Mondial DIY Links Thread | Page 2 | FerrariChat
Discussion in 'Mondial' started by dfranzen, Jul 23, 2015.
  1. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    Preventing your bottom from catching fire :)
    Earlier models are the same. however USA versions have extra return lines from the fuel accumulator.
    [ame]http://www.youtube.com/watch?v=3LCofRMA-dI[/ame]
  2. Alden
    Alden F1 Rookie
    3,777
    Central Florida
  3. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Ponte Vedra Beach , FL
    Don Franzen
  4. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
  5. petrolheadjeff
    petrolheadjeff Formula Junior
    Apr 16, 2015
    253
    Jeff
  6. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,767
    Argent/Brasil
    Guido
    I got my cambelts Isoran, Dayco from Superformance.
    On the box is marked "made in Argentina". As I travel every year to Argentina I'm looking everywhere to get them. I even maked contact with the fabric Dayco there. But they dont have it in there assortiment.
    What to think of that ?
    Guido
  7. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #32 Wade, Nov 1, 2015
    Here's their website with contact info at the bottom of the page:
    Dayco Argentina Aftermarket
    And for those Ferraris that are prone to camshaft seal leaks, this is interesting:
  8. theunissenguido
    Jan 21, 2004
    2,767
    Argent/Brasil
    Guido
    Tried in every important retailer shop but could not find those belts....and even if I find them, prices for belts are so much more expensive in Argentina then our sources.
    Guido
  9. Alden
    Alden F1 Rookie
    3,777
    Central Florida
    #35 Alden, Dec 27, 2015
    Disclaimer - Do not drive with your Brake Failure light on! It could mean you have no brakes, or they could soon go out on you, probably at a really bad time!
    Check your brake fluid level.
    Bleed the brakes
    Check your brake pads, the electronic wear sensors on the front pads can cause this too. You may need new pads.
    Check all your lights and connections. R&R bulbs and clean the sockets and bulbs, replace any that are out or look suspicious.
    Finally:
    Turn off or disconnect the battery and remove and clean all the connections on the master cylinder reservoir in the pic below with electrical contact cleaner. (These pics are from my 3.2 with ABS, yours may be different!)
    Don't lose the metal clips on the connections!
    Re-connect the battery.
    Check brake operation.
    Checking the items above will usually fix it.
    If the light stays on it may be something else, like the front/rear apportioning valve may be bad.
    Alden
    Edits, clarifications or corrections from the experts are encouraged, thanks!
  10. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Don Franzen
  11. theunissenguido
    Jan 21, 2004
    2,767
    Argent/Brasil
    Guido
    #40 theunissenguido, Feb 26, 2016
  12. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Don Franzen
  13. Alden
    Alden F1 Rookie
    3,777
    Central Florida
  14. FCnew
    FCnew Formula Junior
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    [ame]http://www.youtube.com/watch?v=niFdms-wRGk[/ame]
  15. roddyracer
    roddyracer Karting
    Mar 14, 2010
    65
    Can you direct me to the section explaining front hood foam piece for top of radiator? thanks rod
  16. Alden
    Alden F1 Rookie
    3,777
    Central Florida
    #49 Alden, Jun 25, 2016
    Rod,
    Welcome to the forum!
    The info you want is here:
    http://www.ferrarichat.com/forum/mondial/491617-quick-easy-replacement-hood-foam.html
    http://www.ferrarichat.com/forum/mondial/389931-foam-above-radiator.html
    2 things:
    1)Please start a new thread with questions, don't muddy up a DIY thread.
    "Please keep your posts limited to links, so we don't get the thread clogged with questions and answers."
    2)The search tool is top right of the main Mondial forum page, I typed in "radiator foam" and 20 threads came up in the search, that is how I found the pages above, there is more info out there in this forum too.
    Good luck with your foam project and welcome to the F Chat family!
    Alden
  17. 19633500GT
    19633500GT F1 World Champ
    13,238
    Blueberry
    Muffin-Tops
    #50 19633500GT, Jul 7, 2016
    Does anyone know how to reset these or turn them off?
    Just had a full major completed, but they forgot to reset. Not sure how it works entirely myself.
