mondial 3.2 front seat belt removal | FerrariChat
Discussion in 'Mondial' started by ENZ10 1, Feb 15, 2008.
  1. ENZ10 1
    ENZ10 1 Karting
    Aug 22, 2006
    87
    stoke on trent
    john stephenson
    Before I tear the car to bits on the weekend, any tips for removing the front seat belts, seems the rear seats have to come out, Im not removing the centre console recievers, just the belts on the pillars, any help appreciated thanks
    js
  2. MondialTCab
    MondialTCab Formula 3
    Sep 5, 2001
    1,020
    Pacific Northwest
    John Michael Gross
    dopnt know how much different the ounting points are for the 3.2 vs the T Cab but it should be fairly straightforward. The rears are held in but two nuts under the seats...deep socket needed. 10mm if I recall but it has been a while.
  3. CAustinWillis
    CAustinWillis Rookie
    Aug 19, 2024
    7
    Charles Willis
    I also am dealing with a sticking seat belt on the passenger side .... It has become annoying for my wife so Ill order a spare ... my question is are there any reprint copies of service manuals for these cars ? mine is a 3.2 version coupe..
  4. moysiuan
    moysiuan F1 Rookie
    4,188
    Canada
    You can probably adjust the orientation of the belt cartridge, it can move with all the tugging over time. Needs to be straight up and down where the belt enters the spool.
  5. Alden
    Alden F1 Rookie
    3,607
    Central Florida
    #5 Alden, Aug 30, 2024
    Getting at the seat belt mechanism is somewhat tedious.
    My passenger side belt (right side)was sticky too, it would only extend a couple of inches at a time and retracted slowly. I used an endoscope ($60 on eBay) attached to a long straw from a can of silicone lubricant, carefully fit it in the opening next to where the seat belt exits the rear seat trim and sprayed the mechanism with the seat belt fully extended so I didn't get silicone on the belt itself, let it dry for 30 minutes or so and then operated the belt mechanism several times. Now it operates as good as new!
    I did think the same thing to the driver side belt mechanism (left side) and it improved the operation of that one too!
    Alden
    ronfrohock likes this.
  6. Alden
    Alden F1 Rookie
    3,607
    Central Florida
    To answer your original question, I seem to remember that there are downloadable copies of the WSM, but I can't seem to find them right now, it might be worth it to just go ahead and buy a WSM and parts manual for your car, also, get a color wiring diagram while you're at it from Afterburner!
    Check out this thread too, can't seem to copy and paste the link, but here's a screenshot for you to be able to find it.
    Alden
  7. Alden
    Alden F1 Rookie
    3,607
    Central Florida
  8. CAustinWillis
    Aug 19, 2024
    7
    Charles Willis
