Mondial DIY Links Thread | Page 4 | FerrariChat
Discussion in 'Mondial' started by dfranzen, Jul 23, 2015.
  1. OpenAirFan
    OpenAirFan Karting
    Aug 10, 2008
    72
    Krefeld, Germany
    350HPMondial, Nasa1990 and Allen S. like this.
  2. Norseman
    Norseman Rookie
    Nov 26, 2018
    12
    Ben B
  3. OpenAirFan
    OpenAirFan Karting
    Aug 10, 2008
    72
    Krefeld, Germany
    Nick's Forza Ferrari, 2439 Cedar Ct Custer WA 98240
    Norseman likes this.
  4. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    Nobody's allowed to print the prancing horse emblem on repro parts, only Ferrari itself, but I wonder if the emblem was already present on the original floor mats.
  5. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,780
    Argent/Brasil
    Guido
    Thats a Mustang horse....:D
    JayG and uber2 like this.
  6. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    No. It's the horse Ferrari stole from Porsche.
  7. OpenAirFan
    OpenAirFan Karting
    Aug 10, 2008
    72
    Krefeld, Germany
    There were no original floor mats on top of the carpet. I‘m happy that these additional mats are the same material and color as the original carpets.
  8. theunissenguido
    Jan 21, 2004
    2,780
    Argent/Brasil
    Guido
  9. 350HPMondial
    350HPMondial F1 Veteran
    5,343
    Edwardo
  10. Cafe racer
    Cafe racer Rookie
    Mar 22, 2020
    24
    London
    Nigel Waterfall
    I’m currently in the middle of a overhaul of my Brake & Clutch system, clutch master cylinder was leaking, don’t know when the brake fluid was last changed, ABS loom was damaged (sensors not connected & wiring cut/broken)
    I’ve got a “new” ABS loom, but it looks like i will have to remove the fuel tank to get the sensor connectors to the back of the car as it runs in the channel with the battery cable.
    Got all the bits to do the Clutch master cylinder, the pedal box is currently getting cleaned before rebuilding it & replacing parts.
    As for the brakes, is it worth upgrading to 4 pot callipers or are the single piston ones good enough (i have no plans to track the car - yet)
    Any advice about things to change or jobs to do while I have the car in bits
  11. Incaico
    Incaico Karting
    Jun 13, 2020
    70
    SoCal
    JR Sandoval
    Swap Driver/Passenger Seat - '89 Mondial t
    When I read that the seats of the Mondial were interchangeable, I started looking around on how to do it. Didn't find any steps on how to do it so I decided to document the "swap"
    Removing the seats is very straight forward. Each seat has 4 bolts (#6 allen). Once the seats a removed, the leather covered fiberglass covers need to come off (4 per seat). Then the hardware: both the seat levers, seat lever plate, seat return springs and plate. Both the hardware and the leather covers will be swapped to the other seat.
    Take LOTS OF PICTURES so you can see what hardware goes where.
    Seat Adjustment Levers
    Return Seat Spring
    The trickiest part is when you have to remove spring and put it back on the other seat.
    The spring "catch" (red arrow), needs to be "rewound" and placed where the blue arrow is pointing. I used a large Channel Lock. A couple of tries should do it. The seat adjustment lever is super simple.
    Before I replaced the leather covers over the hardware, i cleaned and conditioned, something I'm sure all of us would do. I even removed the rear cover of the seats and painted the screws. Then I took my time to clean and condition the seats. Very happy with the results.
    Side bolster on driver side was showing wear, now, it's the passengers side turn...
    I also adjusted the seat straps, which I will post later as I am limited with the number of pics I can upload.
    Reach out if you have any questions!
    moysiuan and djs308 like this.
  12. DocBasilone
    DocBasilone Karting
    Apr 15, 2020
    164
    NW PA
  13. bluesubielover
    Apr 18, 2019
    22
    Chesapeake, VA
    Carl Von Mosch
    I have recently discovered that my clutch slave cylinder is leaking. I have flushed the entire brake system of old fluid, but now I’m wondering if anyone has ever rebuilt these with new seals? It’s a serviceable part so guys what’s the scoop. Thanks to all that respond.
  14. theunissenguido
    Jan 21, 2004
    2,780
    Argent/Brasil
    Guido
    What model mondial you have ? 3.2 or t...
  15. bluesubielover
    Apr 18, 2019
    22
    Chesapeake, VA
    Carl Von Mosch
    3.2 cabriolet
  16. 2cam
    2cam Formula Junior
    Aug 28, 2014
    751
    Austin, Texas
    MikeS
    Hi Carl,
    I recently had this happen to my car. There's really only one place for the seals at the moment and that's through one of our wonderful forum members. However, I ended up going with a new slave cylinder from Superformance ($130ish US) due to needing it quickly and being able to use a credit card to order it. I'm still planning to order a set of seals from our forumite to rebuild my old slave cylinder.
    One thing to note is that the slave cylinder from Superformance isn't an exact match. It's actually a slave cylinder from a Lancia Delta Integrale. It bolts up exactly the same as the Mondial slave, but you need to use your old push rod and rubber boot from the Mondial unit for it to work. The Lancia slave also doesn't have a c-clip/seeger ring that holds the assembly in the cylinder. I assume that it won't be an issue, but be aware of it.
    If you do decide to go that route, Delta Works UK has the exact same part for 1/4th the price - https://deltaworks.uk/products/clutch-slave-cylinder-integrale-and-evo?_pos=2&_sid=7c4adcdbe&_ss=r as SP. DHL shipping had the part to me in less than 2 business days of ordering the part.
    If you're in a hurry, this may be a good way to go as you can have it shipped to your door in a day or two for $75 from Deltaworks (including shipping). If you're not in a hurry (or mind the transaction payment methods), it would probably be better to order the seals from our forum member and rebuild your original.
    Good luck with the repair!
    2cam
    bluesubielover likes this.
  17. bluesubielover
    Apr 18, 2019
    22
    Chesapeake, VA
    Carl Von Mosch
  18. porphy
    porphy Formula 3
    1,210
    LouisvilleKY/Switzld
    Randall Gatz
    Is this also valid for the Mondial T?
  19. porphy
    porphy Formula 3
    1,210
    Randall Gatz
    Guido, do you have the seal kit for a T?
  20. theunissenguido
    Jan 21, 2004
    2,780
    Argent/Brasil
    Guido
    I dont think mondial t has the same sistem as the other mondials....maybe the master cilinder is the same, but I have no idea of the diameter of the seal(s).
  21. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    Easy job. Hone out the cylinder and replace the seal. See picture below for PN
  22. theunissenguido
    Jan 21, 2004
    2,780
    Argent/Brasil
    Guido
    You can even do this with the pump stil in place....
  23. stekkefun4
    2,232
    Belgium - Europe
    Yes, I did that with the pump in place. A bit difficult to access, but possible.
    moysiuan likes this.
  24. hnichols
    hnichols Karting
    Apr 15, 2020
    216
    Chicago IL
    Hugh Nicholson
    Pretty basic stuff, but I made a video about putting my car away for the winter. Maybe it will help someone. Or maybe someone will have suggestions for improvement:
    cavlino, MvT and djs308 like this.
  25. Mark C Harvey
    Mark C Harvey Formula Junior
    321
    West Hartford, Connecticut
    Mark C Harvey
    Great job, I agree with your comments on build quality. I had a 2008 Audi and all the plastic screws and connectors under the hood were brittle junk by 2017.
    MvT likes this.
