Mondial 83 QV "fuel pressure regulator" Question | FerrariChat
Discussion in 'Technical Q&A' started by AAmsden, Mar 12, 2025.
  1. AAmsden
    AAmsden Karting
    Sep 24, 2017
    57
    Washington
    Andrew
    I have a 1983 Mondial QV Coupe, I have been told I need to replace my..
    there's lots of names for this part:
    "Fuel Pressure Regulator"
    "Warm-Up Regulator (WUR) "
    "Control Pressurer Regulator"
    My question is the parts for sale on the internet sites list it as a Bosch Fuel Accumulator.
    or specifically a Bosch Accumulator - 0438170004
    Is that the same part as the above three part descriptions?
    Sorry for dumb but hopefully simple question.
  2. fatbillybob
    Aug 10, 2002
    28,730
    socal
    I owned an 85qv. Get the thin yellow Bosch k jetronic" book. It is detailed enough for basic understanding of the units MO. Every owner can benefit. It's got good pics and diagrams
    afterburner likes this.
  3. raemin
    raemin Formula 3
    Jan 16, 2007
    2,307
    Lyon (FR)
    R. Emin
    Fuel pressure acumulator is next to the fuel pump. When it leaks on the floor time to change it (except in California where the cars are equiped with a return line that "collects" the leak).
    Fuel pressure regulator is within the distributor (the grey part with many 8mm fuel lines feeding the injectors). The acumulator cannot be serviced.
    WUR is the regulator for the "control pressure" regulator. (K-JET uses two pressures, one for the whole system, one for control).
    Both the distributor and WUR can be serviced ($60 worth of gaskets and parts).
  4. Steve Magnusson
    26,632
    No, your post contains three different parts, and, unless you are restoring a car that has sat unused for many decades, there is a very low likelihood that all three would need to be replaced -- i.e., if you had a car that was running fine and then suddenly developed a runability problem = more likely just one component has a problem and you need to do more diagnosis to determine which part is the culprit.
    By who? If this is just a list of many people throwing out random possibilities for what might by the bad component = you know nothing about what needs to be replaced. ;).
    The three different components in your post are:
    "Fuel Pressure Regulator" = this is a subassembly inside the fuel distributor.
    "Warm-Up Regulator (WUR) " = these two are the same component just called different names.
    Bosch Accumulator - 0438170004 = this is a separate component.
    Do you have a copy of the 281/83 Mondial8/QV WSM? Section D (exactly) describes how the Bosch CIS K-Jet without Lambda system on any 1983 MondialQV or 308QV (both US version and euro version) operates and its components. If not, you can get a pdf copy of 281/83 here:
    https://www.dropbox.com/scl/fi/twng41f9fpi3ipww7q95v/Mondial8qv_workshop_281-83.pdf?rlkey=5sgpj4yz33jepzrec4x8lcwel&st=4o2n8ksm&dl=0
  5. AAmsden
    AAmsden Karting
    Sep 24, 2017
    57
    Washington
    Andrew
    Thanks for the WSM. Yes just bought the car and it has sat for a long time. The car starts fine but once I drive it and say stop after driving 10 miles or so.. it's very hard to start again. Had a 30k engine rebuild in 2022 but then not driven much at all (apparently.) A euro mechanic suggested these as the culprit. Thanks for your response. I will get to work on this.
  6. Steve Magnusson
    26,632
    The most likely cause for this symptom is the residual fuel pressure falling too quickly after warm engine shut off -- that's what should be measured BEFORE buying any components. If that is the issue, the suspects are (and the order that I'd investigate is):
    1. Leaking Accumulator -- as raemin stated, liquid fuel will leak out the vent nipple if the Accumulator is bad (when the engine or fuel pump is running). On the euro version, this is immediately obvious as the vent nipple is left open to atmosphere. On US versions, they added a hose on the vent nipple that goes back to the tank -- this hose has to be removed to check for any liquid fuel. If there is no liquid fuel coming out the vent nipple = almost certainly, the Accumulator is OK. If there is liquid fuel = replace Accumulator.
    2. Leaking fuel pump check valve -- no good way to test this without just replacing the fuel pump (if you've already confirmed the Accumulator is OK). One "complication" here is there are two different fuel pumps: the original stock one (Bosch 69523) has a built-in check valve; however, this can be difficult to source so can be replaced by the later Bosch 69532, but that later fuel pump has an external check valve that requires changes to the hose plumbing. We've had many instances of people replacing the early style fuel pump with the later style fuel pump and wrongly leaving the check valve out completely. Additionally, many F of this era were updated (either correctly or incorrectly) to the later style fuel pump as the early style fuel pump was not available for many years. So the first thing you need to do is determine is which fuel pump is on your car and, if updated, was it properly done, or not. If you can post a picture of your fuel pump assembly, that can be determined easily.
    3. Bad o-ring(s) in the fuel pressure regulator section of the fuel distributor -- this is more complicated, and you (and I) don't need to go there unless #1 and #2 have already been done, but the residual fuel pressure is still falling too quickly.
    raemin likes this.
  7. AAmsden
    AAmsden Karting
    Sep 24, 2017
    57
    Washington
    Andrew
    Thank you for this wonderful documented reply. Really appreciate your time in responding!
  8. raemin
    raemin Formula 3
    Jan 16, 2007
    2,307
    Lyon (FR)
    R. Emin
    #8 raemin, Mar 13, 2025
    While you investigate the issue, you can trick the hot-start mecanism as follows:
    1) floor the throtle pedale while cranking.
    2)last resort disconnect the safety switch (bosh junior plug) from the distributor.
    At least you will not be stranded (this will force the pump to operate and will let you start the engine).
  9. Steve Magnusson
    26,632
    You're welcome, and thanks for the kind words. Now your responsibility is to not ghost us, and let us know what you eventually find is the problem and what was done to correct the problem. ;)
  10. AAmsden
    AAmsden Karting
    Sep 24, 2017
    57
    Washington
    Andrew
    Thanks, Will do!
