Mondial 3.2- sweating blow by hose--Issue? | FerrariChat
Discussion in 'Mondial' started by JoeZaff, Aug 11, 2008.
  1. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    #1 JoeZaff, Aug 11, 2008
    I conducted a thorough inspection of the engine last night and noticed that the small blow-by hoses (3" maybe) that attach to each cylinder bank are moist to the touch and have a greasy feel to them. Neither hose appears damaged in any way, and I know they were tightened about a month ago, when I first got the car. Is this normal? If not, they appear simple enough to replace, is there anything I would need to know before removing the clamps and swapping them out?
    Most importantly, is this something that needs immediate attention or can I continue driving it until I get the parts.
    As always, any help would be greatly appreciated.
  2. rizzo308
    rizzo308 F1 Rookie
    2,764
    Perth, Australia
    riggio
    shoot down to ur local auto shop buy some 5/8 heater hose.... cut the old ones of simple job 1/2 hour or so .... good luck
  3. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,843
    Mike 996
    #3 mike996, Aug 11, 2008
    There is oil vapor present in those hoses - it might be that the hose somebody used is not the proper oil-resistant hose. If it is not oil resistant, it will bleed oil through the wall of the hose after a while and then the hose will fail. Though sometimes folks use standard vacuum line hose or heater hose because they have it handy, it should be hose that can handle oil. PCV hose (hose designated for Positive Crankcase Ventilation use) is sold for specifically that purpose.
    In any case I'd suggest you obtain some new PCV hose and replace the existing hose.
  4. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    Thanks guys. I found some high quality PCV hose in 19/32. Is that the correct measurement, or will it be too small?
