appears to be running well, the mixture test I do is as follows.
    To check fuel air mix and engine running I do a plug colour check. This check I do on hot idle, then at 30 mph at 50mph and at 70+mph these tests I do at those steady speeds in turn, I pull over at a set spot and instantly shut down the engine, pull the plugs and note the colours. This I do 3 times for each of the speeds. It normally takes me an hour and I have a good quiet road to do it on. The alternative is to but a rolling road or hire one.
    Regards Bell
  12. buck74
    buck74 Rookie
    Dec 14, 2016
    30
    Eau Claire, WI
    Frank Buckles
    Thank you guys for all of the information, it is quite loud, so I know something is going on. It runs great however.
  13. Jeka
    Jeka Formula 3 Silver Subscribed
    Nov 20, 2010
    1,181
    Rotterdam
    Johan
    And you are sure it's not an after market sports exhaust?
  14. buck74
    buck74 Rookie
    Dec 14, 2016
    30
    Eau Claire, WI
    Frank Buckles
    Turns out the inside of the muffler is shot. Trying to find one has been a challenge. The prices where they can be found are all over the place. There is a used one on ebay for $700, it might not be any better than the one I have . :) Maybe I should go into business making after market sports car mufflers. :)
  15. Wade
    Wade Three Time F1 World Champ Owner
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Before you reinvent the wheel, look up Russ (snj5) and his hot rod 3.2 Coupe. He designed and developed an exhaust or two.
    For example:
    http://www.ferrarichat.com/forum/mondial/192175-carb-mondial-update-bit-technical.html
    http://www.ferrarichat.com/forum/mondial/127652-mondial-modification-upgrade-list-also-308-328-a.html
  16. David Lind
    David Lind Formula 3
    Nov 19, 2008
    2,248
    David Lind
    My 88 1/2 Mondial 3.2 has exactly the same characteristic of what appears to be more exhaust discharge from one side of the muffler. Furthermore, it's done it w/ 2 different exhaust systems. Two experts on these cars have told me it's normal.
  17. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,958
    Isle of man- uk
    My 87 mondial box was welded back together 3 times before i junked it, the original ANSAs were not very good and rust away.
  18. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,958
    Isle of man- uk
    Check the pipe connections as the 3 sided flanges tend to rust away and the firerings become a bit loose and leak when cold
