Mondial 8 Black Out! internal light ! Help | FerrariChat
Discussion in 'Mondial' started by BlackMondial32, Jun 12, 2009.
  1. BlackMondial32
    BlackMondial32 Karting
    Aug 27, 2007
    244
    Today i open the light , run the key, but the internal light of dashboard, and air control panel are without light! total black out
    i try to use the rheostat located down on the lamp red clock, but not working!!
    Causes ? fusebox problems or internal dashboard problem?
    some can help me ?
    i'm very sadly!!
  2. mondial5183
    mondial5183 Karting
    Nov 17, 2007
    80
    Hi, sorry for my poor english, i m french.
    First check your fuse but I solved the same problem a few months ago. Indeed, i had a failure on the printed circuit board of the rheostat (the same for odemeter, clock and lights for all internal). One track was broken. So i made a bridge and then it's fine except i couldn't use the rheostat but the light of my dash board is ok.
  3. BlackMondial32
    Aug 27, 2007
    244
    exactly!!
    not worry for your english! i'm italian (same blood of supercar ) , i check the fusebox, and i find the fuse burned, replace it and after try to turn the key, but not working, after i try to move the rheostat, and after two movements light are back!!
    Very strange.... if i use the rheostat the fuse jump!! Strange gremlin!!
  4. mondial5183
    mondial5183 Karting
    Nov 17, 2007
    80
    My failure becomed with the same symptoms...One track was stick out, so when i touched the reosthat sometimes the lights were ok, and sometimes no. Then the track overheated and broked...so no definitly no lights until i made a bridge
  5. BlackMondial32
    Aug 27, 2007
    244
    originale fuse 15, now i use a 20, if broken i try with 30! if burn i made a bridge
  6. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    this is another common mondial problem - the light rheostat. It is over sensitive and can easily burn the interior light fuse.
    Many people wire around the rheostat like mondial5183 or set it and don't touch it (what I do).
  7. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,664
    Argent/Brasil
    Guido
    Dont put stronger fuses...it will not help solve your problem...only make it wurs. The internal contacts on your fusebox layers will burn and melt the plastic.
    Guido
  8. BlackMondial32
    Aug 27, 2007
    244
    tomorrow new black out
    unfortuantely fuse 20k it's ok , i dont' see burned parts in fusebox
    i must open rheostat and made a bridge in rheostat ?
    it's only way ?
