Mondial 3.2 Oil level check | FerrariChat
Discussion in 'Mondial' started by Nasa1990, Jun 22, 2022.
  1. Nasa1990
    Nasa1990 Karting
    Sep 18, 2019
    148
    Belgium
    Hi guys,
    There probably is a straightforward answer to this... but I'm having difficulties interpreting the oil level when measuring with the stick. With all my other cars in the past, the level is actually very easy to see.
    But the stick in the Mondial looks completely different to what I'm used to and I can't see the line of the oil level on it.
    It has been topped off about three months ago, but drove a fair amount since then. After a long drive yesterday the oil level light came on, so I disconnected the sensor and checked the oil level manually. The warning light doesn't always come on by the way.
    Any pointers on how to "read" the results on this stick?
    Thanks!
  2. Nasa1990
    Nasa1990 Karting
    Sep 18, 2019
    148
    Belgium
    I'm guessing it's below "MIN" currently, but not sure. I haven't checked it yet when it was correctly topped off. Is the line more clear when the level is below MIN and MAX?
  3. ronfrohock
    ronfrohock F1 Rookie
    4,156
    MA
    Ron Frohock
  4. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    446
    Eastern Tennessee
    Howard Scott
    Same as the one in mine, and it is a pain to read with clean oil. Keep in mind it should be read after the car has run up to operating temp, and then allowed to cool for 10-15 minutes. Checking it cold isn’t really accurate.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Just put your finger on it until you find oil, the oil is hard to see given it is very clear
  6. FerrariJB
    FerrariJB Karting
    Jun 8, 2019
    69
    Netherlands
    FerrariJB
    Lay it directly on a piece of toiletpaper for example, roll it a little bit and you can see on the paper where the oil is on the dipstick and where not.
    Verzonden vanaf mijn iPhone met FerrariChat
    ellum likes this.
