Mondial 3.2 Oil Cooler Fan Test | FerrariChat
Discussion in 'Mondial' started by aleib, Oct 20, 2023.
  1. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    Hello,
    Never seen it working son far, even when the water fans are working ... So
    1) is the Oil cooler fan triggered with water radiador fans? (Or it's independent)
    2) is there a easy way to test it? Eg If it's based on Oil temp, to disconnect the sensor and put some resistor to simulate hight temp and trigger the Oil fan.
    Thanks !
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Looking at the drawing the temp switch is on the side of the rad, midway between the 2 oil pipes, it will be either short together or pull one wire off to get fan to cut in
    aleib likes this.
  3. schelle_pelle
    schelle_pelle Karting
    Oct 22, 2021
    203
    Berlin, Germany
    Mine kicks in, when Oil is somewhere around 90°C. It's pretty loud actually and I was wondering if it's something one could overhaul and make better?
    aleib likes this.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Grab hold of the fan and see if its tight or the bearings are rough when you turn by hand. Any lift in the motor shaft ?
    aleib likes this.
  5. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    Yes i just read other threads, it's triggered by a Oil Thermo switch in the Oil radiador , it's just short these and the fan must go on.... Will do that and take some pictures, thanks !!
  6. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Only way to test thermal switch is to remove and put in hot water with a multi meter connected, to see if it switches over
    aleib likes this.
  8. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    are you sure is not over 100C the oil thermo switch switching point? I read something like 117, at that point water is on the air :)
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Not sure what temp it works at, the new switch is available @£117 ea. i was thinking it was under 100
    If you could find out set temp, it would be a standard part for a german car maybe
