Mondial 8 Clutch Question | FerrariChat
Discussion in 'Mondial' started by Fortunato, Nov 15, 2009.
  1. Fortunato
    Fortunato Rookie
    Nov 15, 2009
    20
    Markham
    Carmine
    Just bought an 82 Mondial, don't know if the clutch is working properly, it engages very quickly i.e. right at the start of depressing the clutch, not sure if this is correct? I am not used to hydraulic clutches. Any advice on how to know where the clutch is supposed to engage?
    Thank you in advance.
  2. Vivaldi
    Vivaldi Karting
    Aug 1, 2001
    83
    SoCal
    Alex Vivaldi
    #2 Vivaldi, Nov 15, 2009
    According to the workshop manual, you should only have 2 to 3 mm of free play. If you really want to find out exactly how your clutch is disengaging, jack the left rear of the car, remove the left rear wheel and inner fender liner foward piece, support the car on a jack stand for safety, then watch the clutch slave rod and linkage move downward as someone is pushing the clutch in. You should see approx. 2 cm of downward movement total.
  3. Fortunato
    Fortunato Rookie
    Nov 15, 2009
    20
    Markham
    Carmine
    Thanks for the advice. If only 2-3 mm, then I should be OK. It seems small, but if those are the specs then I am ok! Thanks again. Any advice on a sunroof that doesn't work? The motor is working but the sunroof is not going back.
    thanks again
