Mondial DigiPlex MED 801A Testing | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by FasterIsBetter II, Apr 15, 2025.
  1. FasterIsBetter II
    Mar 15, 2025
    9
    Seattle, WA
    Max Weinstein
    We've done more testing, and we have more questions.
    We tested both Digiplex units' input voltage (pin 8 on the connector; yellow wire),
    • With the ignition key on, we showed 11.1-11.4 volts (battery shows 12.9V, so it's not depleted battery)
    • Cranking the starter dropped the reading to around eight to nine volts
    • Same voltage and voltage drop pattern on both upper and lower digiplex units
    We also tested the tach sensor and both TDC sensors
    • Videos of signals from the oscilloscope below for all 3
    • Signal from the tach sensor seems ok, good wave signal
    • Signal from the TDC sensors is different, intermittent
    So, now the questions section:
    • Is the digiplex voltage drop acceptable? Is that a problem, or what is supposed to happen?
    • Is what we're getting from the oscilloscope on the tach and TDC sensors indicative of functioning or non-functioning TDC/Tach sensors?
    All videos are below via youtube link
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    Hi Max,
    I'd retest the sensors. The first 2 are probably ok but the third is not looking good. Make sure you have a good ground. The problem is that those little scopes have limited sampling rate and if the time sweep is too long they miss the voltage spikes. Check out my video below. The voltage scale is 10V/division. The time sweep starts at 5 ms/ and then I change it to 10ms/. You can see how the scope trace changes with a 10 ms sweep. If I make it longer it would look like you first 2 videos. You may have to experiment with the time setting to get a good trace. Mine were with the car idling at 1000 RPM. If you car cranking figure 200 RPM which suggests about 25 to 50 ms scale.
    If the rpm sensor is bad at lease it's the easiest to replace.
  3. Steve Magnusson
    26,932
    #28 Steve Magnusson, Apr 18, 2025
    Those voltages are OKish. What you've got wrong is the time base on your oscilloscope is way too slow (I've got that same little FNIRST unit). You need the middle balloon of the five balloons at the bottom of the screen to be something like 10mS or 20mS -- see page 15 in the Instruction Manual. The balloon labeled "5" is the horizontal time base for a major division. Using the thumbwheel at the top left of the unit is how you highlight each balloon -- hold the thumbwheel to the left until balloon 6 goes blue, then release. Then hold the thumbwheel to the left again until balloon 5 goes blue and release. Then use the up-down arrows to change the value in balloon 5. Use the same method for the other balloons as necessary/desired, and when done use the thumbwheel to the right and release as necessary to get back to RUN. Balloon 3 should be something like 2V or 5V, balloon 4 = 1X, balloon 6 = not sure but either AC or DC coupling should be OK. Fiddle with this until you get a reasonable looking signal for the Tachimetric Sensor. The TDC sensors are more difficult because the pulses occur very infrequently.
    With that said, just use your multimeter set to AC volts as an initial check to make the same measurements. The Tachimetric sensor should have an output like greater than 1.5V AC during starter motor cranking, and the TDC sensors should have an output like greater than 0.1V AC during starter motor cranking. Then you can try to figure out that user-hateful FNIRST manual and how it works -- it's truly horrible ;).
  4. Steve Magnusson
    26,932
    Mistyped -- should've written "top right of the unit".
  5. FasterIsBetter II
    Mar 15, 2025
    9
    Seattle, WA
    Max Weinstein
    alright, we completed new testing:
    the TDC sensors both looking exactaly like johnk's, and the Tach is giving off a nice sine wave. I think both are working well. all sensors within operating voltage as outlined by Steve M.
    The only problem that is realy visible right now is the voltage levels. we replaced the battery, which is giving us around 13 volts. at the digiplex, this falls to around 11 when on and 9-8.5 when cranking. to the coils, we're getting a 10 volt ignition trigger. In a move of stupidity, we put the ociliscope from spark plug extender for cylinder 1 to ground. Thankfully, we did not blow up the ociliscope, unfortunatly, we did discover a frequent output of 10 volts from the coils through the distributer (presumably, 10v is too low to cause a spark). As far as I can tell, all signs point to low voltage causing low voltage. Do you all think that's the problem? More importantly, if that is the problem, how would we solve it?
  6. Steve Magnusson
    26,932
    #31 Steve Magnusson, Apr 18, 2025
    No (all those voltages are quasi-reasonable). Now that you've got the oscilloscope, you could measure between terminal 1 on the coil(s) primary to ground as shown in John's post #13 -- if things are working, it should look like his "Good" photo -- however, the firing line (vertical spike) can go up to ~350V, and I'm unsure if the FNIRST unit can handle that (so check into that please before doing this). This is a good video to watch:
    https://www.google.com/search?client=firefox-b-1-d&q=voltage+on+coil+primary#fpstate=ive&vld=cid:18ebe188,vid:7_Wio5t6XEo,st:0
    If the input signals are all good, but it's not working = not a good sign for the Digiplexes (and this is where it would be nice to have a known good Digiplex to swap in for a test). Have you had a look inside the distributor caps to see if the caps/rotors/buttons are in reasonable shape and are not filled with oil?
  7. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    If can handle it. Repost form my post #17:
    Triger signal.
  8. FasterIsBetter II
    Mar 15, 2025
    9
    Seattle, WA
    Max Weinstein
    Ignition triggers tested; no discernible signals from either digiplex unit. We recorded these videos on 1 volt per division; you have to zoom in to about 20 millivolts to see any meaningful signal from the output. Since there are two cables leading from the coil's negative terminal (one to the digiplex, one to the diagnosis socket, I believe), we tested all four. Distributor caps were replaced, and rotors were cleaned. links to the videos of each test are below. This seems to indicate the Digiplex units, rather than the coils, are broken.
  9. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    #34 johnk..., Apr 19, 2025
    Wait a minute. If there is no trigger the voltage at either coil terminal should remain at 12V with the ignition on. If you are not getting 12V relative to ground something is wrong with the test or you aren't getting power to the coils, and possibly to the digiplex units. The yellow wires in the figure below are the 12v lead, straight from the ignition. No fuses or relays. You could have an ignition switch problem.
    Ignition off: zero volts at the coils.
    Ignition on: 12 V.
    Cranking: Trigger signal, jumps from 12v to ground (on the ground side of the coil) followed by the spike and then back to 12v, and repeat.
    You might try connecting the yellow side of the coils directly to 12 V. That should also back feed the digiplexs.
  10. drcappuccino
    drcappuccino Rookie
    Apr 15, 2025
    29
    Jason Weinstein
    thanks Johnk. We are getting 11.2-11.5V at those yellow wires that run straight in from the battery while the battery is showing 14V. So we seem to be losing something from the front to the back of the car in that line with no relays or fuses in between, as you say. When you say run 12V to the yellow, do you mean just run another wire straight from the battery to the yellow wire going into the first coil and then try running the starter? Or something else?
  11. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    Are you saying you are measuring 11+ V on the yellow wires at the coils. If that's the case something doesn't make sense.
    Yes. that's what I mean.
    Just rehashing. You seem to be doing everything right. Looks like the scope is in DC mode, which is correct. With factory wiring and the vertical scale set to 10V/division, you should see 0 volts at the coils with the ignition off, then it should jump to about 12V when the ignition is switched on (not cranking). With a jumper, you would see 11+V all the time. (Make sure you have a good ground.) If that happens and then when cranking nothing, it's not looking good for the digiplex units. I'm not saying that 100%. The other thing would be the check for continuity between the coil trigger wire connections at the coil (yellow/black or green) and the digiplex connector pin.
    Has the car ever run since you bought it?
    Perhaps Steve may have additional input.
  12. FasterIsBetter II
    Mar 15, 2025
    9
    Seattle, WA
    Max Weinstein
    Sucess! We wired a direct line from the positive battery lead to the coil, and now, the sparks spark! still no start, but we'll take the win. The only thing is that whenever the line from the battery to the coil that we just ran is plugged in, the car turns on -- without the key in. It doesn't try to start, it just pretends the key is in run position. A little strange, but I think workable. We're going to replace the spark plugs, probably. Cylinders may be a little flooded after all the unsuccessful cranking. Any ideas on the car turning to run when we plug the wire in?
  13. Steve Magnusson
    26,932
    #38 Steve Magnusson, Apr 19, 2025
    That's normal. +12V power from the key and terminal 15 at the coils are connected together by the fuse-relay panel. See the schematic that John posted in post #34 -- the tops of fuse A and B are connected together. When you apply +12V directly from the battery to terminal 15 at the coils with another wire = it powers up everything that key "on" powers up. (Although the schematic that John posted may be for a 308 so how that connection is made on a Mondial fuse-relay panel is probably different.)
  14. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    That's great. Like Steve said, that connection directly to the battery back feeds a lot f things. Does the car have any type of immobilizer? If not, a wiring problem or it may be that you have a bad ignition switch. They can be found pretty cheap. https://www.ebay.com/itm/392883160790?
  15. drcappuccino
    drcappuccino Rookie
    Apr 15, 2025
    29
    Jason Weinstein
    Hi Fasterisbetter II and I have an update and a new question... We got the car to start! We were not getting fuel through the injectors and we took off the air filter to get better access to the fuel distributor. We ran the starter and noticed that actually the air flow sensor plate was not opening. We then pushed it in a little manually and the car started! Below is a video of the testing. (We were able to get spark running the wire to the coils straight from the batteries as discussed above, so we still have an electrical problem, but this problem first now...)
    This air flow sensor plate seems to be the main mechanical issue. Upon inspection it looks like the plate is sitting too high, according to page D30 in the shop manual, it says the plate should not sit "outside the short cylindrical part at all," and it is definitely sitting at the level above that in the upper conical part. Would this cause the plate not to open when the starter is run? If so, the shop manual makes it sound very tricky to punch the stop pin in to lower the plate. any advice?
  16. raemin
    raemin Formula 3
    Jan 16, 2007
    2,388
    Lyon (FR)
    R. Emin
    To much control pressure. Try cleaning the WUR inlet ports (pour some carb cleaner in the port, if it fails you will have to open it).
    Do you have a k-jet test gauge?
  17. drcappuccino
    drcappuccino Rookie
    Apr 15, 2025
    29
    Jason Weinstein
    thanks. we will try to clean the WUR, was trying to avoid buying a k-jet test gauge but maybe we'll need one... We did find some cracked air hose lines that we replaced but that didn't solve it.
  18. drcappuccino
    drcappuccino Rookie
    Apr 15, 2025
    29
    Jason Weinstein
    We got the WUR off and will clean it (having trouble getting the fuel cell screws out right now) and fix up with the replacement part kit. Also got the k-jet test guage so we'll test control pressure when we get it back on. I'm also curious, it appears from the Bosch K-jetronic book that the air flow sensor plate should be sitting at a slight angle with one edge slightly below the flat opening between the two cones. Ours sits entirely in the upper cone by about 1mm. Assuming the WUR is working properly would you expect that to still create the stalling issue at cold start or would you expect that positioning shouldn't matter and the plate should still properly drop? I'm wondering because it seems like adjusting the plate's zero position by hammering the adjustment pin is a very hairy proposition so I'd rather not do it if unnecessary...
  19. Steve Magnusson
    26,932
    Don't disagree that moving the pin to reposition the airflow metering plate in the funnel can be tricky, but use the figure in Chapter D of the 281/83 Mondial 8/QV WSM to determine if you need to do so (but it sounds like you do need to):
    https://www.dropbox.com/scl/fi/twng41f9fpi3ipww7q95v/Mondial8qv_workshop_281-83.pdf?rlkey=5sgpj4yz33jepzrec4x8lcwel&st=9n9fgpcr&dl=0
  20. drcappuccino
    drcappuccino Rookie
    Apr 15, 2025
    29
    Jason Weinstein
    Thanks - we tested the pressure this weekend. System pressure 5.1 bar so seemed good, then control pressure only dropped to 4.8 bar when we opened up the valve. So we have way too much control pressure as @raemin said. We tried to clean the WUR but can't get all the parts open so we are going to send to CIS Flowtech. Will report back... I also have some wiring questions on the wiring bypass we have and how to restore the fuel pump wiring to original. Any suggestion on whether we should start a new thread for that or keep this one going?
  21. raemin
    raemin Formula 3
    Jan 16, 2007
    2,388
    Lyon (FR)
    R. Emin
    Disasembling the WUR is easy. If the point is to clean the wur, once ÿou've got access to the back of the inlet port, just clear the crude with MEK or acetone. Adjusting pressure a bit more complex, but not horrendous. See photos here:
    https://www.ferrarichat.com/forum/threads/what-did-you-do-to-your-365-gt4-2-2-400-412-today.488990/page-9#post-148136419
    And this thread:
    https://www.ferrarichat.com/forum/threads/ferrari-412-cis-injection-experts-opinion-needed-low-power-weak.690904/#post-149597914
  22. drcappuccino
    drcappuccino Rookie
    Apr 15, 2025
    29
    Jason Weinstein
    Hi - updating this thread once again... We received the rebuilt WUR (and tested fuel distributor/air flow meter) back from CIS. We reinstalled and did the mixture screw procedure and we got the car started (without manually pushing the air flow meter)! (We still have to use the wire direct from battery to the back coil still in order to backfill our power problem which also isn't resolved, but not trying to resolve that now.) Now that we can reliably start the car, we are getting a white smoke out of the left tailpipe that smells of gas and really rough sounding run, it seems like we are not getting all cylinders firing and we're getting unburnt fuel pushed out. The idle speed is really low - 500 RPM and if we don't press the accelerator to raise the RPMs it will stall out after about 20 seconds or so. Checked every spark plug extender and each one is sparking. I think we need to adjust the idle screw but wanted to see if others agree before we mess around with that. We tried riching and leaning the mixture screw but it didn't do anything to the idle speed/stalling.
    We haven't pulled all of the fuel injectors to check each cylinder - would people try the idle adjustment first? Anyone know why we're only getting the white smoke out of the left tail pipe?
  23. drcappuccino
    drcappuccino Rookie
    Apr 15, 2025
    29
    Jason Weinstein
    Thanks JohnK - is this a replacement for the back of the key/ignition barrel? We tested the ignition wire (white wire) under the steering column and when in Position III there is no power going to the starter. Instead we are using a work-around from a prior owner who installed a separate push button starter connected to that wire and separately wired to the battery (it runs through a relay board the prior owner installed along with the fuel pump). I have a hope/suspicion that if we could get the key ignition to work properly we might get the power to the digiplex but haven't been able to remove that key barrel yet. I can't get the plastic piece off the top of the steering column because the steering wheel won't drop low enough even after unlocking it.
  24. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,740
    Argent/Brasil
    Guido
    Can you also check the marks on cams and crankshaft! Can be that one belt skipped a tooth (or more).
  25. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    Yes, as far as I know.
