Mondial Cigarette Lighter/Auxiliary Power | FerrariChat
Discussion in 'Mondial' started by soucorp, Nov 7, 2011.
  1. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #1 soucorp, Nov 7, 2011
  2. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    Just wondering how these adapters would work if the original smaller cigarette lighter has a heating element at the bottom, something does not look right ? What am I missing?
  3. Steve Magnusson
    26,786
    #4 Steve Magnusson, Nov 7, 2011
    That adapter coverts the F auxillary power socket (a.k.a. current socket) to the "US" cigarette lighter socket -- it does not work with the F cigarette lighter with the built-in heating element (as you noted). The 3.2 Mondial wiring diagram indicates that your current socket is located inside the glovebox.
    cavlino likes this.
  4. fdekeu
    fdekeu Formula Junior
    631
    Belzium
    Frank
    #5 fdekeu, Nov 8, 2011
    Steve is right
    There is a socket in the glove box and one in the engine compartment
    You can use the adapters to convert them to a 'normal' one there
    I have replaced my 'US' power socket between the front seats with a normal one (2$)
    This is also fitted in Euro cars, so not a merely 'US' thing
    Easy installation
    Now I can plug in my navigation and so on
  5. ronfrohock
    ronfrohock F1 Rookie
    4,156
    MA
    Ron Frohock
    And had it mounted under the dash on the passenger side, out of site.
    I plug my Valentine in there. The cord goes from the V1 down the dash and disappears underneath, rather than going back to the middle console.
    Much better in my opinion.
    - Ron
  6. jgoodman
    jgoodman F1 Rookie
    3,267
    Central PA
    Jay Goodman
    Totally agree. I have done the same thing but under the driver's side dash for the power to Sirius/XM. Out of site is better IMHO.
  7. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    Good call to use one of the other outlets, otherwise how would I light my cigarettes? :D
  8. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
    I assume you ran the cord across the headliner so no telltake wire trace down the windshield? Or did you simply run it down the windshield and behind the dash?
    I was thinking of mounting my V1 remote head where the clock is on the '89t and looking for another place for the clock. Anyone tried that?
    Regards,
    Jerry
  9. ronfrohock
    4,156
    MA
    Ron Frohock
    The cord is plugged into a Radio Shack Aux Cigarette Lighter Socket that is secured to the underside of the dash - out of site. I plug in the V1 and run the cord up the front of the dash to the unit which is suction cupped at the base of the window.
    - Ron
  10. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #11 soucorp, Nov 9, 2011
    I checked my glovebox, do not see any current socket anywhere, there's a built in light with on/off switch to the left, to the right, seems like a small hole -could that be it, but its too small to stick the adapter in from the look of things. I have to look it up in the wiring diagram. thanks.
  11. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #12 soucorp, Jun 4, 2012
  12. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #13 soucorp, Jun 5, 2012
    I finally figured out how my cigarette lighter works on my car. When I bought it, was missing the top or cover, just had a hole. So this is the original skinny Italian cig lighter units.
    Apparently you pull the spring loaded round thing, it causes the bottom heating element to heat up, the missing top is by design to guide a cigarette down for to get lit.
    I'll be changing this whole part out and installing a US Spec lighter/power for my electronic devices. How to and pics to follow this week.
  13. Valenzo
    Valenzo F1 Veteran
    Dec 4, 2010
    5,069
    IL & NC
    Ted
    but what will you use to light your Virginia Slims?
  14. Brian420
    Brian420 Formula Junior
    Oct 27, 2009
    469
    Suburb of Detroit
    Brian
    Mine works. its an 86, though. In fact, the 'hole' is too big. When I tried to put in my phone charger, it wiggled around and didn't stay connected. I wound some scotch tape around it to take up the space and it fits snug. It even works when the car is off. Just last night, I was using the gps on my phone and it was draining. I plugged it in, and it even continued to charge after I turned off the car and went into my destination. I wonder if a previous owner changed it already.
    Regards,
    Brian
  15. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #16 soucorp, Jun 5, 2012
    Hi Brian,
    For sure the previous owner changed it on your car. My 88 is US spec and still have the little cig lighter, can't insert anything into it that's modern. And yes, the lighter is connected to have continuous power even after keys are out. I have to be careful not to touch mine, it can heat up the element inside and can start a fire, not the safest thing to have around so that's why I am yanking it out.
    BTW, folks said there are auxiliary power in the glove box and engine bay, I have not seen any of this on my car. If you do, can you provide pics and details please.
  16. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #17 Wade, Jun 5, 2012
  17. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #18 Wade, Jun 5, 2012
  18. kouroshoo7
    kouroshoo7 Formula 3
    Jul 21, 2007
    1,088
    Kourosh
    wait, there is a glove box in the mondial?
    I had no idea! Mine doesn't seem to open!
  19. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    The early Mondial t has a glove box, but the later ones do not.
    Ferrari inserted knee padding under the dash that took up all of the space for the glove box.
  20. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #21 soucorp, Jun 5, 2012
    Thanks Wade, You da Man !
    I probably open my glove box, examined it 10 x and never knew to look at the right silver round thing, only to see that a small power chord adapter will work with this. If so, I will not replace my existing cigarette lighter. I see now where the Ferrari aid light plugs into.
    (Electrical - Accessory Plug Adapter to Cigarette - by BMW) $27 http://www.ascycles.com/detail.aspx?ID=1264
    or buy at auction:
    http://www.ebay.com/itm/COILED-HEAVY-DUTY-Accessory-Plug-Adapter-Cable-for-BMW-TRIUMPH-Ducati-MORE-/130706317990?pt=Motorcycles_Parts_Accessories&hash=item1e6eb422a6&vxp=mtr#ht_500wt_1202
  21. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    You too... ;)
    I need to get one of those adapters, thanks.
  22. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    Thanks Wade. I just bought one online!
    Let you guys know how well it works when I get it !
    Cheers!
  23. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #24 soucorp, Jun 8, 2012
  24. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #25 Wade, Sep 18, 2012
    Mike, I was just looking at this again. Yours appears to be modified/gutted. Here's what mine look like (red interior picture).
