Hi folks, I was wondering if you guys/gals could clear up my question with regards to some non working electrics on the mondial - nothing new here! My parking lights, radio, cigar lighter and horn have all stopped working. Are these items related to the same electrical circuit? If so, how do i go around finding out which one is causing the fuse to burn out. As soon as I put a new fuse in it burns out. Oh yeah id better let you know that its a 1989 mondial 3.2 with ABS, had a new fusebox about 18 months ago. thanks guys.
Only thing come up with is check it one by one. Get the wires diconnected from evrything with is on same circuit and reconnect it one by one. That will give you the clue with part is causing the trouble. Don't think the new fusebox is the problem
one thing I would do is ensure that the wiring loom connectors are well seated to the fusebox. I had a connector repeadedly burn fuses out before i fixed it. Image Unavailable, Please Login
