mondial cab window motor | FerrariChat
Discussion in 'Technical Q&A' started by mikeg, Nov 4, 2003.
  1. mikeg
    mikeg Rookie
    Nov 3, 2003
    24
    Does anyone know how difficult a task it is to change a window motor in amondi cab?
  2. nc_newbie
    nc_newbie Rookie
    Nov 4, 2003
    20
    I did both of mine and it takes about a full day to do both.
  3. mikeg
    mikeg Rookie
    Nov 3, 2003
    24
    Thanks, Is it complicated and does it invlove removing all the lift cables etc?
  4. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    did mine too, make a drawing before stripping out the old! helps to have a beer or two handy as well!
  5. pnorman
    pnorman Rookie
    Dec 30, 2003
    47
    I have a new motor if you need one...Patrick
  6. TOM B
    TOM B Formula 3
    Jul 24, 2003
    1,038
    Orange County, NY
    Thomas Buckley
    I was about to replace one of my motors when my mechanic told me to try something. When the motor gets stuck-----tap it with a hammer. It worked. I spent some time lubricating the cable , tapping the motor, and working the motor work with the switch. After it was all loose and working consistently, I buttomed up the door. It's worth a try.
  7. dm_n_stuff
    Dec 10, 2003
    43,886
    26.806311,-81.755805
    Dave M.
    Also, loosen the nuts on the cover for the gears. Do not remove them completely. THen insert a small screwdriver between the plate and spray some WD40 in.
    Run the motor several times up and down, it will loosen the grease, and make the motor run with less drag.
    (I'm assuming the mondial has an arrangement similar to my Dino.)
    It made a big improvement in my car.
