Mondial 3.2 ported/polished head/big valve/big cam/header upgrade | FerrariChat
Discussion in 'Technical Q&A' started by snj5, Mar 29, 2007.
  1. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    As most know, I converted the Mondial 3.2 to Weber 40DCNFs 5 years ago. The final rear wheel dyno showed numbers similar to a Ferrari 348, with 243 SAE rwhp and 203 ft-lb of torque. These numbers were unchanged for either 34 or 36 mm venturis, and almost the exact same numbers generated with a higher lift longer duration (.367, 235*). So, combining this with the shape of the hp curve and with some certainty, we can say that the head flow now limits the power.
    Old FChat poster Kermit had measured the head flow in the mid 90s CFM, and current supercharger Yoda Mark Eberhardt and his cylinder head specialist, Vic, place it similarly on a test QV head (QV and 3.2 heads are virtually identical). After several modifications, Vic now has a test qv head with larger intake valves flowing at around 112 CFM still with very high intake velocity (highest he has seen in any cylinder head) with stock cams. This is a flow increase of approximately 18%. This will be the maximum flow this head will generate without losing any velocity – i.e., the best street set-up in a cylinder head.
    The test head is being sent to Laurie at Webcam to be used to develop the maximum safe lift intake cam specs for the QV engine. Issues such as interference and compatibility with the stock shim over followers will be worked out and the maximum reliable safe lift determined with this head - we're hoping for around .400 lift and keeping the duration around the stock 220. The duration will be similar to stock or a bit over to keep the same rpm power band as stock. This may cost some high end hp by keeping the rpm band lower, but the low end torque will be spared or increased. Interestingly, with the similar durations this cam could be used with QV K-Jetronic engines. This could be the ultimate street QV cam.
    The maximum safe high-lift quick ramp cams will be installed on the ported, polished big-valve 3.2 liter engine. Carobu states that they have had as much as 340 engine dyno hp on 34mm venturi DCNFs showing adequate flow for this hp, but the carbs will have 36mm venturis (the largest side available) for initial testing. The exhaust will have provision for the wide band LM-2 A/F meter to tune the jetting. With the velocity remaining high, I am unsure which way the jetting will go.
    We will keep the same pistons. The combustion chamber will be measured to determine actual compression ratio, and we’ll see if anything can be done short of new pistons to raise the CR a bit. Since this car is a street and trip car, it is nice to have safety from different gas options at less than 10:1 compression in this application - would like to target around 9.5 - 9.7 if possible.
    The exhaust will be a set of port matched Tubi stainless Euro exhaust headers that will be ceramic coated inside and out leading to a true dual exhaust. The exhaust is modeled on the Euro Ansa and other Ferrari V-12 applications, but spec’d for very high flow and a smoother tone and moderate sound volume more acceptable on trips. This will be the Grand Tourismo tuned exhaust.
    I’m hoping this will take about 6 weeks, then tweak the carbs over a few weeks, then do another rear wheel dyno to tune and will post results.
    I’ve always wondered what an all-out hand massaged and prepared tuned and tweaked naturally aspirated Ferrari engine would be like. This will be pretty close to the max tuned naturally aspirated street engine. Many thanks to everyone in the subsystem threads (air cleaner, carbs, performance cams, headers, exhaust, etc.) that have helped so much. Even the P3/4 threads inspired this project to see the engineering, craftsmanship, art and beauty that reside in the heart of every Ferrari – the engine.
    All advice welcome.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    SUWEET!
    I'll be following this with great interest.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    I'm dying to see what Laurie comes back with on the cams. The stock ferrari cams have very mild ramps by modern standards, so there should be a lot of room for improvement.
  4. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    +++++++1
  5. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Engine is out
    Heads are off - will be shipped out Monday with manifolds and a carb for flow benching.
    compressions: 175, 181, 191, 190, 200, 188, 191, 197
    leakdown: 15, 28, 10, 12, 10, 10, 14, 11
    Will be measuring CC volume and doing a block compression check. James feels that the valve work will certainly tighten up the numbers.
    Headers off to be ceramic coated.
    Will also be doing an engine bay clean-up
    Pictures next week.
  6. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Russ,
    I, and a huge number of guys are behind you on this, even if we cannot take it as far as you are.
    Deep in the heart of every hotrod mechanic, is the desire to really build it to the max, to really do it right.
    best regards,
    chris
    P.S. will that 3.2 head fit on a lowly 308 :)
    Or will i have to go to bigger liners and pistons too.
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    I'm having my 308 QV heads done at the same time, they are at the shop waiting for Russ's and the word for Laurie to know what cam to set-up for.
    There is also a 308 2v head at the shop waiting to get tested to see exactly what can be done for them....but it looks like a lot.
  8. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    I have heard that the qv flows significantly more and will tolerate more compresion.
    As my grandfather said about the hereafter, "If there is something more, I will be pleasantly surprised"
    thanks,
    chris
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    The QV/3.2 ports were a bit buggered and the 2V port looks significantly worse. Once the port (2V) is fixed, I would expect it will perform close to the 4V, if there is enough metal in the casting to fix it without getting in to the water jackets (Vic was a scrap head Wil sent to answer that question). We'll see soon enough I guess.
    One thing is for sure, the stock 2Vi/QV/3.2 intake has runners that are just too small and can't be salvaged....well maybe with a cut and weld job, but then it's easier to just make a new one.
  10. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Cam issues were covered in-depth in the Tech Section ‘Performance Cam Regrinding’ thread, but here are the much oversimplified basics.
    The exhaust valve does not need to be enlarged – in fact, many strongly claim it is too large in the stock application. There is an empiric desired ratio between intake and exhaust flow, so in a practical sense on our cars, it is good to keep the current exhaust and focus on the intake (also saves $).
    The stock 328 intake cam has:
    .343 lift
    intake - 16 btdc to 48 atdc (244 duration @020); Lift @050=224
    My current cam has:
    .368 lift with 235@ .050 duration (total 261 @ .020)
    As stated before, the new cam generated the same hp figures as the stock cam since the head was actually the flow restriction. Interestingly, we did not lose low end with the increased duration.
    I know some cams have run as much as around .400 lift; The reported clearance between valve seat and piston to prevent interference is about .100 . Since we are going to larger valves, getting this clearance right becomes an issue. Another issue is at much larger lifts, reliefs must be cut into the head to clear the cam sweep and you may flip off the shim. In our application, the goal is to keep the stock shims and not cut the reliefs. If flow is significantly increased from .368 to .400, then will add lift. I may actually almost have all the cam I need now, but we’ll see.
    Since the goal is to keep a strong low end, will probably keep near or only slightly increased duration. Duration has a lot to do with the power rpm range, and I would like to keep this around stock for a street application. May keep what I have since the low end stayed the same as stock. Lift adds power (to the extent the head can accommodate it) throughout the band.
    More as things develop.
    best to all
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    Don't forget that the low lift flow numbers are WAY up with a 100% gain at .050" lift. That means the low lift portion of the cam will be much more effective and allows much less duration to produce the same flow graph. It should also make any problems with excessive duration that much more pronounced....you want to be careful with duration and using pre porting data to predict and post porting results.
  12. WilyB
    WilyB F1 Rookie
    4,284
    AZ
    Would all your research be also applicable to a Mondial T? It is stock currently at 247.8 RWHP / 197.6 RWTQ.
  13. t024484
    t024484 Karting
    Nov 9, 2006
    171
    Netherlands
    Hans A. Polak
    It is hard to understand what you say. If you are telling that a shorter duration fast ramping cam gives more power than a longer duration slow ramping cam, I am with you.
    It seems indeed that this happens to be the case with the cam that sjn5 is planning to use.
  14. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Yes, and the 3.4 liter heads already are a better design than the 3.0/3.2 qv; I would also recommend you look ar the 355 manifold on a 348 threads in the 348 section for more specific (and enthusiastic) discussion, but the cam/head flow discussed here applies to the 348 qv engine as well.
    Have fun
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    What you are saying is right of corse, but not what I was talking about.
    The stock head has a flow profile for flow vs valve lift, I don't have it in front of me, but it's about 23cfm @ .050" lift going up to 92 @ .350" lift. The ported heads profile is about [email protected]" lift going up to [email protected]" lift. The ported head flows 100% more air at .050" lift and 21% more at .400" lift. You can see that a lot more air moves at very low lift of the valve in the ported head where the stock head needs to get to about .100" lift to flow 46cfm.
    The effect on the top end is like having a longer duration cam and the computer modle say the on a 3.0 liter, the peak hp with stock cams will move from about 6800 up to about 7800. That is the same thing you would expect if you added 15 degrees or so of duration to the cam.
    The big difference between making hp by porting vs camming (assuming enough head flow on the cam only engine to be able to compare the engines) comes in the bottom end performace. Adding duration increases valve overlap and blow-down causing the engine to lose low end power at about the same rate it's adding top end power. The ported engine however does not increase valve overlap and does not lose any low end power, provided of couse the port velocity remains at least as good as it was prior to porting.
    Does that make any better sense?
  16. WilyB
    WilyB F1 Rookie
    4,284
    AZ
    I have been reading all those threads with considerable interest and I am in awe when I see all what you guys do.
    I baselined my Euro spec Mondial T at 248 RWHP. My aim is to bring it slowly but surely towards the 300 RWHP mark without spending a king’s ransom.
    Early this coming week I should receive a Stebro exhaust and test pipes. This, plus a remapping of the ECU should hopefully bring 20 to 25 more RWHP, so I would be halfway there.
    Back in 1972, I rebuilt a Honda 750 engine (new carter). I installed 4 pistons from the 450 twin, bringing the displacement up to 817 cc, had them balanced etc and took the head to the shop that was doing the porting/honing for the Renault Gordini Rally Team. I discarded the airbox, re jetted the carbs, removed the mufflers while keeping the original exhaust and used my girlfriend’s pantyhose as air filter!
    The end result was spectacular. It was the only ’69 CB750 that would routinely lift its front wheel.
    I guess this is more or less what I am attempting to do again! :)
  17. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #17 snj5, Apr 5, 2007
    Here is the engine out now minus the heads. It does come out in a compact package. This will also some more engine bay detailing (wish Spasso was here to help!).
    Now - the challenge of the intakes. Since I've gone to the dual plenums, I am using the low rise radiused intakes to give more volume in the individual plenums. The stock air horns WILL fit, but there is only about .5" - .7" clearance between the top of the air horn and the top pf the plenum. With these shorter ones, I get over 1" to the top of the plenum. Since I want to keep the stock bonnet height, really cannot make the plenum any higher. So, will probably have to come up with a more clever way to do this - it's kinda kluged now as you can see, but if any of you can make some short airhorns, pm me...otherwise I'll come up with something a bit nicer. Of course, I could always go back to the stock airbox sans internal filter and duct it to a large K&N cone at the side duct.
    Still waiting on intake cam data, but I'm still intuitively thinking intake lift to .400, quick ramp, stock or slightly longer durations. Someimes I think I may stay with my .368/235s.
    Headers are off to be ceramic coated, and mufflers and resonators are ordered.
    Will hopefully know more this week. All advice appreciated.
    best to all
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    In the immortal words of Flounder:
    “this is going to be great”
  19. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yes it is.
  20. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Here are some measured specs off our 1988 3.2 liter US spec engine from the Mondial 3.2:
    Dish Vol.- 25.6cc
    Piston Deck- .020" plus (above block deck)
    Gasket- 3.312" x .061" (compressed)
    Bore- 3.268"
    Stroke- 2.90"
    These numbers will be used to calculate the actual compression ratio and used in the computer modeling. I imagine they are the same for all US 3.2 liter engines (328 and Mondial).
  21. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #21 snj5, Apr 6, 2007
    In addition to the tubi Euro headers, the s/s exhaust silencers came today - 4 Magnaflow dual in / dual out units (two per side) followed by four resonated tips. The system will be a true dual exhaust with each bank having non-connecting flows.
    To briefly review from the several ( "exhaust-ive" :) ) exhaust threads, each side will use 2.5" s/s mandrell bent tubing in a system that is a combo design of a flow enhanced Ansa qv system and a 250 GT TdF sytem folded twice. There are minimal bends in the system, and the 2.25" tubing is more than flow adequate. The goal tone is to be smooth and tonal enough to be pleasant as a daily and on long trips, but still sound like a Ferrari.
  22. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Vic and Laurie are now going to test an qv intake cam with:
    Total lift: .400-ish
    Duration [email protected]
    Rapid ramp opening
    This is a bit more duration than stock, but less than the current 236; the lift is more than the current .368 and WAY more than the stock 3.2 .348 and WAY WAY more than the 3 liter qv .
    We were even talking that keeping the fairly near stock durations, this cam would be compatable with K-jetronic injection; I think to at least 270 hp on a 3 liter qv with the stock head (this is what a stock Euro 3.2 makes with K-jet).
    Although it is very early to predict final numbers, the computer says the output may be as high as 330 - 340 hp at the flywheel and keep the same or more torque (240+ ft-lbs) in the same power band. This is based on head flows keeping about 20% over stock at all lifts, which is what the test head flowed (with a target max of about 110 - 112CFM@10" versus a stock 88-89CFM@10").
    Should be interesting - we are about 3 weeks away from finishing the heads if all goes to plan, and will know the final flows with the carbs. Will take a while for me to fully tweak the carbs, but will have an initial rough dyno to get a starting point in a mos or so.
    Thanks to Vic Chichester, Webcam, Carobu and Norwoods for all the great work and advice.
  23. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    The heads are apart now, and there was one leaky exhaust valve and pretty well pooped out seals.
    "Raising static compression is a band-aid for poor head flow"
    Discussion with Vic today focused around compression and flow. He said that the remembering that one idea is to get the most pressure in the cylinder, you can do that with actually flowing in more air or raising the static compression. He stated that my head may not need that much more compression if the head/cam are flowing in that much more air.
    This was a new concept for me.
    There was one cylinder that had a much higher pressure test (200) than the others (175 - 190), and that it may have shown some signs of detonation. With the other cylinders not flowing as well, this one cylinder was genertating enough pressure to come close to detonation. So the issue is, once ALL of the cylinders are flowing well (targeting around 210), I may need to come BACK off the current 35 degrees of advance down closer to the factory stock 32.5 or 31 as all of the cylinders will be drawing in much more air and generating much more pressure for the same combustion chamber volume. Vic said it was not uncommon to bring well flowing efficient heads down to advances of 30 degrees, or even less. This also fits with why 2 valve engines can run greater advances as they dflow more poorly, i.e. less efficient. We'll address the issue as the engine goes back together, but certainly a fascinating concept. Especially interesting as I will be running on pump gas.
    Because I did not lose any bottom end when I increased the cam duration, the new cams may instead keep a little more duration than the original plan to have stock durations. The flows will be calculated and we'll see. Laurie at Webcam is running some profile tests now.
    Spoke with Mike Pierce at Pierce Manifolds today about increasing the size carburretors. He said that the carbs are still likely to outflow the head, and typically a barrell of a 40 DCNF with 36 mm chockes is good for about 400CFM; so with the head flowing at 110 - 115, we should be ok with the 34 or 36mm venturis. With the increased flow, the current settings will probably be too rich and require smaller jetting.
    So big lessons for today: With increased head flows, we'll start off with a much lower ignition advance due to higher cylinder pressures, and expect to go down a jet size.
  24. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I ordered a new set of tires for the Mondial to achieve two goals, remembering that this is not a track car so ultimate grip was not as much an issue as having a good street GT. This is somewhat cross-posted from a tire thread, but it fits in with this thread as well for completeness.
    1. Lighten steering and keep it precise. Previously had 225/50 Pilot A/S on 7.5" rims. Ordered a set of PS2 205/55 to reduce contact patch and have the widest rim for the same wall height as the previous 225/50. While I will lose the all wx capability I needed in DC, I don't need it here in San Antonio.
    2. Functionally have a taller final drive to take advantage of increased torque. I had looked at different drop gerars and even ring/pinion, but figured out the easiest and WAY WAY cheaper way to do it would be by upsizing the wall height on the rear tire. The previous 245/45 P A/S on a 8.5" rim had a height of 25.8 and rolling ratio of 811 revolutions per mile. By going to a newer technology higher grip tire in a PS2, am trying a 235/55 on the same rim, again the widest rim recommended for the tire. The new tire height is 26.6" with a rolling ratio of 777 revolutions per mile. Using tire sizes, I have functionally reduced my differential ratio by 4.3%, taking the original 4.06 ratio and funtionally making it more like a 3.86 (essentially the Mondial 3.2 Euro spec 3.82). This slightly reduces the cruise rpm from about 20 mph per 1000 rpm to about 21 or so (about the same as the Euro spec 3.2 and Mondial t). I do not worry about speedometer error as it is so wildly inaccurate to begin with, and if anything, this makes it closer.
    I do have adjustable spring perches, so ride height adjustment is not as big an issue. I've heard that PS2's have a good ride and very good steering response with the newer technology rubber. Coincidentally, these are the same f/r tire sizes on a newer Porsche Boxster and have the N0 designation. I ordered the tires today, so I'm hopeful this will work out.
  25. plugzit
    plugzit F1 Veteran
    7,792
    Redondo Beach, CA
    Bruce Bogart
    There's nothing that looks quite as good as a brace of webers on top of a motor-gonna be nice.
