Mondial 3.2 oil cooler wiring | FerrariChat
Discussion in 'Mondial' started by GeorgieM, Aug 4, 2021.
  1. GeorgieM
    GeorgieM Rookie
    Dec 16, 2018
    27
    George Melanis
    Does anyone know where the relay for the oil cooler fan leads to. I have three wires and it appears an aftermarket relay. One goes to the fan obviously. The other to a power source. I thought this was the starter power cable but a diagram appears to show it goes to the ignition coil and the third I assume goes to some sort of sensor on the block to signal that the oil needs to be cooled via the fan. Any ideas?
  2. Steve Magnusson
    26,829
    #2 Steve Magnusson, Aug 4, 2021
    The SPC shows the sensor (thermoswitch) for the oil cooling fan is item 15 mounted on the oil cooler radiator:
    https://www.ferrariparts.co.uk/diagram/ferrari/32-mondial---cabriolet/022-lubrication-system
    (But I recall that there should be 4 wires on the relay -- +12V power to run the fan motor, the connection going to the fan motor, +12V from the ignition system to run the relay coil, and the ground signal from the thermoswitch, when closed, to the other side of the relay coil.)
  3. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
  4. afterburner
    afterburner F1 Rookie
    3,471
    Switzerland
    Urs STEMMLER
    On the US quattrovalvole diagram, there is no relay in the circuit controlling the oil cooler fan:
    - the negative wire controls the fan via the dedicated oil cooler fan thermo-switch
    - the positive is ignition controlled
